Question about Zodiac Baracuda G3 Automatic In Ground Pool Cleaner
My barracuda is not moving and i fell is not pulsating eather why?
  • 640 Answers
If your pool cleaner is moving slowly and not pulsating, there are a couple things that you will want to check and/or adjust. Make sure that the main drain is closed. It is a common problem with these pool cleaners not operating correctly if the drain is not closed. Use your flow gauge to make sure that there is adequate flow. Poor water flow through the cleaner can cause these problems. Backwash the filter and clean out any skimmer baskets. Clogs can cause loss of suction and prevent movement. Make sure that the diaphragm is not damaged. Check for hose leaks and air entering the line at all connections.
Posted on Apr 13, 2011
Why does zodiac g2 pulsate in one spot suction on 1?
increase the flow through the vac by closing off the relief
Apr 24, 2014 | Zodiac BARRACUDA G3 IN-GRND CLEANER
2002 chevy silverado 1500 2 wheel drive when appling brakes it pulsates and fells as if there is no real braking
The brake rotors are warpped [ the pulsation ], The pads may be worn out, and-or have a frozen caliper causing the loss of braking power.
Jan 24, 2011 | 2001 Chevrolet Silverado 1500
Water circulation is OK. barracuda g3 does not pulsate, hoses are clear
If the cleaner is not pulsating, then either you don't have enough suction or the diaphragm is bad or clogged. Very common to have a **** or tear next to or just below the plastic retaining ring that holds the diaphragm on the inner cassette tube. Also check and make sure there are no holes or breaks on the hoses. Your cleaner should have come with a suction gauge that you put on the end of the hose in place of the cleaner. It's a clear tube with a spring and plastic piece inside that indicates high, low, or normal. Use this to check your suction. If you don't have one see if you can get one at the local pool supply house, they may even have one you can borrow. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
Sep 30, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
My baracuda is not moving....I took it apart and nothing is caught inside. The filters arer clean. I adjusted suction as well with no results
Is it pulsating? If not then either you don't have enough suction or the diaphragm is bad or clogged. you said it was not clogged so check closely for tears. Very common to have a **** or tear next to or just below the plastic retaining ring that holds the diaphragm on the inner cassette tube. Also check and make sure there are no holes or breaks on the hoses. If this doesn't solve the problem let me know, these cleaners are very straight forward. Good luck!
Sep 17, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
My baracuda is pulsating and moving but surfaces
The control should be below the water, and if you cut the suction down that should help with the cleaner.
Dec 22, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Barracuda Zodiac G3 is not pulsating. It's got
either some debris is caught in the diaphragm or it's deformed enough to render it inoperable. Unthread the nut just above the handle and pull it apart, then push the white tube downward until it comes out of the bottom of the unit. Inspect the diaphragm to see it there is any debris in it or if it is deformed. Usually the diaphragm has a uniform opening, if the gap is wide, it will not function. The most common problem is that the diaphragm needs replaced. Hope this helps.
Nov 16, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
It pulsates; but pretty much stays in one spot
check your diaphram for a tear near the plastic ring that hold it on the tube
Jul 25, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
G3 is not moving, but has suction? Please advise.
I had the same problem. come to find out there was somehting stuck in the diaphram. (a piece of mulch). Once I removed it, everything worked fine. Take your Barracuda apart and check the diaphram for blockage.
Mar 21, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Zodiac Baracuda G3 Automatic In Ground Pool Cleaner Logo
999 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
