Question about Profoto Cameras
I recently purchased the D1 Monolight kit that has two monolights. They worked perfectly until my last photo session. At that time, only one of the lights would trigger the second light when I attached a sync cord from the light to my camera. Today, neither light will trigger the other one. What is my problem and how do I solve it? Thanks for your help. Jerry Stevenson
silly girl
  • 513 Answers
SOURCE: Canon G2 Powershot suddenly went dead
I read of a simmilar problem - a "zoom brush", caused by a faulty part, number CL1-1006-000. Usualy it appears earlier in the cameras career though... Did you try leaving it battery-less for a bit longer than the short changes? Remove it from all possible power sources(There is a small battery inside the main battery compartment) for at least a few minutes. It should reset it in case its just a system crash. Just be aware that after the reset it will ask you to input date and time, and theres another known bug of most of the buttons freezing after inputing date/time. should be fixed by pressing the display button. Hope you manage to fix it somehow...
Posted on May 11, 2006
jackboy
  • 2985 Answers
SOURCE: LCD not showing view of image to be taken
Nikon Techical Support the quickly this is a CCD or associated component failure
Posted on Jul 22, 2007
poolseman
  • 206 Answers
SOURCE: Fuhifilm finepix a700
Can you play back pictures and is the quality of these ok ? If you can but there is no image in capture mode then the CCD sensor is faulty and needs replacing.
Posted on Sep 11, 2007
jrw4u
  • 62 Answers
SOURCE: lost manual for GE H855 camera - how do I upload photos?
Here is the owners manual to it...
http://static.tigerdirect.com/pdf/GE_H855-Manual.pdf
Posted on May 01, 2009
BillB-SA
  • 2761 Answers
SOURCE: Hello, I purchased a finepix s5700 about 18 months
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, it may be time for new batteries, or the camera may have a problem that requires professional repair.
Posted on Dec 30, 2009
I have both remotes, but unable to use the remote to unlock my vehicle. Using the key, while unable to start the vehicle, the lights all flash. No audio as the horn quit sounding when I us the remote to...
Check/replace the battery inside the remote. Check the battery of your vehicle. The battery connectors could be loose. untill you unlock the vehicle with the remote it will not start. try resetting it by removing the +ve positive connector from your vehicle battery for a few minutes.
Aug 13, 2014 | Cowboystudio Multi-Function Wireless...
How to use fxr 400 lights
You can see any you tube video to use Elinchrom FRX 400 lights, you can get some ideas.
Source: For your photographic needs; visit here
http://www.arihantdigi.com
Jul 28, 2010 | Elinchrom D Lite4 400 with S Monolight
Sunpak ms 4000 monolight parts
Try ebay... and keep checking. Most everything can be found... except the super cyclers, and the flash tubes.
Jan 01, 2010 | Sunpak Cameras
My 1800 is printing extremely slowly , until I
Your printer may have recieved a spike from the same lightning and fried the circuit board.
Is it under warranty?
If so call Epson and get an exchange unit.
The MAY help you if you mention the surge
Jun 19, 2009 | Epson Stylus Photo R1800 InkJet Printer
Cameras Logo
19 people viewed this question
Top Profoto Cameras Experts
Are you a Profoto Camera Expert? Answer questions, earn points and help others
