Question about Pioneer DEH-P2000 CD Player
Have deh p2000 display is faded not as bright. had stero for years still plays good is there something i can do to get the brightness back. thank you
Deh p8000r having problems with illumination won't get bright enough to see display
Hello! A resistive connection on the vehicle's illumination lead is the prime suspect...If you know the wire color for this signal, make sure it's a good solid connection to the P8000R's illumination wire...If you do not know the wire color send a comment with the year and make of your auto...
Guru........Saailer
Mar 29, 2010 | Pioneer DEH-P8000R
How to adjust brightness pioneer deh-546?
Turn unit off. Hold function button until options display, including tuning steps and display brightness.
Jan 20, 2010 | Pioneer Car Audio & Video
Still, bright images on my PS3 change the color of my TV in areas
hi verifies if you are connecting good the video cable i mean the red, the yellow, and the white, if this dont serve you, is because your tv is to old.
Sep 19, 2009 | RCA TruFlat 27F520T 27" TV
How to set a clock on a Pioneer DEH P2000 car audio system?
turn radio off and press clock then press function for about 4 seconds and the display will appear with the clock functions
Sep 01, 2009 | Pioneer DEH-P2000 CD Player
My Pioneer DEH-P645 faceplate display is FAINT
The circuit board is broken.
I was trying to find out about setting the display dimmer option. I found someone that had a manual and was told to set/reset the "dimmer on/off" by pressing the function button repeatedly while the unit is powered off. When dimmer showed on the faceplate press up or down to set or reset the dimmer option. This was done in a dark closet as the display was so dim. Anyway, setting dimmer to on/off made no difference in the brightness of the display. Oh well. . . BTW, I found that the manual is not a free download and can cost between $18 - $40 on the internet - geeeeee whiz, Pioneer is not a user friendly company.
Mar 06, 2009 | Pioneer DEH-P645 CD Changer
Faded out Acer LCD screen
It's not a contrast / brightness issue, even at the lowest setting the screen would look normal and probably not the way you're seeing it now. It's likely that the inverter or backlight went out on the lcd. You could possibly turn them up the highest level, but it would still need to be serviced by Acer for it to work correctly.
Glad to hear you've got the extended warranty.
Best of Luck!
Feb 23, 2009 | Acer Aspire 1800 Notebook
Palm Z22 display faded out, unreadable
TRYit with normal reset >
 way to do it > insert stylus in left bottom corner of ur phone but before it take back up or consult service centre coz might be display issue good luck
Sep 04, 2007 | Palm Z22 Handheld
DEH-P670MP Display goes from regular to extra bright, then back
Your deck has "reverse mode" activated. To turn it off, just turn off the power by holding the source button. The press the preset "5" button. When you turn the deck back on, reverse mode should be disabled. (If this doesn't work, try the same procedure with button "6". One's for reverse mode, the other for demo mode, but I'm not sure I remember which is which).
Jul 01, 2007 | Pioneer Premier DEH-P670MP CD Player
Tv has bright green color
you are having a problem in your video circuit and your tunner section if the green is smooth also have the deflection ic checked.but this set needs to be taken to a qualified tech repairs could cost about $1oo.00 good luck.
Nov 16, 2006 | Samsung TXK2554 25" TV
Pioneer DEH-P2000 CD Player Logo
110 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
