Question about Maytag SDE2606A Electric Dryer
I need the diagram on how to wire the power cord in
    President:
  • 3,074 Answers
Http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=5
Posted on Apr 02, 2011
Put on a new power cord wiring diagram
If you need a wiring diagram for this task you should not be doing the work. Please don't dis-assemble the fan, or try to work on it unless you already know what you are doing, you could easily use the wrong cord or not connect the (rather simple I admit) wires correctly.
Feb 07, 2015 | Dryers
Replace power cord sta-rite pump
You should have a ground wire (attaches to the grounding screw) and two other wires that attach to the terminals. Which way doesn't matter. The motor will not run backwards.
Jun 30, 2013 | Pool & Spa
Moved and the new place has a 4 prong outlet. i need the wiring diagram to switch from 3 prong to 4 prong power cord
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Sep 03, 2010 | Dryers
Need wire diagram for 4 wire cord [color code[
Here is a tip that will help you with that problem...
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
heatman101
May 17, 2010 | Dryers
Kenmore dryer 3prong cord installation diagram
if its a" flat cord" what-ever color jacketed 3 wire cord, the 2 outside wires are your 2 hot power wires they go to L1 and L2 on your dryer,the center is the N neutral wire and goes to the N terminal,usually the L1 and L2 are a gauge larger than the neutral: HINT: the center is normally neutral on both the cord and machines terminal board in the back of the dryer,there usually is a diagram on the dryer on how to install the input power at the place you hook up power
Feb 07, 2010 | Kenmore 62602 Electric Dryer
Wiring diagram for new power cord
TRY TO ORDER A REPLACEMENT FROM THE PARTS STORE IT WILL BE EASIER TO USE AN YOU CAN FOLLOW THE COLOR CODED WIRES, PLUS YOU DONT HAVE TO WORRY ABOUT FIRES OR OTHER PROBLEMS TO OCURR
Feb 05, 2010 | Dryers
Need a readable motor wiring diagram for Eureka Vacuum Bagless Upright 4388.....
take the black lead of the power cord to one on-off switch lug, then take wire off other switch lug to one motor connection terminal, brilg other motor terminal wire back to other wire on the line cord.simply a series power circuit
Sep 27, 2009 | Vacuums
WIRING DIAGRAM
The following link explains the proper wiring scheme for installing a 220VAC power cord to an appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Make sure you also have a dedicated outlet and power source for your dryer. This means a single outlet with a single circuit breaker. Most homes are constructed this way to ensure safe operation of the appliance and to prevent improper loading. If you have questions, please let me know.
As far as a wiring diagram is concerned, most manufacturers place a schematic drawing inside the operator console of the appliance for troublshooting purposes. I hope this helps.
Oct 16, 2008 | Kenmore 64732 Electric Dryer
Cord Connection
If your dryer cord is flat and gray, then simply attach the two outside wires from the cord to the left and right screws on the terminal block. Connect the center wire of the cord to the center screw of the terminal block. The only important wire is the center wire of the cord goes to the center screw of the terminal. The two outside wires don't matter.
Jun 13, 2008 | Roper RES7646KQ Electric Dryer
Maytag SDE2606A Electric Dryer Logo
54 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
