Question about Plantronics Explorer 230 Bluetooth Headset
Im having a hard time pairng my blue tooth. its a plantronics 230
    Prodigy:
    An expert who has answered 500 questions.
  • 537 Answers
Here are a couple of things to try. First, remember that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove again the battery for a few seconds, then replace the battery and turn it back on again. Then reset the headset. The attached user guide for the Plantronics Explorer 230 on page 7 will show you how to turn off / on the headset and then page 4 will walk you through the pairing process. Remember to remove any lingering bluetooth connections from your phone.
Plantronics Explorer 230 User's Guide
Good luck from Headsets Direct!
Posted on Nov 29, 2011
How do I set up my explorer 230 to work with an I-Phone 4
turn blue tooth on on your iphone under settings click general click on blue tooth make sure its on then it will auto serch the super tooth make sure its turned on
too easy let me know how you went
Mar 01, 2011 | Plantronics Explorer 230 Bluetooth Headset
It is not being detected by my new nokia C7
you must make sure you have your blue tooth device turn on to discovery mode most blue tooth devices you just hold the power button for 6 to 10 second when turning on the device,once it is in discovery mode your phone should find it,then you will need a 4 digit pn or pairng code,most blue tooth manufactures use a 4 digit code they are as follows 0000,1234,1111 or 9999 i hope this helps
Feb 21, 2011 | Jabra Radio Communications
How to you set it up with your phone
In order to set up your blue tooth device to your phone you first must turn your blue tooth power to on in your phone menu then you must turn your blue tooth device into discovery mode.this usually is done by holding the power on for 6 to 10 seconds and a solid light will be on,then in your phone menu you can add or search for blue tooth device if you have your blue tooth in diuscovery mode the two will pair then you must enter a pin or pairing code,most manufatures of blue tooth devices use a 4 digit factory pin or pairing code they are as follows 0000,1234,9999 or 1111 enter the code and they will pair ,once paired it might ask you to connect ,selet ok or yes and your in business, i hope this helps
Feb 21, 2011 | Plantronics Explorer 230 Bluetooth Headset
I have a droid x and a friend gave me an plantronics explorer 240 cause she had gotten another one. I thanked her not thinking to ask how it worked like what buttons was what and how to connect it to my...
First of all, go into Settings and then Wireless & Network settings on your Droid X, then push Turn on Bluetooth. The check mark in the box should be green once its on. Then click Bluetooth Settings. Meanwhile, turn on your headset by sliding the power switch towards the microphone. The light should flash blue and red. Now go back to your phone and push Scan for Devices, at which point you should see something like "XXXPlantronicsHeadsetXXX". Push that, and it should work. IF it asks you for a passcode, its 0000. Here's the Plantronics help site: http://www.plantronics.com/us/common/easytopair/#/explorer-240
Feb 21, 2011 | Plantronics Explorer 240 Bluetooth Headset
How can I conect to my HTC wildfire when searching my phone cant find my plantronics Many thanks
You have to put your blue tooth device into discovery mode,Most blue tooth manufactures use the power button by holding it down for 6 to 10 seconds when turning the device on,then when you are searching they will pair ,now you will be asked for a pin or pairing code.Most blue tooth device manufactures use a factory pin pairing code they are as follows 0000,1234,1111,or 9999 i hope this helps
Feb 19, 2011 | Plantronics Explorer 230 Bluetooth Headset
When I hit the button on my blue tooth it sends my messages directly to voice mail. How can I fix that.
It almost sounds like you are rejecting a call, and when that happens you will send it to voice mail. It says that if you are tapping twice, it will sens it. I am also giving you the link to the users guide below to try and help.
If this does not work please refer to Plantronics tech service, 800-544-4660 ext 5538.
Feb 01, 2011 | Plantronics Explorer 230 Bluetooth Headset
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
I don"t know how to put my blue tooth in discoverable mode
Try this:
1. With your headset turned on, simultaneously
press the listen volume adjust button marked
+ (volume up) and the call control button.
Release the buttons when the indicator light
begins to flash red then blue.
2. While the headset is flashing red and blue,
use the phone menu to search for Bluetooth
devices and select "510 Plantronics".
3. When prompted for password, enter 0000.
The headset will flash blue when paired
successfully.
Don't forget to rate if this was helpful :-)
Sep 19, 2010 | Plantronics Explorer 230 Bluetooth Headset
Does explorer 230 pair with nokia 2600
the explorer 230 blue tooth can be paired with the Nokia phone if only the blue tooth tooth device is a universal blue tooth.
Universal blue tooth can work with any phone no matter the model.So check the blue tooth if it is a universal blue tooth, try it with the phone and see if it will work.
Have a nice day
Mar 16, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Plantronics Explorer 230 Bluetooth Headset Logo
91 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
Ed Nelson
Ed Nelson
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
