I need a wiring diagram for a dunsley neutralizer system
Where can i find a wiring diagram for neutral safety switch for 2003 neon
The DK BLU/WHT wire from 15A fuse 10 in the fuse block connects to terminal 2 of the brake transmission shift interlock solenoid. The WHT/PINK wire from the brake lamp switch connects to terminal 1.
Apr 09, 2013 | 2003 Dodge Neon
Wiring for a Dayton motor 6k857L
Wiring diagram appears on side of motor.
This motor is rated 115Volt.
Hot and Neutral wires connect to main terminals.
Connect other wires as shown on label.
For example there can be yellow, black, blue and white wires.
Dayton manufacturing is owned by WW Grainger.
Contact Grainger.
http://www.grainger.com/Grainger/static/help_contactus.html
Oct 12, 2012 | Dryers
I have TORK 1104 , I need control 2- louds (same face) I understood L- hot 1 from breaker, 1- hot 2 from breaker, X- com to loud 1, 2- is com to loud 2. BUD WHERE MUST BE CONNECTED NEUTRAL???
Tork 1104 is 240Volt timer.
Same timer is repackaged and sold as GE 15307
See wiring diagram for single load 240Volt:
http://waterheatertimer.org/images/GE-15307-wiring-250.jpg
On the 1104, there is not a separate terminal for Neutral wire.
240Volt circuit does not require neutral wire to complete circuit, so 240Volt timer does not have terminal for neutral.
If you want to control two 240volt loads, then this is not the best timer.
I recommend GE 15207 from Home Depot or Heavy-duty Intermatic GM40 available on-line.
If you want to control two 120Volt loads using Tork 1104, then connect 240Volt lines to to terminals L and 1 as shown in diagram above.
Bring your neutral wire into the box, but do not connect neutral to any terminal.
Each 120Volt load has black and white wires. The whites are for neutral so tie them into the neutral wire using wire nut. Connect black wires to terminals X and 2. If you want both 120Volt loads on same phase, then connect both black wires to terminal X.
Resources:
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
Sep 25, 2011 | TORK Variable Cycling Timer 8601
How to connect a new era alternator voltage regulator wiring diagram.Or a schematic diagram of the charging system.
knowing the color codes can be a great help..usually in 12v reg system,from the regulator there are 6 white wire having a stripe codes,blue means neutral,green means field,black means ground to body,white means hot wired to +12v,yellow means to bat charging indicator going to instrument panel and finally red means to ignition....and always secure the regulators case to ground.
Jul 19, 2011 | Isuzu i-Series Cars & Trucks
10-3 w/ ground wiring diagram
your 2 hots phase wires RED and BLACK need to go to the L1 and L2 terminals,the white goes to the "N" neutral terminal and green or green w/yellow stripe is case safety ground---now at the breaker the RED/BLACK are connected under each one of two screws on the breaker the white goes to the NEUTRAL BUS BAR on the palel surface where all the white wires are already, also the green goes to the neutral bus bar,this only applies if this is the MAIN house power panel, is you wire it to a sub box panel then the neutral must be isolated from the sub panel chassis and ground can still be connected to panels case
Oct 04, 2009 | Dryers
Need a basic diagram to wire a ceiling fan.
Depending on how your place is wired will dictate the solution here.
The light box in your ceiling should have two or three wires. Black and White, or Red, Black and White.
If you have two wires (one switch to control everything):
Black is power - hook this to the fan's power wire (and the fan's light wire if applicable)
White is neutral - hook this to the fan's neutral wire.
If you have three wires (two separate switches):
Red is power for the light - hook this to the fan's light wire if applicable
Black is for the fan - hook this to the fan's motor
Sep 18, 2009 | Hunter 52" Ceiling Fan With Light And...
Wiring diagram
This model of cook top needs the 4 wire install because it has both 220v and 110v circuits. The forth wire is a neutral that operates the 110v circuit. You can move the ground of the 3 wire outlet to neutral, but ONLY! if the ground wire is insulated. What this will do is give you both your 220v and 110v circuits. The problem with that is your cook top will not be grounded. The best solution is to locate a neutral wire and tap into it, this will give you your 4 wire circuit. Your missing a neutral in a 3 wire outlet.
More Asst.
eboukater@gmail.com
Sep 24, 2008 | Jenn-Air JJW8530C Expressions Collection...
Heating & Cooling Logo
102 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
