Question about Bose Acoustimass 3 IV System
Stuck terminal tab
The terminal tabs where you connect the speaker wires into on both my acoustimass 3 modules is stuck in the closed position. How can I re-open them?
I would appreciate any help.
thanks
  • 1 more comment
  • Anonymous Sep 13, 2008
    I am having exact same problem.
  • lhauge Nov 15, 2008
    A terminal tab is pushed in, will not pop back out, and the wires will not stay inserted as a result.
  • byron twain Mar 01, 2009
    Is there a product like WD 40, only for stuck terminal tabs. Mine are stuck on Bose Lifestyle 8 Series 11 .
    New Friend:
I was able to pry the stuck tab open with a small flat head screwdriver. After a number or repetitions of that process, plus some repeated pushing on the tabs, they started working normally.
Posted on Nov 27, 2014
3 Suggested Answers
SOURCE: accoustimass 15 speaker problem
more than likely your speaker terminals are broke. Those type of terminals have springs inside to push them down onto wires. more than likely the terminals will have to be replaced.
Posted on Aug 26, 2008
Ironfist109
  • 3018 Answers
SOURCE: Is there a product like
Never use WD40 or any other petroleum product on anything electronic including the terminals. You may have to remove that terminal and repair or replace it. Good luck.
Posted on Mar 06, 2011
How to connect denon AVR 1513+Bose Acoustimass 5
Plug the speaker wire from the speakers themselves directy to the receiver or you can plug them into the acoutimass module and the module into the receiver using speaker wire.12_16_2013_3_46_09_pm.gif
Feb 19, 2013 | Denon Avr-1513 5.1 Channel 3d Pass Through...
How to put together a double cube bose speaker
The Bose speakers with the cubes and bass module are all interconnected with a proprietary cable available from Bose, if lost you get a replacement by called 1-800-444-BOSE.
When you connect the speakers all wires run from the receiver to the base module first, then out to each of the speakers. All terminals on the bass module are labeled.
The Bose cubes are all identical and can be used in the front or back positions.
Try to keep them at ear level or aimed at the listening position for best sound.
May 17, 2011 | Bose Acoustimass 15 System
Is there a product like WD 40, only for stuck terminal tabs. Mine are stuck on Bose accoustimass 3 speakers . A terminal tab is pushed in, will not pop back out, and the wires will not stay...
Mar 06, 2011 | Bose Acoustimass 3 IV System
Have this Bose system connected to my Yamaha a/v receiver
If you have it literally conencted the way you say not much good will happen.
The speaker OUTPUTs for the Yamaha feed the INPUTS on the Acoustimass Module then the satellites branch out of the Acoustimass Module's OUTPUTs.
Acoustimass module
Bose® recommends putting your Acoustimass module at the same end of the room as the
television monitor. To prevent interference, keep the module at least 2 feet (.6 m) from the
television.
• You may hide the Acoustimass module behind or under furniture, but do not block the
opening. Be sure there is at least 2 inches (5 cm) between the opening and any surface.
• If the opening faces the wall it increases the bass; if it faces away it decreases the bass.
For the most bass response, place the opening 2 to 3 inches (5 to 8 cm) from a wall or
corner.
• Stand the Acoustimass module vertically or horizontally (Figure 6). To stand it on the
cable connection end, remove the cover by gently pulling it away
Move the sub closer to a wall or corner to increase the bass.
This is a SYSTEM and as such is not designed to be pieced out or separated. I don't recommend that you try it that way. I doubt it will improve the sound.
Apr 30, 2010 | Bose Acoustimass 10 III System
Not getting spar to wires
check ignition fuse.if okay.remove one of coils connectors using a test light .turn ignition key to on position .terminal 1 on the connector to coil is the first to left with the locking tab up. then remove the ignition module connector terminal 4 is 12 volt supply.4 terminal to the right with lock tab up.connect test light to ground.take the pointed end touch both the terminals for 12 volts with ignition on position.if getting 12 volts.you have PCM PROBLEMS OR CRANK POSITION SENSOR..IF GETTING NO 12 VOLTS YOU GOT A BLOWN FUSE OR GROUNDING PROBLEMS.
May 25, 2009 | 1999 GMC Yukon
Left Channel Not Working.
Has it ever worked?
Try this - connect one pair of its speaker wires at a time and test it. Watch the polarity.
• Make sure all cube speaker arrays are connected to the proper terminals according to their
position in your room.
• Check to be sure all wires are connected to your surround receiver with the proper polarity
(+ to + and – to – wires). Incorrect wiring can result in a total loss of module output.
• Correct any wiring problems before you plug in your receiver and turn it on.
How do you know the receiver's Left channel isn't the fault? Sounds like a source issue.
Jan 04, 2009 | Bose Acoustimass 16 Speaker
Subwoofer blows internal fuse when receiver is turned on
Has it ever worked?
Dec 12, 2008 | Bose Acoustimass 16 Speaker
Do I have to have a powered bass module to make the cubes work?
Your Acoustimass 5 is a powered sub with powered surround speakers. If you are not getting sound output, the internal fuse may be open and you will have to replace it. Bose used a heavy multiple output cable terminated in a miniature DIN plug to connect speakers. You may be able to find one on eBay.
Apr 17, 2017 | Bose Acoustimass 6 III System
Speaker wire tabs for neg/pos connections in rear of speaker
The usual spring-loaded speaker terminals can be bought from constructor supply catalogues or salvaged from broken or obsolete equipment.
It should be possible for anyone with a moderate practical aptitude to replace the terminal if the original is beyond repair. It is a largely intuitive process.
Mar 14, 2017 | AAD E-30 Main / Stereo Speaker
Accoustimass 15 speaker problem
Jul 18, 2008 | Bose Acoustimass 15 System
Bose Acoustimass 3 IV System Logo
738 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
