Question about Refrigerators
Coil was bad stopped up. Cleaned thouroughly. Let run last night and froze up again. Has proper coolant level of 5 ounces. Compressor pulling about 1 amp. Could it be compressor bad or chance of bad defrost sensor.
    Sergeant:
    Champion:
  • 202 Answers
Hi.... sounds like have a bad defrost time and sensor
Posted on Apr 02, 2011
    President:
  • Refrigerators Master
  • 2,118 Answers
What's the brand name and model number?what's freezing up the back inside wall of the freezer?if so you have a defrost problem.get back to me and hopefully we can fix your fridge.
Posted on Apr 03, 2011
I have a ffus2613lp. Yesterday the alarm started going off with the doors closed. The inside temperature raised to room temperature. I pulled it out, cleaned everything, including compressor/coils. ...
Good Afternoon Friend,
I understand the Hi Temperature alarm was going off on your Frigidaire refrigerator, model# FFUS2613LP, and the temperature was room temperature. I also see that you pulled out your appliance and cleaned everything, including the compressor and coils. You turned your refrigerator back on and it froze a cup of water before you went to bed. However, when you woke this morning, your refrigerator was back at room temperature. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why it keeps warming to room temperature. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire Refrigerators
Coca cola true glass door merchandising cooler (refrigerator) turned warm over night. I replaces the relay and capacitor and have eliminated those as possible causes. I assume it must be the compressor as...
Dusty compressor won't hurt. Dirty condensing coil can burn out the compressor. Supco makes a 3 n 1 start kit with very easy instructions, be sure to remove cap and external overload, this may kick start the compressor. If this fails then your compressor is bad, clicking inside is the overload. If you have the proper tools, go for replacement. Vacuum pump, gauges, scale to weigh in the ounces of 134a listed on the model number label, new liquid filter is a must, access port for low side if not present etc, etc. good luck.
Oct 29, 2013 | Refrigerators
Model GSI-26 suddenly stopped cooling
It sounds like your compressor is having a hard time starting. Take your model number to an appliance parts store and ask for a compressor start relay. It plugs directly into your compressor and is easily replaced. Remember to unplug the refer first.
Dec 17, 2012 | Frigidaire Refrigerators
Icebox not cold
Hello - From what you have described it sounds like you might be experiencing some form of sealed system issue or a bad door seal. This can include the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines not at the correct levels to properly cool. If the compressor is running, humming, or even a little warm then that is typically normal. However if the compressor is running hot, then it is over working and the issue could be before the compressor in the evap fan, coil or coolant lines. When was the last time you cleaned the condensers? You may do so by removing the toe grille and use extended vacuum attachment and condenser cleaning brush to remove dust buildup from condenser coils usually located on the left side underneath. If you hear the compressor running and if it is providing warm air then that means it is operating correctly and the sealed system is removing heat from the cabinet. Fan motor/evaporator may be the primary issue. However, if you do not hear the compressor and the unit is blowing room temperature then the unit may possibly have a sealed system leak, faulty compressor or overload relay. Try checking if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check the door from closing then replace the gasket. If any proves to be ineffective, you would need to contact your manufacturer and then a professional to move forward accurately.
Oct 27, 2012 | Frigidaire FRT18FS6C Top Freezer...
Stops cooling unplug replug starts up again
Hello Tana - Freezer might be experiencing some form of sealed system issue or a bad door seal. This can include the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines not at the correct levels to properly cool. If the compressor is running, humming, or even a little warm then that is typically normal. However if the compressor is running hot, then it is over working and the issue could be before the compressor in the evaporator fan, coil or coolant lines. Trying checking if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check the door from closing then replace the gasket. If any proves to be ineffective, you would need to contact your manufacturer and then a professional to move forward accurately.
Oct 04, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My Kenmore model 596 doesn't stop running. I've adjusted the temperature controls all the way down to level 1 and it still runs constantly. I've also made sure it is level and have cleaned the front...
It is probably low on refrigerant and has a leak... If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 22, 2011 | Refrigerators
My A/C was serviced last week and it was fine until last night when the cooling is not enough again
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 15, 2011 | LG Heating & Cooling
9-10 year old Frigidaire Gallery FRS26ZSH refrigerator stopped cooling as only the fan was running and not the compressor. Cleaned the lower coil and fan of a small amount of dust. The unit worked for 1-2...
might be your compressor relay gone bad. if the condenser fan was running and no compressor that could be the case. Also could be a bad compressor. you could try installing a 3in1 start kit. cost about $30. if doesn't start with that then compressor is kaput.
Jun 27, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refigerator not working properly
the compressor is out of coolant/freon.u should not run it if the compressor is too hot to touch
Aug 02, 2008 | Kenmore Elite 21086
Refrigerators Logo
369 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
