Question about Frigidaire Refrigerators
Compressor will not come on. Fan and light do come on.
  • Frigidaire Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 02, 2011
Noise from the refrigerator...fan or compressor? It cools and freezes perfectly fine.
Most likely the condenser fan. If the compressor was making a lot of noise, it probably wouldn't cool sufficiently. When the compressor is running, open the door and listen for noise from the inside fan too. A light machine oil will fix a noisy fan.
Sep 26, 2015 | Refrigerators
My kenmore fridge with bottom freezer, model#596.785.83801. Both fridge and freezer won't stay cold. Fan on and lights are on. Help!!
Check to see if the compressor in back is running. It could need a new compressor start device. If it is running it could need a new compressor. The compressor cooling fan could be stalled and the compressor is overheating.
Sep 26, 2014 | Refrigerators
Ac fuse blowing, in 1996 isuzu rodeo
Disconnect wire to Air Conditioning Compressor and connect normal test light to wire, from engine harness(body)side. Fit new fuse and try air cond controls and switch, test light should light up and hopefully fuse wont blow indicating short in compressor clutch windings(replace compressor). If fuse blows while doing this test compressor might be ok and fault short some where else, fan speed resistor block, fan or control/switches, wiring.
Jul 19, 2011 | 1996 Isuzu Rodeo
The refrigerator has quit working. Lights come on and fan appears to be running. Not cooling
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If it's iced up really heavy you have an auto defrost problem. Melt the ice with a hairdryer and check the defrost system.
Oct 12, 2010 | Maytag MSD2756G Side by Side Refrigerator
The Unit does not cool. The fan, lights, etc run
check if the compressor working if it working and you get frost in your freezer back panel then your problem is in your freezer area but if your compressor not working then and the fan next to it working then the starter unit for the compressor is bad....let me know if you need more help
911service today . com
Jan 01, 2010 | Whirlpool ES5FHAXS Side by Side...
The lights are on in the refrigerator and freezer, but neither unit is cold. The thermometer on the refrigerator registers 55 degrees. Why is it not cooling??
First, make sure the compressor is running. It is underneath the refrigerator body. If the compressor is running, and you still don't have cold air, check the compressor fan. This should be close to the compressor. This fan draws air across the coils and removes heat from them. The compressor and fan must both be operating properly to get cold air.
Oct 18, 2009 | Refrigerators
Refer warming / no compressor / no fan
If the fan doesn't work , the compressor overheats and shut off by the overload protection.I would replace the fan which will cost no more than $30.
Sep 19, 2009 | Refrigerators
Compressor and Compressor Fan Not Working
Rotate the dial on the defrost thermostat, a big click is when it goes into defrost, a little more and it should turn the compressor back on. By overload protector, do you mean the one under the compressor cover?
May 03, 2009 | Refrigerators
Lights on in frig and freezer but no compressor or fan running
Remove and test the fan. If it has failed the Compressor may not run.
May 03, 2008 | Amana ABB1921DE Bottom Freezer...
Refrigerators Logo
51 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
