My Craig 15" TV has
  • 6,993 Answers
There are different causes to this type of problem;
ONE: If coming from the loudspeakers you may have a power supply problem wherein one of the filter capacitors is allowing 120 cycle ripple to get into the audio amplifiers. If the sound goes up and down with the volume setting, it is in the lower B+ voltage area that feeds the preamplifiers to the audio amplifiers. If it does not go up and down with volume settings, it is in the main power supply - but the repair problem is about the same. The replacement of the caps is not much; mostly labor. The cap parts are only a few dollars.
TWO: If the buzzing sound is coming from within the unit itself it is likely to be a loose transformer. They are mounted on the metal chassis and sometimes one of the mounting screws will work loose and allow it to vibrate, causing a resonating buzz to make the chassis into a sounding board. The problem is solved by properly mounting the transformer. No parts are needed, only a remounting of the transformer screws that hold it down. This is something your depressed husband may be able to do by himself if he knows which end of a wrench and screwdriver to hold (I can give some detailed instructions if you think this is the problem).
THREE: AND, there are other possible causes of this noise you are hearing. As you may realize it is not possible to predict exactly when doing it from a long distance without seeing the unit and only going by your description of the symptoms. For example, it is possible there is a buzz coming from the video signal processor into the audio; it happens to some extent in some sets, and would require the replacement of some parts in the IC chip that handles those functions, but your description didn't sound like these symptoms.
Lastly, please note that before you do any of the above, just do a hard reset on the tv; unplug the power cord for 4 hours. That will reset the internal software codes and could, although not highly likely, restore the system if it is something in the video and audio processing functions.
I hope the above points you to the right direction in solving this problem.
Good luck.
Posted on Apr 02, 2011
No signal, bought an antenna still no signal
i have a craig tv bought it six months ago it was working fine until i put it on today now it saying no signal i tired everything.it goes on but i cant get any pictur or sound
Sep 20, 2012 | Craig CLC501 15 in. TV
The sound on craig tv wont work
With your remote go to menu. Go to audio and make sure your speakers are turned on. murf427
Aug 30, 2012 | Craig "15"" High Definition Lcd Color Tv...
Hello, I have a Craig CLC503 TV as well and having trouble getting my cable channels and clear pictures. Any help with this would be appreciated.
First, change the input to some other you are sure works well and see. Then if the problem persists, this might need attention by a qualified service technician.
Jul 24, 2012 | Craig CLC501 15 in. TV
I need a remote for my craig tv clc501
Try website like Remotes.com to buy the tv original remote or a very closed compatible one.
Sep 24, 2011 | Craig CLC501 15 in. TV
COMO PUEDO PROGRAMAR LOS CANALES DE MI TV MODELO CLC501
como puedo programar los canales de la Craig CLC 501 TV
Jul 17, 2011 | Craig CLC501 15 in. TV
Craig 15" lcd tv Model
YES.
THE-MANUALS.COM/CRAIG- CLC501 -TV- MANUAL
ITS A FREE DOWNLOAD...
Jun 06, 2011 | Televison & Video
Need a manual for Craig 13in HDTV. CLC503
You can download and print the instruction manual for Craig CLC503 in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Thanks for using FixYa.
May 09, 2011 | Craig CLC501 15 in. TV
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
Electro Med Services...
