Question about Frigidaire FDB1502RGC Built-in Dishwasher
Frigidaire dishwasher model FDB1050REC5 water will run in but wont wash
  • 7 Answers
SOURCE: dishwasher not washing
By chance have you cleaned the spray arm out lately? There could be something blogging the water from getting into the arm. In most dishwashers, the arm only spins because water pressure makes it spin.
Miss Midget
Posted on Nov 02, 2007
  • 1314 Answers
SOURCE: frigidaire dishwasher ultaquiet , model=FDB750RCC1
the first thing that your dishwasher does when you turn it on is drain when you turn it on you hear a motor running then it stops then it fills start the washer when it stops to start filling open the door should be no water in the unit if there is you have a drain problem and in fact are washing your dishes in dirty water can be several things that can cause drain problems a piece of food blocking the line at the sink where the drain goes in if its run to a disposer there is a knockout plug that should be removed just stick your finger in there to see if it was removed get you installation instructions and read the part about not removing the drain loop but just about all the time installers will lol if you cant find the instructions go to www.frigidaire.com under customer support can down load them there let me know what you find
Posted on Jan 17, 2008
rockfixya
  • 679 Answers
SOURCE: Frigidaire dishwasher not completing cycle.
hi,
The cycle doesn't complete
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
On some units, the pause is timed and the unit continues after the allotted time.
On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
I see an error code
If your dishwasher has a digital readout and you see an error code, it may indicate a problem with the unit. If this happens, look up the error code in your owner's manual to find out what the problem is.
Good Luck
Thanks for using FixYa
Posted on Jan 03, 2009
  • 530 Answers
SOURCE: DISHWASHER WONT STOP UNLESS YOU MANUALLY TURN IT OFF
Wow, I am just wondering is the water inside the dishwasher warm or hot? Or is it cold? IF it is cold it could be that the unit is trying to heat the water usually to 120 degrees.If it is hooked up to a cold water valve from your house this could be the problem. Or it is the heating element,.
Posted on Jan 05, 2009
SOURCE: dishwasher seems to be clogged, wont drain
I had the same problem and it was solve by checking the food disposal were the dish washer is usually attached for draining, if you resently replaced the disposal it could be that the drain hold was never openned. I hope this helps
Posted on Apr 22, 2009
Frigidaire dishwasher fills but then the motor is not running for the wash cycle
Hey Gary, thank you for your inquiry!
From the information you have provided your Frigidaire dishwasher fills with water and then the motor will not run to complete the cycle. This could be an issue within the control panel or motor of the dishwasher. Which lights are flashing on the control panel of the dishwasher? Can you provide me with your model number as well? Once I have that additional information I would be able to assist you. -Matt
Apr 18, 2016 | Frigidaire Dishwashers
Why wont my frigidaire dishwasher wash?
There could be something blocking the drain. There are parts on the base inside the dishwasher that can be removed and then cleaned.
Nov 08, 2014 | Dishwashers
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
Upperrack water pressure
1)check the wash motor is freely rotating. 2)any jam in the wash motor.
Jun 03, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Lights on but wash
I assume you can't even hear water running. If that's the case, you may have a faulty or stuck water solenoid valve. Under your sink, there is a water line that connects directly to your dishwasher. That line is always on, so it's always under pressure, unless you turn off that valve under the sink. Therefore, something has to prevent water from flowing into the dishwasher, and that something is typically a solenoid valve. The solenoid typically gets it's power when you start your dishwasher. If the solenoid is stuck (most typical problem) a little gentle persuasion from the handle of a screwdriver may be all you need to unstick it.
Mar 24, 2010 | Frigidaire 24 in. FDB635RF Built-in...
Frigidaire dishwasher model GLD2445RFCO is making noise
I have the same problem with my dishwasher. If you remove the kick plate while it is running, There is an electric motor underneath. If you push up and pull forward on the electric motor, the noise will stop. I used a block to prop it up and the noise stopped. You may want to try it.
Jan 08, 2010 | Frigidaire GLD2445RFC Stainless Steel...
What does Frigidaire dishwasher timer code "Hd"stand for? It's not listed in the manual and I couldn't find it listed online. If it's just a "Hold" code (which is what I suspect) for extra washing time,...
“HO” or “Hd” means the dishwasher’s cycle time is being extended while it is heating water. At certain points in the wash cycle, the dishwasher uses hotter water to ensure a clean load of dishes. If it detects that the water is not hot enough, it will heat it.
If you’re seeing “HO” or “Hd” frequently, check the temperature of the water available to your dishwasher. It’s best to do this at the sink closest to it, allowing the hot water to run until it reaches its maximum temperature before you test it with a thermometer. For best results, water should be not less than 120°F.
Sep 20, 2009 | Frigidaire PLD2855RFC Dishwasher
Dishwasher leaks water from front
posible solution 1) use detergent whitch originally reconmended ( detergent for dish machine only,)
no regular dish wash detergent
2) check gasket and door allianment
Aug 28, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Jan 05, 2009 | Dishwashers
Frigidaire FDB1502RGC Built-in Dishwasher Logo
120 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
