Question about JVC HR-VP673 VHS VCR
Guide plus I recently switched over to Verizon for my cable channels and hook-up a dvd player. Now whenever I open the tv I can this "guide Plus menu" that says "no data found". How can I delete this menu from popping up. Thanks
  • 752 Answers
Are you sure this isn't coming from the tv (is it an RCA or GE?) and NOT the vcr? Either way you would access it in the Menu under Setup or Initial Setup.
Posted on Aug 05, 2008
How do i hook up a dvd player to my tv if i have cox cable? I dont know what channel to put my tv on. I know there has to be a way to watch a dvd without unhiiking the cable
Most DVD players have a coax input and output on them. But some newer ones don't. Assuming your does then you can run your DVD player to your TV with a coax cable you bet. Either on the back of the DVD player there will be a little switch or in the menu settings it will give you an option for channel 3 or channel 4. The same channel you select on the DVD player will be the same channel you will want to put your TV on. For the coax install run it from the output on your DVD player to the coax input on your TV. If you use a coax for cable too then just run you coax from the output on your cable box to the input on your DVD player.
Mar 20, 2011 | Samsung Televison & Video
Hooking up dvd player
I searched everywhere i could think of for a manual or a diagram of the back of the player with no luck - any chance you can post back a photo of the back of the dvd player, then we can easily talk you through what to connect to what and what cables to use. :)
Jun 27, 2007 | Oritron DVD600 DVD Player
Can't get video on vhs sound but no picture, is it broken
I had the same problem, so I took it back to basics. Hooked cable into VCR/DVD player and another cable from player to TV. S cable too, plus red/white audio. Plays DVDs on AV1 and VHS on Channel 3 on TV setting.
Jun 30, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Whenever I have an outage or disconnect the tv, guide plus needs to be downloaded again. How do I eliminate that problem of guide plus? I now have a cable box from Comcast that connects from cable from...
Sharp TV, Guide Plus Download problem
Solved by using Sharp TV Remote: Set Up, Guide Plus, Enter 00000 (zip code),
No more Guide Plus downloading!
Jan 02, 2010 | Sharp 36K-X2000 TV
Using RCA P61939 without Guide Plus
Guide plus still works even if you don't have the wand hooked up. In the setup section of the guide plus there are several questions that must be answered properly or it won't function as you would like. It maybe labeled as options as well. Thanks
Oct 02, 2009 | RCA P61939 61" Rear Projection Television
Rca f36648 & rca HOME THEATER
Have you tried just hoooking up the DVD player by itself? Is the DVD player output setting correct? Also, make sure the "video input" is set for the correct channel that you are viewing (i.e. Channel 3).
Jul 31, 2008 | RCA F36648 36" TV
Cant use all cable channels
Go to SET UP TV, press yes for the following question. SET UP GUIDE PLUS. This will take you to another GUIDE PLUS SET UP SCREEN. Answer the questions as they appear. The important question is going to be. DO YOU HAVE CABLE? Answer yes to this questions. Answer the rest of the questions as they appear. Then go back to MAIN MENU, select channel, then select auto channel search. This will find all channels that are offered by your cable package.
Jun 08, 2008 | Proscan PS32500 32" TV
RCA Gold Plus+ Guide problem
go to menu and find the automatic set up of your channel
May 27, 2008 | RCA 32F531T 32" TV
How to hook up my dvd/vhs combo to my tv with out the red,yellow and white cables
go to radio shack and get the red and white and yellow cords.
Dec 23, 2007 | Televison & Video
JVC HR-VP673 VHS VCR Logo
67 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
