Question about Sony STR-DG820 Receiver
My system is set up with an A & B (inside and outside) front side along with back speakers and a center speaker (for dialog on TV & movies) the center chanel does not turn off when you switch from A (inside) to B ouside. I have to kick up the power for outside and the center channel is still blaring. Is there a way to get the center channel to work only with the A speakers?
  • 24 Answers
Only the front speakers are affected by the A/B switch.Press the 2CH/A. DIRECT button on the remote to force the receiver to only output sound to the front speakers and mute the other speakers that are not being used.
Posted on Apr 02, 2011
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
How to set up surround sound
Not sure what you are looking for
But if 5 speaker setup have your front left and right speakers on the appropriate side of the television, your center speaker in the middle of the tv, Either mounted on the wall or underneath or on the shelf, try to have the center speaker set back from the front speakers. Subwoofer usually I mount behind the entertainment center. Your rear right and left speakers optimum position is behind you on the left and right.
If its a 7 speaker setup everything is the same except side right and left speakers go in the middle somewhere between the right and left front and rear speakers
I will make a example the the cursors [] Speaker *TV
LF[] CT and TV*[] RF[] []Subwoofer behind tv
SL[] []SR
LR[] RR[]
Hopefully that helps
Aug 15, 2013 | Audio Players & Recorders
I have background sound on my TEAC HTX1800 DVD player, but I can't hear the people talking. Please help?! Regards /Hester
Chances are you are playing movies coded for Dolby Digital Surround. Depending on what kind of receiver your DVD player is plugged into, the receiver may not have the Center channel operating or turned up. Most all dialog comes from the center channel of a surround sound system. The receiver usually has a separate output for a center channel speaker, and a separate volume control as well. This will adjust the dialog volume up.
If you are not using a receiver, or plugged directly into the TV, check the audio settings on the TV. They may not be set up for the surround, hence why you are missing the dialog. Good Luck
Feb 21, 2011 | Audio Players & Recorders
I can hear the music when playing dvd's on my Spectoniq dvd player, but can't hear when people talk. Can anyone help me?
Yes, I can help you. Your DVD player should have output connectors in the back of it to plug your amplifier or receiver into. If you have a Stereo system (no surround sound speakers, or front center speaker) connect the DVD Audio Cables on the back of the DVD player to the STEREO Output Jacks. If it is connected to the Left Front and Right Front jacks of the "Surround Sound" output jacks instead of Stereo is that the dialog on is sent to the CENTER channel output. If you have no center channel speaker you will not hear it.
If you have a surround sound system with two speakers in front and two speaker in back. Then you need to make a change in the Receiver Setup (Which may be set up for 3 speakers in front) so that it is set up for 2 speakers in front.
The last thing my simply be that you have a center channel front speaker that is not completely connected because of a wire falling off, etc.
Hope this helps,
Best,
Mark
Jan 13, 2011 | Spectroniq PD-3000HD
I am not able to hear the dialog while playing DVDs. The background is great and comes through all 5 speakers, however, to be able to listen to the dialog, I have to switch over to 2-channel or Stereo. ...
Well let me first ask is the center chanel working? or properly hooked up. Cause most of the times when in 5.1 the talking or "dialog" as you put it comes only through the center channel its just kinda how they do it. Listen to see if the center channel is working. if you are unsure try hooking up a speaker that you know works into the center channel speaker output. If no sound comes out then the reciever possible has blown its center channel. Please follow up with a comment and i will be glad to assist you further thanks, Midwes-tek
Sep 17, 2010 | Coby DVD765 Theater System
B speaker setup problem
Why don't you set it Zone 2 then you could listen to the radio outside and still watch tv inside. You can turn it on and off just like a and b speakers.
Jul 07, 2009 | Yamaha RX-V663 Receiver
Dvd player
I assume the above problem is on all DVD's. Generally speaking, dialogue soundtrack is located in the Front Center speaker. From your description of the problem I would double check all the wiring to the front center speaker you have connected to your audio system. If there is no front center speaker, check to see how your audio system is set to handle the front center speaker . . . it should be set to "Phantom" or "none". On the other hand you're relying just on your TV speakers and you're not getting any dialog I would change, under the Settings of the DVD player, the Digital Out settings to PCM.
Jun 09, 2008 | Sanyo DWM-390 DVD Player
Back speaker sound
Why would you only hook up one speaker for the rear channel? in 7 channel stereo, all speakers have 100% signal sent to them as "stereo" in Dolby digital, rear speakers are for "effects" not dialog. like a plane flying past you or a car driving by, that's when you hear a rear speaker. It also needs to be placed behind you, not next to you or in front of you. Unless you are using zone 2 & 3 the receiver's surround back will work. if you only have left,right,center,sub & rear; the rear speakers should go to surround speakers not surround back. If you still have questions, post a comment and I can explain further. Hope this helps
Feb 04, 2008 | Yamaha RX-V2600 Receiver
Sony STR-DG820 Receiver Logo
74 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
