Question about Jandy Aqualink Pda Ps4 Wireless Handheld Remote Control System Pool and Spa Combo
My jandy pda system resets itself to default settings (turns off pump etc..)and date/time to 09/08/06? I reprogram and it works for a few hours. What do I do to fix?
  • 3 Answers
How about the battery in the controller box? The 9v battery keeps the settings in its memory - not the PDA.
Posted on Jun 08, 2011
Jandy PDA PS4 Firmware 4.1 Date reads 10/10/14 "SAT"should be Friday.
go into system setup then find time and date reset to correct if every time the power goes out it is wrong you need to replace the battery backup either a 9 volt or a nicad on back of PCB board
Oct 10, 2014 | Jandy Aqua Link RS PDA-P4 - PDA for...
Set a program for pool mode on
go into set up then programming highlight the item you want to make a program for set on time and off time if you want it to run continuously start time 2:00am to 1:59am it will go off for 1 minute then start back up
Apr 13, 2014 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Jandy pda time keeps resetting back to default and the spa blower will turn on and off by itself
go to system set up see if programs if you have a 4 button spa remote disconnect and see if it goes away sometimes they get water in the wiring no programs are stored in the PDA
Jun 09, 2013 | Jandy Aqualink Pda Ps8 Wireless Handheld...
Jandy PDA not showing water temp
sounds like a loose wire on the red 4 pin connector to get water temp filter pump must be running lost of times closing crews disconnect that stuff if that doesnt work give me more info
Mar 02, 2013 | Jandy Aqualink Pda P8 Wireless Pool or Spa...
The Date and Time change back to installation date and programs no longer work
if you have a 4 button spa side remote unplug and see if it continues its called ghosting if so replace controller
Dec 10, 2012 | Jandy Aqualink RS8 Pool/Spa Combo Control...
Can't figure out how to set the LOW speed part of the 8 hour cycle
the 2 speed pump uses 2 auxilaries set low for low hour and high for high hours have to go into set up and assign them
Sep 28, 2012 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Jandy pda 8265 not working
Have you replaced the 9v battery in the control box recently?
Sep 30, 2009 | Jandy AQUALINK RS TELELINK KIT
Jandy Aqualink display reads "waiting"
System locked up. Handheld is frozen at WAITING screen means Microprocessor is locked.
Here is what you do:
1. Turn off power to the system (control box)
2. Disconnect battery at the Power Center (9volt battery in control box/cross tip screwdriver required)
3. Turn on power
4. Reconnect the battery
5. Reset time and date on PDA.
6. Thank me.... BadWally sends
Aug 20, 2009 | Jandy AQUALINK RS TELELINK KIT
I have a jandy aqualink RS PDA. It will not
System locked up. Handheld is frozen at WAITING screen. Microprocessor is locked.
1. Turn off power to the system.
2. Disconnect battery at the Power Center and turn on power.
3. Reconnect the battery and reset time and date.
4. Thank me.... You are welcome... BadWally sends.
Jul 03, 2009 | Jandy AQUALINK RS TELELINK KIT
Jandy Aqualink Pda Ps4 Wireless Handheld Remote Control System Pool and Spa Combo Logo
706 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
