Question about Car Audio & Video
It was laying on the workbench in my kids stole the fusesWhat size fuses go in a koiiler model 9696 1000watt Max amp? To bridge this 4ch to 2 on the high input side. do you have to tie the input side?? together as well? and --?????thankx for the help ahead of time.bleam_customs@yahoo.com
  • 396 Answers
NO dont tie the inputs. Inputs stay just as they are. Outputs are where the bridging happens.
You amp specs are:
XM-9696 C/W 4 CHANNEL POWER CHROME/WHITE AMPLIFIER
MAX OUTPUT POWER (2 OHM): 200W X 4 = 800W
POWER OUTPUT: 90W X 4 @2 OHM (360W) LESS THAN 0.5% THD
60W X 4 @4 OHM (240W) LESS THAN 0.3% THD
BRIDGED 180W X 2CH @4 OHM
So lets take 800 watts and divide by 13Volts DC = 61.54 Amps
So if there are 2 fuses start with 30 amp. To play it safe you could use 25 amps and if they blow try a 30. Now if the 30 blows you may need to take
another look at your wiring. I think 30 will be fine though.
Posted on Apr 03, 2011
How can I bridge a Rockwood Model No. AMP326 4ch amp?
simply use the two outside speaker connectors in order to bridge them
Jul 17, 2016 | Rockwood Car Audio & Video
I have a set of kenwood 5-way 7x10'' speakers (4oahm,90watt rms,500watt max) and a kenwood 12'' sub (4oahm, 200watt rms, 400 max, 800 peak) and my question is if the kenwood kac-706 4ch amp...
Did you google for the specs? Gotta be there. Meanwhile the amp will drive your speakers - the issue is if the amp has enough power to drive the speakers to the volume level you want without distortion. Whatever you decide be careful with speaker wiring and do not hook them up in parallel lest you want to toast your amp stages to a crisp.
Sep 01, 2017 | Car Audio & Video
I have a Koiiler XM-6666 2 channel amp. I was wondering what size fuse i use from the battery source to the amp its self.
You need to match what is on the amp. If the amp has a single fuse, or multiple fuses rated at a total to 80, then you need to use an 80 amp fuse at the battery.
Apr 22, 2011 | Koiiler XM-6666C Car Audio Amplifier
Hello, can someone help me, i want to know how to connect the wires if i want to use 2 channel instead of 4. THANKS IN ADVANCE!!!!!!!!!!!!!
You would want to bridge 2 of the left channels and 2 of the right channels, essentially combining the power output of the amp.
This article should help you out:
http://knowledge.sonicelectronix.com/car-audio-and-video/car-amplifiers/how-to-bridge-an-amplifier.html
Essentially you will just be using 2 channels (left, right) instead of 4 (front left, front right, rear left, rear right) essentially combining the power of those outputs. You'll want to check the amp to see if it tells you which of the outputs should be used for the "bridged" method.
Mar 07, 2011 | Koiiler 8686-C Car Audio Amplifier
Ive got a 5channel zeus z7oo & im hooking up
if i were you i would put the switch to 4ch and the run one sub from ch1-2 bridged and then ch3-4 bridged. I would have to bet this amp is stable only to 4 ohms bridged with so many channels
Mar 19, 2010 | Hifonics Zeus Z700 Car Audio Amplifier
Koiiler XM8787 Amp power problem
Sometimes i goes into protection when the amp is overloading with power.. Or the amp is touching metal.. Or the ground wire aint in the right place..Or check your RCA's, Speaker wires? if their earthing your amp..
Jan 13, 2010 | Koiiler XM-8787C Car Audio Amplifier
What size fuse does the XM 7676W Car Audio Amplifier take? mine blew and i got the amp from a friend so i dont know?
Do not use anything bigger than a 10amp fuse. Cheaper to replace a fuse than an amp. 10 amp is usually the standard.
Apr 25, 2009 | Koiiler XM-7676W Car Audio Amplifier
Blows fuses koiiler amp mx-8686
check your ground thoroughly make sure it is making good metal on metal contact and that there are not breaks or cracks in the outer coating. Most times amps throw fuses for that reason.
Mar 09, 2009 | Car Audio & Video
Problem with LEGACY BLUE DIAMOND AMPLIFIERS LA1080
never attemp to bridge your amps specially this type of amps. this are too very complicated. you may blow your amp if you will attempt it again.
Jan 22, 2008 | Legacy BLUE 4 X 250W CAR AMP Car Audio...
Need help in wiring speakers to amp.
The right speaker will connect to the R+ and R- terminals and the left speaker will connect to the L+ and L- terminals. Only one speaker per connection. If both speakers are not exactly the same brand, part number,size, etc. then they may NOT sound the same. Be sure to watch the polarity of the speakers so they don't interfere with each other. I.E. speaker + to amp + etc. Good luck.
May 11, 2007 | Koiiler XM-7676W Car Audio Amplifier
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
