Question about HP Office Equipment & Supplies
Hp designjet 500 error code 11 11 - HP Office Equipment & Supplies
  • Anonymous May 06, 2009
    i have error code 11:11 in my printer
    & some times it shows :
    severe error : 0x4090001
    task : tMech
    file : mech.c
    line : 1295
    plzzzz give me the solution for this problem
    tnxxxxxxx
  • 300 Answers
SOURCE: hp designjet 500 error code
This error means the trailing cable is badly connected. Check the connections in the carriage and the board, reseat them.
Posted on Sep 18, 2008
SOURCE: HP designjet 500 the system error 21:10
I recently had this problem as well and it was the service station gunked up with a bunch of ink over the years. Remove the right hand cover of the plotter. Remove the 2 screws that hold the service station in place and slide to the right to remove. When removed, take off the small motor by the gears. The rest is all plastic, I removed the 3 screws and "popped" the two black parts apart and cleaned the spitoon, which is just a sponge. I then dropped the thing into the sink and poured dishwasher soap. Let it sit for about an hour and rinse. It is really really messy. Then put the whole thing back together again. If I recall, the motor was the only electrical component.
Use care and caution so as NOT to break anything and I recall that the only electrical part was the small motor by the gears.
This wasn't so bad and I spent about 8 hours just because I was exercising much caution. If you're more mechanically inclined on the first go, then I would guess about 1 hr to clean and another 1 or two for dry time.
This SOLVED my problem and WOW there was a bunch of ink over the years. Don't worry, that is what the "spitoon" is used for to soak up the excess ink. Well, if not maintained or replaced, then the ink gunks the insides rock hard as in my case.
A new station is about $160 bucks. If you have HP install then you are looking at a few hundred more on top of that. To me, it was worth it and if it didn't work then I just get a new one and I had nothing to lose since the plotter was getting past the 21:10 error.
Be sure to download the HP Service Manual online so you know how to remove the service station. It is just 2 screws. Without the manual, I probably would have taken off many more screws as I would not have thought the service station simply slid out to the right. The designjet is well designed and was glad that I found a service manual online.
Good luck and use caution,
Posted on Feb 15, 2009
  • 181 Answers
SOURCE: Error code 08:11 on hp
down load drivers
open google home page serch driver magician
update
open drivers click
driver version relese date
driver name copy serch google free down load
Posted on Oct 31, 2010
  • 51 Answers
SOURCE: hi how toresolve error code 08:11
I hope this will help its taken from the HP book the YZ are not relevant
good luck
Yours Ian
System Error: 08:YZ
Problem
Description:
Problem with the Front Panel.
Corrective Action: Try the following:
Switch the Power OFF from the back of the Printer and disconnect the
Power cord. Reconnect the power cord and power On the Printer.
Check that the Front Panel interface cable is not damaged and is
correctly connected between the Main PCA and the Front Panel.
Check that the memory module in the Formatter is installed correctly.
Check that the connections between the Formatter, the Formatter and the
Formatter are not damaged and are correctly connected.
Check that the Printer has the latest Firmware version. If not, update the
Firmware to the latest version.
Posted on Mar 08, 2011
  • 53 Answers
SOURCE: hp designjet 500. plotter is
On the DJ 500 the fault code points to the trailing cable. In 9 out of 10 cases you will need a new cable. The newer cables have a brown tefelon strip between the actual cables to increase their life, if this is not there then you really need a new cable.
Posted on Aug 30, 2011
71:06 error code
hello,
Description:
Out of Memory problem. This Error Code only appears in HP DesignJets 800 Series, or in the HP DesignJet 500 Series with an
HP-GL/2 card installed, when processing either a PostScript or HPGL/2 file.
Check the amount of RAM in the Printer using the Front Panel
(use the Printer Information utility aPage 4-27). If necessary,install more memory into the Formatter.
If the problem continues, try processing the file in the PC instead of the Printer (select Avoid out of memory in Advanced options in the Driver).
hope this helps
Mar 03, 2015 | HP DESIGNJET 500 InkJet Plotter Printer
ERROR CODE 11:11
Make sure the trailing cable is pushed all the way in (no bent pins) to both the back and to the printhead.
Push the carriage all the way to the right and turn the printer off and then back on.
Apr 02, 2014 | HP DesignJet 500 InkJet Printer
Hp designjet 500 with error code 02:10 can firmware be reloaded?
the error code gives :
Carriage failure. The possible cause could be:
The Carriage PCA is not compatible with the rest of the Printer.
The Carriage ASIC has problems initializing.
The +2.5V reference voltage generated in the Carriage PCA is out of range.
One of the Carriage ASIC's cannot be found within the Serial Bus that connects the Electronics Module to the Carriage.
One of the Carriage ASIC's did not respond to the Serial Bus that connects the Electronics Module to the Carriage Assembly.
Go To Below official Hp Printer Page For Your problem, DesignJet 500 error 02 10 Print Head HP Enterprise Business Community
Feb 24, 2014 | HP DesignJet 500ps (42 in.) InkJet Printer
Error 17:11 Hp 500 designjet plotter
error 17:11 no way related to DSJ 500.. Pl check
Dec 12, 2012 | HP PRINTER,DESIGNJET 500 42'' InkJet
Error 11
11:11 Error related to "Trailing Cable", my suggestion is experienced engineers only can handle other wise Formatter or Carriage assm PCB may got damaged...Vinay..
Jun 22, 2011 | HP DESIGNJET 500 InkJet Plotter Printer
Hp designjet 500. plotter is not working it only disply 11:11 . What is the solution of the erroe code please send me my email
May 05, 2011 | HP DesignJet 450c InkJet Printer
HP Designjet 500 System Error 71:06
Check the amount of RAM in the Printer using the Front Panel buttons.
install more memory into the Formatter or
of the Printer (select Avoid out of memory in Advanced options in the driver)
good luck.
Aug 03, 2009 | HP DesignJet 500 InkJet Printer
Hp designjet 500 error code 11:11
Sep 17, 2008 | Office Equipment & Supplies
929 people viewed this question
Seeker5211
Seeker5211
