Question about ESP LTD KH-602 Kirk Hammett Signature Electric Guitar - Black - B-Stoc
Hi i have the esp kh-602 and i am having some problems with my sound. My sound is too muddy especially in clean channel. It sounds as if i have some distortion on. I have a Washburn 30W amp and another guitar which sounds great with my amp
    Sergeant:
  • 195 Answers
Change the 9v battery and see what happens
Posted on Feb 24, 2015
2 Suggested Answers
Kree8iv
  • 192 Answers
SOURCE: Not getting enough distortion(esp ltd ax-260)
It's not your pickups. It would be nearly impossible to loosen a wire inside of your guitar by having even heavier than your amp head drop on it. It is most likely your volume pot. The post, if hit hard enough, can virtually distroy your pots. Another possibility could be your jack, al though considering where it's located on your guitar, it would be very hard to damage it by having something drop onto it.
There is little else that could be the problem. Hopefully you didn't damage your guitar too badly. If the guitar was in front of me, it would be a relatively easy diagnosis.
Fortunately, volume and tone pots are inexpensive, and if you're handy with a soldering iron (or you have a friend that is) it is an easy install with four to six solder points, depending on your configuration. I don't want to assume it's a stock setup, but when you take off the rear electronics cover, you will immediately see what configuration you have.
If you have possibly damaged the pickup bobbins (assuming you have the stock humbuckers in your guitar), you would be able to see the damage, It would either look damaged,or work correctly. As you know bobbuns are simply wound wire, and that's not easy to damage. Plus your strings provide a minimal amount of protection, unless your amp head slammed it very hard. Start by replacing the volume pot. Cheapest parts first. There is no way to test the pot with anything like a potentiometer, because there is virtually no voltage that passes through the pot. Additionally, unless you have active pickups, your pickups cannot be either. If you do have to replace your electronics, you can find a large variety and even upgrade your parts by searching eBay. The good thing is that you havce a guitar, and guitar parts are abundant, relatively cheap, and most people change out electronics just to achieve a different sound.
If you are so inclined, most good guitar shops will diagnose your problem for cheap and apply the cost of the diagnosis to the cost of the repair. Good luck, and I hope I have given you some information to work with.
Thank you for using FixYa
Posted on Jul 19, 2009
Hi, I have a Mackie vlz3 mixer. Last night I turned everything on and it was all distorted. I did some trouble shooting. It is definitely the board. Can you help. Ted
sounds like it could be dust or moisture ...Try cleaning the board and knobs and faders. this may help it may make it worse. Also while at it...check all connections...especially from board to amps. or to outboard gear. Could be a bad chord
Feb 22, 2015 | Mackie 1604 Vlz3 16 Channel Mixer
Is it the guitar or the amp
Hi, Sounds like you have a bad cable to your amp. Try swapping out the cable. If that is not the problem, The pickup maybe bad.
Hope that helps.
Jan 14, 2014 | ESP LTD MH417 7-String Electric Guitar
Well, my Ibanez TBX150R Tone Blaster Xtreme Guitar Combo Amp worked fine for the longest time, and suddenly after a show, every time I turned it on the "hot" channel it popped and banged every...
Sounds like a problem with the channel itself, if the clean channel works then its not the lead, input, guitar or the drivers. You have to be careful when opening up amps as some can hold a residual charge and there can be danger of electrocution.
I would recommend getting it looked at by a pro, it doesn't sound like an expensive fix.
Jun 30, 2011 | Ibanez Tbx150h Tone Blaster Xtreme Guitar...
I have 2 peavey sp 5 and a pwavey 2600 amp . i wanna know can i hook a peavey 118 passive sub to one of the sp5 and how would it sound?
You would send high as well as low to the sub and unless the sub had a built in crossover it COULD get muddy sounding. The specs SEEM to indicate the 118 DOES have a low frequency crossover so it SHOULD be OK... How would it sound? An 18 inch sub normally adds to the sound of a system... You MAY need to PAN over to send more power to the one side with the extra load on one side. Often people use two sub's... one for each side so it is balanced.
Jan 19, 2011 | Peavey SP5 2-Way PA Cabinet (800 Watts, 15...
I have a Fender Frontman 212r amp. The problem seems to be when I put the volume upto past 4/10 [40%] The amp gives out an awful crackling sound and power light etc flickers on and off. I have had the map...
When i turn on my 212R it turns on in drive channel. if footswith is plugged in, then it turns on in the clean channel, but after switching in drive it is impossible to switch it back in clean channel. What could be wrong? Swith position doesnt change anything and it seems like switch is OK.
Nov 27, 2010 | Fender Frontman 212R 100W 2x12 Guitar...
I have a jackson dinky DK2. what is happening is that on certain frets, like the 13th, 14th, 15th fret on the 2nd string (B string),when playing with slight drive or distortion, the note does not sound...
The frets MAY be worn or the neck truss rod MAY need adjustment, Neither of these is DIY unless yiu have experience in repoairing guitars. Since this is only on the 2nd string, inspect the frets for wear and the only DIY thing to try is to replace that string... DO that first !!!
Oct 15, 2010 | Jackson Dk2m Dinky Electric Guitar
I have a crate fxt 120. I 'll be playing in the #2 overdrive channel and it will automatically fail and go to a clean sound. Although it is not entirely clean. It sounds like 2 sounds combined. A loud...
A possible problem MIGHT be marginal switch contacts on the external foot controller cable. If you are not using the foot pedal, these contacts must maintain contact to keep the same channel selected.
Sep 15, 2010 | Crate Music
Have amp only 2 months & clean channel is muddy. it was clean when i bought it. its somewhere in between clean & drive
Test if the sound is clean using the headphone jack.
IF IT IS CLEAN in the phones, you have probablydamaged the speakers with excessive volume causing the voice coils to rub the pole pieces due to heating. If you can reach the cone either front or back GENTLY push on the cone and listen for ANY rubbing noise.
There are also electronic component problems that can cause this IF the headphone test is also muddy sound.
Apr 12, 2010 | Fender Frontman 212R 100W 2x12 Guitar...
Problem of marshall g80rcd, volume drop when i play
It sounds like your volume control is dirty. You will have to disassemble the amp enough to get access to the volume potentiometer which is soldered to the circuit board. There will be a square hole in it that you can spray some contact cleaner into the control. Use only contact cleaner as anything else could damage the control. Use a small squirt and rotate the shaft. If this doesn't solve the problem you may have to replace the control. While you have it apart, examine the solder side to make sure all the solder joints are perfect especially those on the controls. A bad solder joint can also cause the same problem. Before you take the amp apart unplug the power with the amp on and the volumes turned down. This will discharge the capacitors so it will be safe to work on. I hope this helps.
Oct 31, 2009 | Marshall Mg15dfx 15-Watt Combo Guitar...
Behringer UB1222FX Pro: Problem With Left Channel Cutting Out
Try cleaning al of the sliders using an electronics cleaning spray. Choose one that contains a lubricant as well. Dirty sliders can cause this especially at low volume levels. If that does not resolve the provblem, update this and we'll look further.
Dan
Apr 09, 2009 | Behringer Music
ESP LTD KH-602 Kirk Hammett Signature Electric Guitar - Black - B-Stoc Logo
136 people viewed this question
Top ESP Music Experts
Joseph Hoffmann
rhodesworks
Are you an ESP Music Expert? Answer questions, earn points and help others
