Question about Maytag Dishwasher
Ge profile dishwasher clogged from using two different types of Cascade detergent.
  • Maytag Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on Apr 02, 2011
PDWT300R10WW
Check the pump and filter for blockages as the dirty water may be not draining properly. A mix of detergents is ok. Run a prewash with the unit empty and see if the water is still greasy
May 09, 2012 | GE 24 in. Profile PDW9880JSS Built-in...
I recently purchased a insinger 18-5 dishwasher, what type of detergents should I use ??
Follow the steps below to ensure proper dishwasher detergent selection and usage.
Use only powder, liquid or tablet detergent designed specifically for automatic dishwashers. Any other types may cause a sudsing and as a result, poor wash performance and possibly suds and water on your kitchen floor. GE recommends either Electrasol®, Cascade® or Cascade Complete® detergents.
Use the right amount of detergent for the job. Soft hot water requires less detergent - perhaps a quarter of a cup in the main cup. Very hard water requires a full main cup and a full open cup to get good wash performance. Conditions between these require judgment. Use enough to get the job done, but don't use more than you need.
Too much detergent in very soft water will cause etching of glassware. This is a permanent clouding of the glass. If you experience this condition, use less detergent.
Keep your detergent fresh and dry. Store the detergent in container away from moisture to prevent lumps. Do not put detergent in the cup until you are ready to run a cycle. If powder detergent gets old or lumpy, throw it out; it will not clean effectively. Liquid detergents do not age.
As a rule of thumb:
Harder water requires more detergent
Cooler water requires more detergent
Softer water requires less detergent
Hotter water requires less detergent
Jun 15, 2011 | Singer Commander 18-5 Dishwasher
Soap residue remains on dishes after wash cycle is complete. Spoke to GE today & was advised that Cascade changed their formula a few months ago & many people are having the same problem. ...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Nov 10, 2010 | GE Profile PDW8400J Built-in Dishwasher
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
heatman101
Nov 09, 2010 | General Electric GE Profile Dishwasher 24...
Detergent dispenser doesn't empty completely
The detergent reservoir should pop open allowing the wash water to "wash" the detergent clean. It sounds like your DW is not "spraying" with full force. From your description, it sounds like your water pump is malfunctioning OR your drain is clogged with food and the water flow is restricted, because the wash water is the original rinse water from the first cycle and it recirculates. Check and make certain your drain is not clogged before you call the repairman or replace the machine.
Apr 19, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE Profile dishwasher with ''SmartDispense'' technology is clogged
Check the reservoir hose , and unclog it if necessary. You may need to disassemble the reservoir/dispenser to solve the problem.
Use to the diagrams below:
Apr 06, 2009 | Dishwashers
Detergent caked in holder after running a cycle, using Cascade
Try this before you jettison your current dishwasher. Yes, it is possible that the wash motor is getting weak, beginning to fail but:
Buy and use a box of brand name box of detergent powder Electrosol or Cascade. Stop using the generic powder and never use a gel or tablet in a dishwasher.
You will be amazed how how much better the detergent dissolves and the DW cleans.
Good Luck!
Mar 31, 2009 | GE 24 in. Profile PDW7800 Built-in...
Smart dispense detergent dispenser
There are two different types of dishwasher detergent types, bleach based and enzyme based.  The owner's manual states that if the two are ever mixed that the mixture will congeal, clogging the dispenser.
I don't know exactly how to safely remove the detergent that is in there, perhaps a wet/dry vaccuum.  There is likely a service mode for the dishwasher if it has electronic buttons, in the service mode you could activate the pump that dispenses the detergent.  Use caution, the thicker the clog, the harder the pump has to work and it may fail.  Hope this helps.
Nov 08, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
Not draining
Are you sure your drain system is not clogged or restricting water flow ? When you say youtook off the hose off under the sink and it seemed to be lots of water running on the rise cycle .. that suggests that you may have a restriction after the drain hose in your house drain system. ...
Some other considerations..
To minimize the possibility of electric shock, unplug this appliance from the power supply before attempting any maintenance.
  • Some water, usually one to two cups, remaining in the bottom of the tub is normal. However, if water is covering the bottom of the tub, the dishwasher is not draining properly.
  • Check for paper or large objects covering or blocking the sump area in the rear of the tub.
  • Make sure that the right type and amount of detergent is used: Using the wrong type or too much detergent can cause sudsing that can prevent the dishwasher from draining. Only detergent specifically designed for automatic dishwashers such as Electrasol®, Cascade® or Cascade Complete® should be used
Hope this helps you...
Sep 03, 2008 | Dishwashers
Maytag Dishwasher Logo
182 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
