Question about Refrigerators
My whirlpool model et8chmxkt04 refrigerator has water in the refrigerator which I assume comes from the freezer. I don't have visible ice buildip anywhere. Shirley
  • Refrigerators Master
  • 5,323 Answers
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Posted on Apr 17, 2015
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Apr 02, 2011
Top freezer whirlpool refrigerator condensation water leaking/dripping
there is a drain in the freezer that sum time get Clogged the drain is located below the evaporator coil you have to remove the evaporator cover to unclog it make sure the refrigerator is unplugged before trying this you can't unclog the freezer drain without removing parts
Sep 10, 2013 | Refrigerators
Freezer won't drain
If the water is showing on the freezer side, more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt. If thats not an option that you want to use the actual repair method would be to 1) unplug the machine 2) empty everything out of the freezer so you'll have room to work 3) take all the shelving and baskets out 4) locate the screws on the rear wall inside the freezer and remove them 5) take the back panel off exposing the evaporator coils ( the aluminum ) 6) directly below the coils is a trough of sorts and the drain is usually in the middle and runs out the bottom, remove the ice by carefully chipping it out or by using a hair dryer or hot water. 7) once all the ice is gone, the drain is visible and water can flow smnoothly down the drain dry the area and reassemble.
May 11, 2012 | Whirlpool Refrigerators
Whirlpool gold French door refrigerator ...ice maker stopped making ice. I THINK that my daughter left the door ajar (on the side with the ice/water dispenser) during the day. Came home to find water...
Oh yes. Shut it off let it drain and dry. When you start it up tho let the freezer cool for 2 days to be sure, then turn on the ice maker. 48 hrs will allow the unit to dry up any moisture you may have missed and all will be well.
Mar 04, 2017 | Whirlpool Refrigerators
Ice maker/ water dispencer "locked"
have whirlpool ice and water waterand ice will not come come out--right no ice wil come push the ice have ice ill not go back to water
Sep 26, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Is there a drain hole in the freezer area on whirlpool model # ET18LK?
To get to it , remove the food from the freezer and remove the ice maker , if equipped , and remove the 2 screws holding the freezer bottom "panel" . Remove the 2 or 3 screws holding the rear freezer panel on , and remove the panel . About in the middle , under the coils , is the drain hole . If iced up , defrost the hole with a hair dryer until visible . Hot water will help defrost the hole . When water starts to flow , use a small piece of hose , inserted into the drain , and blow thru until clear . This will remove any debris built up in the unseen drain line .
Sep 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool refrigerator leaking from top of unit
Listened to other posts and figured drain plug was clogged. It was with ice. Removed bottom pan and back panel of freezer, removed ice on bottom, put hot water in drain to thaw ice until it flowed into pan underneath fridge. Thanks for the ideas.
Jun 02, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice maker stopped working
Hello pryorjonw. You may need a new dual water valve, because the part going to the icemaker may be bad, the ice sensing arm may be in the up/off position, the ice bucket may not be positioned properly not triggering the icebucket sensing switch, the condenser coil might be dirty, or the freezer may not be freezing enough to make ice while everything else seems to be staying frozen. To see if your freezer is cold enough, squeeze your icecream carton, as that is the first to thaw if there is a problem.
Nov 17, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Broken ice maker in whirlpool side by side refrig model no.ed2ghgxmq00
1. Check freezer temp. Above 5 degrees? Icemaker will not start. 2. Make sure there is water coming to the refrigerator from the supply line. 3. Is the refrigerator clean underneath? Fan running? Dirty refer bottom can cause high freezer temps, see #1. Ideal freezer temp is -5. Icemaker and valve should be checked by a service tech.
Jun 26, 2008 | Whirlpool ED2FHSS Side by Side...
Refrigerators Logo
198 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
