Question about Kenmore 94052 Dryer
Kenmore model 94052 gas dryer is not getting heat. all lights are blinking.
  • Kenmore Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Apr 02, 2011
Kenmore gas dryer #41793142300 electronic start doesnt heat up
if you first have heat and then like 10 to 20 minutes later no heat you could have bad gas coils,on most gas dryers there's a plastic cap you can pop off on the front panel so you can look in and see the ignitor,if at first the ignitor glows orange and the flame lights then after a few minutes the ignitor glows orange and the flame doesn't light you have bad gas coils,they are located on the top of the gas valve,easy to change.part number 5303931775 go here and look at part 71
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-41793142300/0582/0151200/R0310102/00005?blt=06&prst=0&shdMod=41793142300
Mar 25, 2013 | Dryers
Lights flash will not work
Could you please describe the problem you are having a little better?
Oct 28, 2012 | Kenmore 94052 Dryer
Kenmore gas dryoer model #11073912100 not getting hot, all vents cleaned out, still won't work. could it be pilot light?
heatman101;
Sep 11, 2011 | Kenmore 74112 Gas Dryer
Hi, I have a Kenmore gas dryer model 417. I can't
Sounds like the coils on the gas valve are bad.
May 26, 2011 | Kenmore Dryers
Kenmore gas dryer model number 111.76712693 no heat coil wont light up do you think its the igniter sabrefan29@yahoo.com
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 23, 2010 | Kenmore Dryers
Kenmore Dryer Model 417.92142101 does not heat up. It looks like the element is getting hot but the gas does not light
Hi, Hey, that thing can get red hot and still not be working right... If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 20, 2010 | Kenmore Dryers
Hello, My Kenmore 70 serie (model 110.72712101), will not heat up. Cleaned filter and exhaust vent. Any suggestions will be of great help. Thanks!
The ignitor is probably bad not aloowing the gas valve to come on and ignite the gas to heat the dryer. The ignitor is a flat bimetallic element that heats up when the dryer is turned on to light the burner to heat the dryer. It is usually located in the lower left section of the dryer near the burner assembly. It has two wires usually white going to it with a plug in connector on the end.
Jan 18, 2010 | Kenmore 73952 Gas Dryer
Kenmore dryer Model #6507923 Gas sometimes won't
You may have a bad thermocouple. The thermocouple senses the heat from the flame and "tells" the control unit that the flame has lit. If it is sending no signal, the control will think it didn't light and shut off the gas to prevent an explosion. Good luck.
Jan 03, 2010 | Dryers
Need the manual to understand operation, problems with drying
84052/94052 is the stock number and 417.94052500 is the actual model number
How long did you let it run on sensor? Some models may need to sense for a while before they decide to start heating.
The knob can be turned either way
Manual: http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0502104.pdf
Sep 02, 2009 | Kenmore Dryers
Kenmore gas dryer
That model does not have a pilot light.  It has an electronic ignitor.  If it is not igniting, either the igniter is not getting a signal to ignite, the igniter is burned out, or the gas solenoid is broken.  Probably the igniter is burned out.  It is item number 3018 at RepairClinic.com.
Oct 20, 2007 | Dryers
Dryers Logo
235 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
