Question about HP Office Equipment & Supplies
Software won't reinstall, I had to uninstall my complete system everything apart from my all-in-one printer is working correctly apart from this. It's a C3100 all-in-one series.
Uninstal softwere ,check virase and and reinstal softwere
Posted on Aug 05, 2008
Printer won't print. I had to move the desk and everything was unplugged and now it won't print. It is on, checked as default, on-line, I think it may be the port.
  1. Background
    • HP provides details of the problem on its website. The problem usually occur on PC laptops or when printing across a network. HP offers several fixes for the problem.
    Software
    • First, check your Windows print queue and ensure the printer is not set as "Paused" or "Working Offline." This can often clear the problem and resume your printing.
    Resolution
    • The problem can also be caused by printer driver issues. Try uninstalling and reinstalling the printer driver. Connecting your printer directly to your computer using a parallel cable may solve the problem, but this may not be practical in all cases as many modern laptop computers do not have a parallel port.
Instructions
    • 1 "Power Cycle" Your printer. Shut down the printer, unplug the power cord from the socket, give it 5 minutes, plug it in again and turn it back on. Try to print.
    • 2 If the printer still won't process a job, shut down and restart your computer.
    • 3 Check your printer cable connections to the computer.
    • 4 Check the printer for any paper jams, check the trays, and also pull out the toner cartridge and/or remove any paper jam, if you find one. Put the cartridge back in. Then try to print.
    • 5 If after completing the steps above, the printer is still not working, click "Start," then "Settings," click "Printers," and the printer folder will open. Make sure your HP LaserJet 5 is selected as the default printer.
    • 6 Double-click your printer, and delete everything from the print queue, canceling all the print jobs. Close out the queue.
    • 7 Right-click on your printer icon and make sure it's not offline. If it is, then click "use this printer online."
    • 8 Right-click your printer, and click properties. Make sure the right port is selected for your LaserJet 5 Printer. If you are using a parallel cable, you are most likely using an LPT port; if USB, then look for a USB connection in the list. If the port connection is correct, try to print again.
    • 9 It's still not printing? Click "Start," then "Control Panel." Double-click "Programs and Features" or "add or remove programs," uninstall your Laserjet printer software, and restart your computer.
    • 10 Insert your Laserjet software and driver disk. Proceed to reinstall your printer software and drivers. Then test the printer again. If it is still not working, you probably will have to seek professional assistance.
Jan 20, 2013 | HP LaserJet 1012 Printer
My Brother MFC215C is not working with my newish computer which has WIndows 7 on it. I have tried uninstalling and reinstalling the correct software but when I get to the point where I have to plug the...
Are your usb ports correctly configured ? Are you using the right printer software/drivers for your windows 7 (32bit or 64bit) ? Try uninstalling everything and try again, but don't plug in the printer until it tells you to.
Jun 20, 2012 | Brother MFC-215C All-In-One InkJet Printer
Dell printer will not complete task. If printer is uninstalled then reinstalled it will print one time but doesn't complete the task on the "printing screen". I go to the printer window...
Hi Bill,
Have you tried the printers on another PC?Please do.
  • Whats the Operating System on your PC?Do the printer drivers correspond with that Operating System?If not,download the corresponding drivers from this dell support site. This you select under compatibility.
  • After uninstalling the printer,disconnect fully and unplug from power.Reboot your PC before installing the printer again.
Hope this helps.Thanks!
Nov 01, 2011 | Dell V305w All-In-One R840635AU InkJet...
Hp 5610 software won't finish installing on xp
Please uninstall the software as it has not been installed correctly... uninstall the entire software completely while doing it make sure the printer USB cable should be unplugged ... reinstall the software by downloading the full version software from HP.COM
May 10, 2010 | HP Officejet 5610 All-In-One InkJet...
It won't work
hi
Try to figure out if its hardware or software issue.
unplug power adaptor from the back of printer.press and hold the button on printer and simultaneosly plug the power adaptor..if a test page prints out-hardware is fine and issue is with software..to correct software issues-try driver uninstall and reinstall.
Jan 24, 2009 | Lexmark Z640 InkJet Printer
Printer will not stop printing until it runs out of paper
Delete all printers, uninstall related drivers and printer software. I have uninstalled and deleted related folders (but don;'t delete from Recycle Bin in case you need to put them restore them). Boot up and Windows should reinstall correct drivers through the internet. Reinstall photo programs with disk that came with printer.
Aug 29, 2008 | Epson Stylus 880 InkJet Color Printer
Fatal error message
Hi all,
The error happens if your installation did not finish completely and you didnt have complete access and permission to the system(even though you are an administrator). Run the access denied tool by hp by clicking on the link http://tinyurl.com/5u2pg three times. uninstall the software and reinstall again. If this dosent work you will have to manually change the permissions in the registery.
hope this helps!
cheers
Aug 10, 2008 | HP Photosmart C4280 Aio Printer
I have canon mp160 printer. how do i usethe scanning function?
You can access the scanning function usually through a button on the front of the Canon, or using the Canon toolbox. If neither of these methods work, double check the physical connections to the printer.
Once you've verified everything is plugged in correctly, and it still doesn't work, you may have to uninstall and reinstall the software that came with your printer. Just make sure that you unplug the Canon from the computer before you uninstall the software, and don't plug it back in until the installation software tells you to do so.
Jul 24, 2008 | Office Equipment & Supplies
Can't load printer Driver in WinXP
Uninstall the printer and unplug any other USB printers you have restart you PC and then try installing if this doesn't work then the driver has not been completely removed in the system registry. You will have to do this manually but I do not know the correct fields for this printer.
Thanks J
Jan 07, 2008 | Sharp AL-1641CS All-In-One Laser Printer
HP 1315
You should have gotten an installation CD with the printer. First, find the installation CD. Once you have that, follow the steps given by the tech.
Apr 25, 2007 | HP PSC 1315 All-in-One Printer
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
