Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
I can not find the model number of my Kenmore gas stove. The oven part does not work but the burners work. Do gas oven have a heating elelment?
    Sergeant:
    Champion:
  • 218 Answers
No but they do have a pilot light check and make sure that it is lit for the oven
Posted on Apr 02, 2011
Hello, We have a Kenmore gas stove model # 71761. The burners on top work good.The issue is with the oven portion. Oven is working. Flame comes on upon ignition to desired temperature setting and then...
It sounds like yous stove is working fine. Cycles fine. If you think the stove is cycling more often than when new then ck the seal on the door. You may be loosing heat.
Jan 14, 2011 | Ovens
My oven doesn't work but my top burners do. It's a gas stove Model #36273271690
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Oct 28, 2010 | Kenmore Ovens
My kenmore electric oven works on the 4 burners on top, but the oven part does not heat at all.
There is an upper and lower burner, since it's not heating at all it's either your gas control valve or your temperature control board.
Note: If you have Sears service come out to repair your stove beware, We had them fix our stove. They told us there would be a $65 charge for them to come out but if we had the repair done it would be included in the repair price. Instead after they had our stove torn all apart they told us we would have to pay both charges or they would just leave with our stove in piece and we would still owe them the $65.
Jun 11, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
My Kenmore gas stove has a light constant smell of gas coming from the oven. The oven also does not heat any longer. Burners work fine. Model 970
There is a problem with the regulator or the thermal bulb you need to call a repairman in to replace it, if you have a gas smell it is allowing the piolet light to have gas comming out and not lighting this is DANGROUS do not put it off get it looked at right away. This can kill you.
Nov 13, 2009 | Kenmore Ovens
I have a kenmore gas range with electric ignitors. My question is that my stove top doesnt ignite but lets gas by and I can use a lighter to lite them. However my oven doesn't do anything...no gas no...
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Nov 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
Kenmore gas stove Model 790
It could be that the sensor wire that controls the main gas valve is out of position. It should sit in the pilot light flame.
Look, and adjust if needed.
If it's ok, then you need a replacement main gas safety valve.
This should only be fitted by qualified personnel.
They do give up eventually after years of heating, and fail safe.
Dec 31, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven won't heat
do you see a bright glow in the oven area when the oven is turned on it will take 20 secs or so..If not your ignator maybe bad no gas will flow into the oven unless the ignt. is good
Mar 03, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Problem with Kenmore Electric stove
I have kenmore stove mod.790-95660103 you turn on any top burner . T he small one inside the big burner comes on Roy
Nov 24, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
133 people viewed this question
Top Kenmore Ovens Experts
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
