My kenmore 80 series washing machine will not always drain out on the spin cycle and sometimes when it does there is dirt in the tub under the clothes. why?
  • Washing Mach... Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Apr 02, 2011
Kenmore series 80 washer do not drain enough
It's normal to hear some water in tub, it isn't normal for the rubber wheel to be hard to turn, you need to replace the pump, they are much cheaper on ebay
Sep 27, 2017 | Kenmore Washing Machines
Kenmore Washer Series 80. The cycle stops before
check to see if you have it set on drip dry
Feb 06, 2010 | Kenmore Washing Machines
Kenmore 80 Series washer will not spin; MOD#110-22882101
you need to replace the motor coupler between the motor and the trans.,let me know if you need more help,mike
May 26, 2009 | Washing Machines
Kenmore 80 Series washer wont spin or drain at end of cycle
POST ME THE MODEL NUMBER. AND ALWAYS POST MODEL NUMBERS WHEN NEEDING ASSISTANCE PLEASE:)))
Apr 17, 2009 | Washing Machines
Washer over flows
Dear Cbelton
please inspect the following
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
  • please rate this solution.Thank You..
    Dec 16, 2008 | Kenmore 24032\24036 Top Load Washer
    Water after spin cycle
    remember ,,the tub has a balance ring on top..and that filled with water,,,if your getting water at bottom make sure your drain hose is at proper height,,,+theres always water between the pump and the drain hose no unit can drain 100 per,,
    Nov 05, 2008 | Kenmore 24902 Top Load Washer
    No spinning
    95 percent of the time this is caused by a defective lid switch.
    Oct 19, 2008 | Kenmore 24032\24036 Top Load Washer
    Washing Machines Logo
    118 people viewed this question
    Top Washing Machines Experts
