Question about Chamberlain 1/2-HP Whisper Drive Belt Drive Garage Access System
My whisper drive is blinking 13 flashes on the code light
13 Blinks Sony Bravia KDL-40V3000, Back Light Issue?
13 red flashing is backlight balance error bad lcd panel or inverter boards (common) or bal board on kdl-52v4100 only, replace inverter board usually then main logic board
Apr 12, 2018 | Sony Televison & Video
Sony Bravia KDL-52WL130. Turns Off and standby blinks 13 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Mar 18, 2015 | Sony Televison & Video
Will a chamberlain belt drive work with genie safety sensors?
no, chamberlain openers require chamberlain, liftmaster, or craftsman safety eyes
Sep 10, 2017 | Chamberlain 1/2-HP Whisper Drive Belt...
We have installed a chamberlain wireless keyless entry. The problem is that when our neighbors house uses their keyless entry our garage door opens without us using our code. We have checked this seveal...
We have a Chamberlain Whisper Drive Plus. The keyless entry stopped working, suddenly. I have changed the battery, not the problem. I cannot get it to work, and cannot get it to reprogram. The keypad lights up when buttons are pressed, but when I press "Enter" the whole keypad flashes for about 30 seconds and then just goes dark.
May 10, 2010 | Universal Garage Wireless Keyless Entry...
When turning on the screen comes on for 2 seconds, then red blinking light flashes 13 times and repeats flashing.
Standard blinking codes for Bravia sets for US only goes to 10 blinks which points to faulty or short circuited components inside whereas the Australian range of KDL's goes to 13 blinks of the LED which points to a faulty balancer and must be taken into a service department.
Aug 02, 2009 | Sony BRAVIA KDL-40V3000 Television
13 red standby flashing lights -- turns on, then turns off
Are you sure about the 13 flashes. Error code only goes to 8 flashes.
Apr 25, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Chamberlain whisper drive garage door keypad
It might be your batteries are dying, or that someone has been tampering with it and messed up the combination. You can get the manual if you don't have it anymore by searching Google for "chamberlain whisper drive garage door opener change code". Page through the instructions and reset the motor control to erase all your remotes, put new batteries in the one on your wall and the one in your car if it's not the kind that's built into the car, and then follow the instructions to program new codes.
Oct 11, 2017 | Locks & Locksmithing
Chamberlain 1/2-HP Whisper Drive Belt Drive Garage Access System Logo
375 people viewed this question
Top Chamberlain Building Materials Experts
Terry Smith
Level 1 Expert
Joseph Hoffmann
Are you a Chamberlain Building Material Expert? Answer questions, earn points and help others
