Question about Encore Math Advantage Deluxe for PC
Need a compatability fix between Math Advantage Deluxe Edition (no year) and Windows XP Home Edition. After loading the disks and accessing program icons, I get a screen that indicates "script error: Handler not defined" and options to QUIT or CONTINUE for all icons. I've used the "compatability wizard" to simulate a Windows 95 environment but the software continues with the "script error" and won't link to the next lecture/section after the Chapter and section have been identified. How do I correct this issue?
2 Suggested Answers
  • 381 Answers
SOURCE: I have an old version
If you are using Windows 7, try the compatibility mode Right Clic (use the right button of your mouse )on the execyute file EX: setup.exe or Install.EXE or witch ever the file that start your program first and chose "Property" In that box clic on the compatibility tab tic the box execute this program.... to activate the scroling menu drop it down and chose the compatibility that your program required (Windows XP or VISTA, clic at the botton "Privilege" "Exécute this program as an Administrator Clic apply and clic ok try to install again
Posted on Aug 03, 2011
Is there a version of Bible Library Edition compatible with windows 7
If a program cannot be run under Windows 7 because of compatibility issues, which is the case with Bible Library Deluxe Special Edition 5.1, you have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. You can find more about this Compatibility issue on Microsoft website:
Nov 25, 2010 | ValuSoft The Bible Library Deluxe Special...
Is Quicken99 compatible with Windows 7 and/or XP?
The best way to install older versions of Quicken on Vista or Windows 7 is to run the setup program through the Windows Compatibility feature:
In Control Panel search for 'compatibility' that will bring up an item 'Run program made for previous versions of Windows'.
Select this and step through the process which will eventually show a list of all programs loaded on the system.
Select the first option 'Not listed'. This will then prompt you for a location of the program.
Click 'Browse' and select the location of the Quicken install program (either CD or disk).
Once found, select the Quicken install program and continue. This will the suggest that the installer run in XP mode. Click 'Next' to run the installer.
Aug 09, 2010 | Intuit Quicken Deluxe 99 for Windows...
I have a question the compatibility of a game called EVE. Is it compatible with XP Home Edition?
Getting older programs to run on Windows XP Your game should have compatibility info on the box or in the readme file on disc. Even if it was made to run on Win'98, you can change settings in WP so it will run.
Here are MS instructions to run a compatibility test:
To start the Program Compatibility Wizard, click Start, All Programs, Accessories, Program Compatibility Wizard.
You can also use this method:
You can set the compatibility properties for a program manually. The settings are the same as the options in the Program Compatibility Wizard.
To set the compatibility properties for a program manually
  1. Right-click the program icon on your desktop or the shortcut on the Start menu Or right click on the program Icon on your desktop.
  2. Click the Compatibility tab, and change the compatibility settings for your program.
note.gif Notes
  • The Compatibility tab is only available for programs installed on your hard drive. Although you can run the Program Compatibility Wizard on programs or setup files on a CD-ROM or floppy disk, your changes will not remain in effect after you close the program.
Nov 13, 2009 | Microsoft Windows XP Home Edition
When I start up Windows XP I get three error boxes each of them say: Rundll Error Loading C:windowssystem3whnoherd.dll Rundll Error Loading C:windowssystem32cryakfuvzxugjh.dll Rundll Error Loading...
Rundll.exe files are systems process directly related to your computer's Windows Registry All Dll files are a part of vast library that contains code and data that is shared by many programs. This helps to produce speed and memory efficiency in your operating system by reusing the same code or file to run many functions by various programs. An error occurs when program aren't allowed to access this code.
Now, if you able to access the XP in safe mode, You could go to :-
Start > Programs > Accessories > System Tools > Restore.
Select a restore point and it's all done.
Unless, the only User Fixable option is to Repair the Windows. Put the XP disk in tray and run Repair. Once repaired, it would fix the problem.
Let me know, if needed assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 08, 2009 | Microsoft Windows XP Home Edition
Contact Broderbund for support This problem was caused by a compatibility issue between this version of Windows and this version of PrintShop Deluxe. This program was created by Broderbund. Recommendation...
I used a 14 disk ClickArt 200,000 edition with my older computer. Now I have a new Windows 7 Computer. Is not this 2000,000 edition compatible with my new Computer.?
Feb 19, 2009 | Broderbund The Print Shop 20 Deluxe for PC
I just recently purchased a HP Laptop with Vista windows. I am having a problem downloading my older programs. I have a Quick Verse Deluxe 6, I like it very much and it won't download so I can use it. Can...
install or run the program in compatibility mode.
locate and right-click the program executable (if successfully installed in C:\Program Files\program_installation_directory\) and choose Properties.
click Compatibility tab and select your choice.
if this fixes the issue, you have the option to pay me instead. post back for more.
just kidding, happy new year
Jan 04, 2009 | Parsons QuickVerse 2005 Expanded Edition...
System Crash or Freeze
XP home edition should be very stable when install properly.. I suggest you scan for PC invalid registry.. below link might be able to help on this issue.
Good Luck!
Nov 05, 2008 | Microsoft Windows XP Home Edition
Restoring windows xp home edition
HI satisfier
provided his disk has a newer build version than your this should be no problem if his is older then you will receive the mssage that "a newer version already exists"
Oct 25, 2008 | HP Pavilion dv6000z Notebook
Dont have windows xp home edition disk..
Here's the link to Microsoft where you can get a replacement Windows software.
Mar 13, 2008 | Microsoft Windows XP Home Edition
3D Home Architect Home Design Deluxe 8
This program is not vista compatable, sorry. You will either need to create an XP partition and run it from there or use another product.
Jun 22, 2007 | Encore 3D Home Architect Home Design...
Open Questions:
See all Encore Math Advantage Deluxe for PC Questions
Encore Math Advantage Deluxe for PC Logo
70 people viewed this question
Top Encore Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
