Question about Dell Inspiron 1525 Notebook
I'm having problems getting the dvd rw to work or recognize discs.It says that i have the correct driver,but it just says "cd rom",not dvd.The computer used to play dvd's and burn dvd's all the time before it was fixed after a bad virus had gotten into the system.
    Guru:
  • 811 Answers
You have a combo drive I ran into this issue myself and the fix I used was to redo the region and populate the ROM again. Virus would not have anything to do with changing this out. What I would do is there is a screw on the back side of the lap top remove it and pop the ROM drive out and place it back in again after you have removed the power supply and the battery out of the computer.
Now restart everything again with battery and power supply unit plugged back in. It should pick up the ROM Drive again. Now go to devices select CDROM drives and select properties and then select region make sure this is set to region 1 then go to populate. This should solve your problem with the ROM Drive. Please post a vote for me if this assisted you. Thanks for using FixYa! John
Posted on Apr 02, 2011
Can't recognise DVD RW
Hi all,
Boy, have I been having a problem. I've tried two different dvd burners, an external TDK DVD+/- RW drive and now an internal NEC dual layer DVD+/-RW drive. I have a Dell Dimension 4500 that came with a Dell branded Windows XP Pro. Have you ever tried getting support from Dell? What a freaking bad joke that is.
Microsoft says there is known problem with XP viewing a DVD+/-RW disc the same way it views a CD+/-RW disc. Problem is a CD RW uses 32 bit packets and a DVD RW uses 16 bit packets. As a result, without the fix, my computer can't recognize there is a DVD RW disk in the drive when trying to burn to it. It recognized DVD +R and DVD-R discs just fine, and I am able to burn to those with no problem.
What I want to do is image my hard drive and burn the image to DVD. That I can't do, because it always comes up with "no disk" or some variation thereof anytime I try to write to an RW disc. Any suggestions? Has anyone else had this problem?
Feb 28, 2011 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
My LG DVD RW can not play DVD
Are you sure that your ROM can't play the disc or is it that you don't have a program to play the disc? To my knowledge Windows XP didn't come packaged with a DVD Decoder program; except for XP Media Center. There are some FreeWare programs out there that you can download, or you can pay for the program that decodes DVDs so that you can watch them. If your DVD isn't recognizing any type of DVD that you put into the ROM, then try playing a CD\DVD player cleaning disc in it. If that doesn't work, then you will probably have to get another DVD-ROM.
Jun 06, 2010 | LG GSA-H42N 18x DVD RW DL IDE Drive...
Computer CD-RW
here is your problem - im a expert in cd roms ... put the computer back like you had it
2 download this small file i wrote
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
open the file run it and reboot the computer BINGO it works - this file reset you upper and lower filters in the registry now the cd rom works - let me know
Dec 30, 2009 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
I have a six year old sony vaio desktop. It has a
can you give me the name of the driver and i'll get you a site to download it
Nov 07, 2009 | Sony VAIO PCV-RS720G (027242658103) PC...
I purchased a CD-Rom advertised on Amazon as compatible with Asuseeepc and I wanted it for use with the DVD support disc. It works fine with cds but does not recognize dvds when inserted. I have been
A CD-Rom will only recognize CD's. It must be a DVD-ROM to recognize DVD's. DVD-ROM will recognize CD's ,but not the other way around. No drivers needed for thes, they are plug and play.
Char S.
May 20, 2009 | Teac PortaCD 224PE External 24x CD-ROM...
DELL laptop does not read blank DVDs
the combo drive you listed above is a cd-rw/ DVD-ROM....meaning that it will play and burn cd, cd-r, and cd-rw disks. the dvd rom will only be able to play dvd-rom and dvd-r disks providing they are in the proper format. check that the disk in question is not a dvd-rw or (+2) disk. the drive will not recognize that a disk is in the drive if the disk isnt compatable. try a dvd movie, if that works then a dvd-r, if that works then try a dvd-rw +1. if the last option doesnt work then you will have to stick with the dvd-rom and dvd-r, or purchase a dvd-rw drive to install.
GOOD LUCK AND DONT FORGET TO RATE MY POST!! :D
Mar 18, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
LG GCA-4080N internal drive
It seems that what you have is a combo drive only :(
it only recognize DVD reading. no matter what driver you used. need to buy a dvd writer/ that said can write dvd.
Types of Optical Drives and CD/DVDs
Optical drive type Read from CD/DVD-ROM media Write to CDRW media Write to DVD ±RW/R media Write to DVD +R DL media Write label to LightScribe CD-RW Write to DVD-RAM media DVD-ROM Drive Yes No No No No No DVD and CD-RW Combo Drive Yes Yes No No No No DVD±RW/R and CD-RW Combo Drive with Double- Layer support Yes Yes Yes Yes No Yes LightScribe DVD±RW/R and CD-RW Combo Drive with Double- Layer support Yes Yes Yes Yes Yes Yes Blu-Ray Disc DVD±RW SuperMulti Drive with Double-Layer support Yes Yes* Yes Yes No Yes *Low speed (4X) and high speed (4-12X) are supported. UHS-RW (24X and 32X CD-RW) is not supported.
NOTE: Some of the optical drives listed may not be supported by your computer. The listed drives are not necessarily all of the supported optical drives.
Dec 26, 2008 | LG (GCC4521BBULK) CD-RW/DVD-ROM (Combo)...
DVD-RW not working
Hi, in my experiance 99 times out of 100, it's the CD/DVD gone kaput! sorry... they seem to be rather delicate devices and fail for often NO apperant reason. I suggest ya take it to a reputable "PC Guy" Get a FIRM QUOTE, and replace the unit. If ya tech savy then buy a new unit and replace it, it is REAL simple to do so ya self, usually the sorta "Plug In" I bet that solves ya problem.. :)
Feb 08, 2008 | Acer Ferrari 3000LMI PC Notebook
DVD/CD ROM drive issue
sometimes these things got dust as dvd writer use 2 kind of lenses. and as u didnt use the DVD for long time may be you need a CD/DVD cleaner disc. which will fix your problem.
Jan 05, 2008 | Panasonic Combo Drive - DVD-ROM & CD-R/RW...
Copying data on to a DVD
What type of application are you using? I know that the new nero requires you to choose whether you want to write to dvd or cd before it will work. maybe your application is similar.
Aug 01, 2006 | HP CD-Writer 9900ci CD-RW/DVD-ROM Burner
Dell Inspiron 1525 Notebook Logo
32 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
