Question about Tecumseh Garden
Tecumpseh tc3 ,2cycle ,idles fine,give it gas then stalls?
  • locco Apr 04, 2011
    THANKS will try when I get a chance
  • locco Apr 06, 2011
    thanks all good
  • 274 Answers
The carburator is rinning too rich. Adjust the knob to make the air/ fuel ratio more lean. You may want to change the spark plug as well, it will be fouled.
Posted on Apr 02, 2011
  • Kelly Comstock
    Kelly Comstock Apr 03, 2011
    Let me know if have been able to get this resolved or if you need some more help. If not you can accept the solution to close this thread. Thank you!
  • Kelly Comstock
    Kelly Comstock Apr 04, 2011
    Could you mark the question as solved and rate the solution. Thank you!
98 Mustang stalling after start
Use a bottle of yellow HEET dry gas to remove any moisture problem in the fuel.
Clean / replace air filter.
Top off ATF to MAX level.
Use starting fluid to aid starting.
Jan 16, 2014 | 1998 Nissan Maxima
Car starts fine idles fine wont rev up wants to stall if you give it gas
Could be the throttle position sensor, or low fuel pressure.
Feb 25, 2013 | 2000 Toyota Corolla
1991 chevy c1500 stalling
Usually a problem with a dirty throttle body or a faulty idle air control valve. The computer controls idle speed by regulating how much air enters the intake thru the valve.
Oct 13, 2012 | 1991 Chevrolet C1500
'97 crown vic cranks but stalls immediately
Idle air control valve. And/or gunked up throttle body, pcv port at throttle where mating to intake manifold.
Jul 08, 2017 | 1997 Ford Crown Victoria
Car stalls when in idle
You need a tune-up. Not a major problem, and it will fix all your problems. Please don't forget to rate this answer.
Feb 23, 2010 | 1995 Toyota Camry
Engine stalls when giving gas
Make sure you have the carb. fuel line on the correct side of carb. Not on primer bulb side.
May 14, 2009 | Garden
Idles fine but stalls when i give it gas?
Hi jkeefer,
I'd suggest you check the air flow sensor
Regards Johngee10
Sep 08, 2008 | 1999 Jeep Cherokee
'93 Aerostar-stalls while driving/scary-stalls in 'drive' at stops
Wow!!! Now that's a headfull of problems....
This could be a great many things...
Check these before you sell. I have a '93 Aerostar and can't live without it.
1. Check idle speed
2. Fuel filter may be clogged or water in the fuel system.
3. Choke improperly adjusted or sticking.
4. Distributor components damp or damaged.
5. Faulty emissions components.
6. Faulty or incorrectly gapped spark plugs/ Also check wires.
7. Vacuum leak at the carburetor/fuel injection unit or vacuum hoses.
8. On 1986 models, stalling during idle or deceleration may be caused by sludge in the throttlebody. (2.3 litre engine)
9. On 1986 & 1987 models with a 2.3 litre engine,hesitation or stalling during acceleration may be caused by carbon build-up on the intake valves.....I hope this helps!! Adios
May 23, 2008 | 1993 Ford Aerostar Extended
Garden Logo
Top Tecumseh Garden Experts
Mike Squire
Jim Parker
Jim Parker
lnbn1975
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
