Question about Cell Phones
I have lost my charger what voltage is the original charger?
  • tinky25 Apr 03, 2011
    for what cellphone?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 157 Answers
Just go get a generic charger that fix your phone. And the voltage info is usually on the battery
Posted on Jun 20, 2011
Charger output voltage and amp
Search google for a charger for your laptop model and look at the specifications shown for the chargers available. The voltage may also be on the bottom of the laptop and also on the battery pack.
Jun 28, 2016 | Computers & Internet
I lost my original charger for it so is there another kind of charger i can use to charge it
There are 4 things that have to match up.
Plug - obviously the plug has to fit
Polarity - If the plug fits, this is PROBABLY ok, but the negative/positive must be the same as the original
Voltage - The voltage output should be the same as the original, which will be a few volts higher than the battery. If the voltage output is the same or less than the battery, it won't work. If the voltage is too much higher than the original, it might fry the battery and the charger.
Current rating - If the current rating of the replacement charger is less than the original, it might fry the charger. If it is much higher than the original, it MIGHT fry the battery. You can probably go +/- 20%
Jul 17, 2012 | Razor MX500 Dirt Rocket
Lost the charger to my notebook
What's your notebook model? Not all ac adapters work. Before making a purchase, make sure the following three conditions meet.
1) Output Voltage is within +/- 5% of your old charger's output.
For example, if your old charger provides 19.5V, then you can use a charger that provides 20.5V or 18.5V.
2) Output Current is the same or higher than that of your old charger.
For example, if your original adapter provides 3.42 Amps, then you can use a charger that provides 3.42 Amps, 3.9 Amps or higher.
3) Connector tip must fit securely into your laptop.
Here blow is a store specialized in laptop ac adapters, have a check.
http://www.chargerbuy.com
Dec 04, 2011 | Computers & Internet
I have a victorlite 1.5 million candle power spotlight lost charger but I have a 12 volt 1000ma- will that work??
If the voltage and tip polarity of your replacement charger matches the charging port on your spotlight, there's no reason why it shouldn't work as a substitute for your original charger. Note, however, that if your original charger was more powerful (say, 1.5 amps instead of the 1-amp charger you have here), it will take noticeably longer to fully charge your spotlight than the original charger took. it's not a problem if the original charger had a lower mA rating than the replacement in your hand--the spotlight will sip an appropriate amount of juice from the charger.
Jul 13, 2011 | Vector 1 Million Rechargeable Spotlight
I lost the plug adaptor for my Wolverine 6020 hard drive and am trying to figure out what type it is so that I can buy a replacement. Can you tell me what type of adaptor it takes? Voltage? Any info would...
The Wolverine 6020 charger is model SL15A212-U, input 100-240vac, 50-60 Hz 0.5a max. Output +12Vdc 1.5A. Tip/ring plug tip positive. This info came off original Wolverine charger. The tip/ring is small.
Jan 01, 2010 | Wolverine Computers & Internet
Charging
for most phones it is always best to use the original products the generic ones may not give you the correct voltage ffrorm the charger for the battery
Sep 29, 2008 | Motorola Mobility RAZR V3
Charger Voltage and Watt Differences
it hardly matters if u are using a 90 watt adapter instead of a 65watt
it will charger the battery much more faster
so you can use it
it should power on your system without the battery.... just check that first
Jun 07, 2008 | HP Compaq Presario C304NR Notebook
Help!Phone does nothing!
Ok you need to replace that charger cos thats the one that is doing all the damage. Check your battery voltage if its below 3v then you need to rejuvenate it back to its original capacity. It will be ok good luck.
Jul 02, 2006 | Samsung VM-A680
Cell Phones Logo
47 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
