Question about Kenwood 1060VR Receiver
I have a Kenwood 1060vr and I have no sound what so ever. There is a hissing sound from each speaker but absolutely no sound, doesn't matter the setting
    Brigadier General:
  • 8,546 Answers
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead
Posted on Apr 03, 2011
KENWOOD TS 450S WITH RX PROBLEM
If you are still seeing meter deflection in received signals, it sounds like something in the audio amplifier went south.
Apr 23, 2014 | Radio Communications
I think my receiver just blew. hissing noise from all speakers, now i get no sound - but the display still works...help
unplug the receiver, Everything- speakers, input/outputs. The only cord to the device left should be the power cord.
Power up the receiver, set the tuner on a strong station. check sound quality with headphones only.
If that was ok, now pick one speaker to test all channels with. Follow the procedure above with the
speaker. check each output channel with the tuner as a source using the one speaker. Good Luck!
Sep 03, 2011 | Kenwood VR-8050 6.1 Channels Receiver
My cd player wont work but my radio does in my pontiac 2006 sunfire. Is it the fuse?
Absolutely not. The cd mech is damaged. If it makes a clicking sound when you press eject, it has a cracked gear retainer. If it just plain doesn't read discs or says ERR, it has a bad laser, which means it's time for a new radio. If you need to replace the radio, consider an aftermarket option such as Kenwood, Pioneer, Alpine, etc... It will often cost far less than a factory unit from the dealership and outperform it significantly (as well as offer better features like MP3 inputs).
Jul 03, 2011 | Car Audio & Video
NO SOUND OUT OF RECIEVER, TURN VOLUME TO MAX AND CAN HARDLY HEAR ANYTHING
TURN THE VOUME CONTROL DOWN TO SOMETHING REASONABLE. MAX VOLUME IS ONLY USED TO DESTROY SPEAKERS.
Unmute it, de-select Tape Monitor, de-select M.Input.
http://www.retrevo.com/support/Kenwood-1060VR-Receivers-manual/id/478ci953/t/2/
Jan 27, 2011 | Kenwood 1060VR Receiver
Pop and Hissing after turning on Tannoy 6D
It happens, don't be upset. Call Tannoy and get an RMA # . They will repair under warranty. When you get it back it will be as good as new. Rob
Feb 27, 2009 | Tannoy Reveal 6D Speaker
Loud hissing through rear (souround sound) speakers
I have the Sony Bravia KDL-46S4100. The high-picthed hiss drives me insane. I have a work around but not a fix. Go into your TV's menu and find BACKLIGHT. Adjust it from 1-9 with the house quiet and find what frequency of the hiss is the least annoying.
Sony Bravia high pitch hiss hissing sound high frequency
Nov 22, 2008 | Audio Players & Recorders
No audio
Check all the push buttons and switches on the front of the unit are set where they should be set. In particular the speaker and tape monitor buttons. If there is a "pre out" "main in" set of jacks in the back of the unit, then be sure it is jumpered with stubs or if that unit uses a switch to perform the jumpering function be sure it is enabled. I hope this helps you.
Jun 28, 2007 | Kenwood 1060VR Receiver
Static or hiss noise
I have the same problem. Only one speaker is hissing and only for analog sources. No hissing when I select Coax.
Nov 14, 2006 | Harman Kardon AVR 340 Receiver
120 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
