My creative zen will not charge and not turn on
  • paynee Aug 18, 2008
    MY IPOD WILL NOT CHARGE WHEN THE BATTERY IS FLAT IT WILL HOWEVER CHARGE WHEN I HAVE A SMALL AMOUNT OF POWER LEFT
    President:
  • 4,402 Answers
Have you tried a ac charger?
Posted on Aug 05, 2008
SOURCE:
Creative zen won't turn on
had same prob to the T...found this post and it fixed it...it's the computer not the zen...once I did the two steps my zen started charging and turned on...go figure...the flashing blue light doesn't mean it is charging.
posted on Feb 25, 2009 abeales
If you have windows set to do automatic updates, you most likely had a windows update installed that caused this conflict with Win Media Player 11. No fix has been posted by Microsoft yet, so the only workaround is to Uninstall/Rollback Windows Media Player 11. Goto <Control Panel<Add/Remove Programs and remove Windows Media Player 11. Follow prompts, restart computer when prompted to. Also uninstall Windows Media Player 11 Runtime application following same procedure above.
This will roll your Windows Media Player back to version 10 or 9, whichever you had installed prior to version 11. You will need to re-configure Windows Media Player again.
Your Zen should now be recognized by WMP and Creative software. You probably need to upgrade your firmware at this point, follow the instructions on upgrading your firmware, and you should be good to go.
This is a windows problem, not a creative problem. Dont blame Creative for the screwed up hotfixes that Microsoft puts out on a regular basi
May 28, 2009 | Creative Labs ZEN Vision:M Digital Media...
My Zen Creative is stuck and will not turn off/on or play music!
If you have a warrenty "accidently" drop it on the ground and return it.
Apr 06, 2009 | Creative Labs Zen Touch MP3 Player
Creative zen
itcan happen because of battery ded.can you remoove the battery and connect it again to usb and turn on if it is on ,problem is with your battery.isnt it????
nuwan
Jan 12, 2009 | Audio Players & Recorders
How to charge my creative zen mp3 player
Just connect your Zen onto your PC (NOT LAP TOP) on a USB.
If does not start charging (you´ll see arrow and pause/ play buttons flashing slowly) then you need to RESET your ZEN.
How to reset: You´ll find a tiny little hole by on/off button on the side. With ZEN connected to the PC USB or onto wall charger try turning ZEN on, it doesen´t matter if it turns on or not. Then insert a sowing pin or office paper clip end in this reset hole for a few seconds and release. Give it a couple of seconds and see the lights go off onto charging mode. LEAVE IT CHARGING for 24 hours. Make sure your PC will NOT turn itself on safe mode or hibernates in this period, it has to be ON for charging, at all times.
This is it.
Louise Passalacqua.
Jul 08, 2008 | Creative Labs ZEN V Plus MP3 Player
Zen not turning on after powering up
I had the same problem. Couldn't turn on the Zen and computer wouldn't recognize it.
I took a safety pin and reset it. It works now! Thank goodness!
Apr 28, 2008 | Creative Labs Zen Digital Media Player
Creative Zen Neon 2 stopped working
leave it until it's all charge get dis charge than charge it from your PC it will works then
Mar 25, 2008 | Creative Labs ZEN V Plus MP3 Player
CREATIVE ZEN VISION MZEN VISION M TECHNICAL SUPPORT
read this:
http://www.anythingbutipod.com/forum/showthread.php?t=10960
Dec 12, 2007 | Creative Labs ZEN Vision:M Digital Media...
47 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
