Question about Minolta Magicolor 3300 Color Printer
Imaging unit missing - Minolta Magicolor 3300 Color Printer
  • heidi204 Apr 03, 2011
    I have cleaned everything.
    what is the PWB-B? I cannot figure out how to take the side of the printer off to get at the gear.
    Please HELP!
  • 3,530 Answers
Welcome to Fixya
Its the contact sensor, find it on the imaging unit, then clean the corresponding on inside the printer (its easier to find it outside of the printer if you don't know where it is) if this fails then you may need to replace PWB-B. You might need to adjust it. The gear might have jumped not letting the plug come in contact with the unit.
Thank you for using Fixya!
Posted on Apr 02, 2011
  • Jose Cada
    Jose Cada Apr 03, 2011
    remove the topcover (after removing the colour catridges )and. remove the left hand side panel. You will see a nylon gear mechanism. Sqeeze together the nylon clip inthe centre of the gear wheel, and pull the gear about halfway off. This should allow you to move the vertical geared bar up 1 notch. .Push the gear wheel back on and try the machine to see if it works ok. All covers will need to be closed and if it works ok , reassemle the machine. Job done -about 10 to 15 mins.
How do I reset ms610 imaging unit?
When you get the error message "Replace imaging unit, 0 estimated pgs remain [84.3x]" This means the imaging unit has reached end of life and needs to be replaced. The device will not print, and this message will not be cleared, unless you replace it with part number 50F0Z00
(or 500z)
Vertical streaking. If the imaging unit is near end of life, or the device has had problems with non standard toner, vertical streaks may occur on the page. Replacing the imaging unit will resolve the problem.
Vertical streaks on page
Vertical band at top of page. This typically appears on printed images, but can also appear on text. The most likely cause is toner contamination on the charge roll, however if the band is still visible after printing 30-40 continuous pages this means the imaging unit needs to be replaced.
Vertical Banding on images
Seal failure on the imaging unit. Occasionally seal leaks have been seen from the Imaging Unit.
Toner will be seen on the main frame near the Imaging Unit sides.
If toner build up is excessive, it may even fall into the Tray below. Cleanup with a toner vacuum may be needed.
Replace the Imaging Unit to fix the problem.
Spots, scratches, marks on the page. If they are random, this indicates a problem with toner scatter.If they are repeating patterns, measure the distance between matching marks or spots. If the distance is one of 97mm, 47mm or 38mm, this indicates marks or dents on the imaging unit and it will need to be replaced.
You receive the message Replace defective imaging unit The imaging unit is defective and needs to be replaced. If you just installed it, it will be covered under warranty - contact Lexmark Australia on 1300 362 192
You receive the message Reinstall missing or unresponsive imaging unit and the below instructions don't resolve the problem. Try one or more of the following:
  • Check if the imaging unit is missing. If missing, install the imaging unit.For information on installing the imaging unit, see the "Replacing supplies" section of your device's User's Guide
  • If the imaging unit is installed, then remove the unresponsive imaging unit, and then reinstall it.
  • Note: If the message appears after reinstalling the supply, then the imaging unit is defective. Replace the imaging unit.
You receive the message Replace unsupported imaging unit The imaging unit you attempted to install was either non-genuine, or was from a different region. Buy a genuine Lexmark imaging unit from an authorised Lexmark supplier in your country/region.
You receive a 31.6x error One of the following errors is shown on the display:
31.60 Imaging unit smart chip error
31.61 Imaging unit I2C packet timeout
31.62 Imaging unit I2C packet has been sent but code timed-out on receiving the data (callback)
31.63 Imaging unit security error in the send challenge sequence
31.64 Imaging unit ROM signature error
31.65 Imaging unit stuck busy (status register and/or CRI Arbiter register report busy)
31.66 Toner failed to replenish into the imaging unit
In this case you need to ensure that the imaging unit is properly installed. If yes, check if the imaging unit is supported. Replace with a supported imaging unit if necessary.
If the problem remains, you will need to organise a Lexmark service call (Australia 1300 362 192)
You receive error message 32.11 Imaging unit smart chip compatibility error This could be caused by an unsupported imaging unit (non-genuine or incorrect region). Replace with correct imaging unit to clear this error. If your imaging unit is supported, you will need to organise a Lexmark service call (Australia 1300 362 192).
You receive error message 84 Imaging unit low If expected, replace the imaging unit. If unexpected, call Lexmark Support (Australia 1300 362 192)
Jan 23, 2017 | Office Equipment & Supplies
IMAGE UNIT MISSING
Imagin unit have a life chip .When this imagin unit life finished than need new one.
Jul 08, 2014 | Minolta magicolor 3100 Laser Printer
Smudge and missing ink
remove all image units. clean the class where the laser writes on the drum with machine no laser. so clean. smudge what color replace the that color image unit.
Apr 07, 2014 | Konica Minolta Magicolor 1600W Printer
Install imaging unit
may be image unit cable is missing or it is damged check image unit
Jun 27, 2013 | Samsung CLX-3175FN Color Laser All-in-One...
Magicolor 3300 - Imaging Unit Missing
reseat the missing image unit or get a new one, or the sensor is bad for that image unit
Sep 30, 2009 | Minolta magicolor 3100 Laser Printer
Imaging Unit Missing on Konica Minolta Magicolor 3300 after paper jam?
I had the same problem previously. I had a small piece of paper jam in the imaging unit
pulled it out and got the Imaging Unit Missing error. I could not solve the problem so I called it in under the extended warranty. Even the printer tech could not solve this issue. But, I look at this file, took off a the side cover moved the gear an viola! fixed..
Try page 3-308 of this PDF.
ftp://ftp.qms.com/pub/cta/out_going/other/diagcd/mc3300sm.pdf
Apr 02, 2009 | Minolta magicolor 3300 Laser Printer
Minolta Magicolor 3300 Imaging unit
I had the same problem. Check out page 3-308 of this document.
Take off the side cover and re-engage the gear. Should solve the problem.
Oct 23, 2008 | Minolta magicolor 3300 Laser Printer
2 Missing ink black streaks
Check the dev unit for missing lines. Also clean the laser glass with the supplied cleaner pad - though if the problem were caused by toner on the lens, there would be gaps in ALL colours.
Check the dev units first. You can also do a stop test whilst a full colour test image is half way through printing and see if the lines are missing off the image on the PCU as well.
May 20, 2008 | Epson Aculaser C1100 Printer
Imaging Unit Missing Error
Hi, I had the same problem. The following Cause and solution may help you fix your machine.
All refereces to left and right are facing the front of the machine as if for normal use.
The cause is due to the connector on thtop left rear of the imaging unit. this connector is mated with a coresponding, retractable connector in the body of the machine. When you open the cover over the top of the imaging unit, this connector retracts back into the body of the machine and when you close the lid it should re-engage with the imaging unit, The problem is that it dosen;t reconnect. I have asumed that it is due wear in the connector operating mechanism. This solution was effective for my printer.
Switch Off!!!
remove the topcover (after removing the colour catridges )and. remove the left hand side panel. You will see a nylon gear mechanism. Sqeeze together the nylon clip inthe centre of the gear wheel, and pull the gear about halfway off. This should allow you to move the vertical geared bar up 1 notch. .Push the gear wheel back on and try the machine to see if it works ok. All covers will need to be closed and if it works ok , reassemle the machine. Job done -about 10 to 15 mins. It tookme alot longer to find it,so some feedback would be appreciated.
Paul
May 04, 2008 | Minolta magicolor 3100 Laser Printer
Missing Imaging Unit
When I had this problem the solution was a tiny piece of paper which was jammed in the machine.
When the jam was cleared the message went away.
Hope this helps
Jan 29, 2007 | Minolta magicolor 3100 Laser Printer
Minolta Magicolor 3300 Color Printer Logo
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
