Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Power shuts off after about 3 minutes - Dyson DC07 Bagless Upright Cyclonic Vacuum
  • 456 Answers
This is quite a common problem with dysons. mine had the same problem last year.
there is a thermal cut out switch built into the motor and sometimes they can become too sensitive.
as the motor warms up, the thermal switch thinks it is too hot and cuts power to the motor.
thie switch is built into the motor and cannot be replaced. the only option is to change the motor unit itself.
please feel free to ask again for detailed fitting instructions if you decide to take this route.
Posted on Apr 02, 2011
  • Official Brand Answer
  • 2,572 Answers
Your DC07 is equipped with a thermostat designed to protect the motor. You should be able to resolve your issue by washing your filters and checking the cleaner for blockages. Our online guide may be useful in helping to do this:
http://www.dyson.co.uk/support/help.asp?article=1940&product=DC07-SY
Hopefully you should find these steps resolve the problem. However, if you're still experiencing problems, please get in contact with us free, 08002980298 (UK), or 1866MYDYSON (US), so we can run through some checks over the phone.
Kind regards,
Jack
Dyson Customer Service
Posted on Jun 22, 2011
My Hoover pure power 1700w upright, bagged vacuum cleaner shuts down after 5 minute's use. Although I purchased the pure Hoover power 1700w upright vacuum cleaner around eight years ago it has not u
Are the brushes worn down too far? As they wear the springs tension gets weaker. The brushes can also get stuck inside the channel they slide in. Could also be a buildup of dust etc inside and around the internal fan or commutator, etc.
Jan 18, 2015 | Hoover Vacuums
Oreck vaccum cleaner runs about 4 or 5 minutes then shuts down.
this means you have a blockage somewhere on the vac
Feb 17, 2013 | Oreck Vacuums
What would cause this to shut off after a few minutes of use with full battery charge
1) test the power cord for open, broken, loose or defective with VOM
2) test the outlet wall, for ground improperly, and repair.
3) Most of the time is THERMAL fuse, replace or fix it.
God bless you
Jul 27, 2012 | As Seen On TV Swivel Sweeper Vacuum
Electrolux EL7020 SHUTS OFF Constantly!
That problem have 2 causes..#1 is loose electrical connection inside or on the power cord..#2 is worn out carbon brush inside of vacuum motor..
Carbon brush is the one of the most serviceable parts of a vacuum cleaner because our vacuum cleaner motor is very hard working parts so the brush inside will possible worn or not connected to the armature of rotor...
Jan 12, 2012 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Shark infinity vacuum nv31c motor overheats. everything is clean and free of clogs. it will work for 3-4 minutes, then shut off. does the motor need replacing?
Mine takes longer to shut down, but I just started having this same problem. I wish I knew what's causing it so I could fix it. I think maybe we had a power surge at some point when I was using it last week. :(
Nov 07, 2010 | Euro-Pro NV30 Infinity Bagless Upright...
I have a Kenmore Elegance Vacuum with Dirt Sensor, Model # 116.30750400C, Serial number M41901532. When vacuuming the carpet the power head will work for 3-6 mins then automatically shut off, power is...
It is an electrical problem in the handle, if you can or know somebody that has any fix it ability it can be fixed in about ten minutes. Oh, and Sears SUCKS!!
Oct 17, 2010 | Kenmore 34612 Bagged Upright Vacuum
Electrolux Oxygen 3 model 7020A contols not working
You need to replace the hose itself. The buttons in the handle a very cheap and go bad all the time.
Aug 17, 2009 | Vacuums
Dyson shuts off in 5 minutes, then starts up 2-3 minutes laters w
I think there's a good chance of a clog that you haven't found. On the Dyson it's fairly easy to remove several covers that give you access. From the collection canister is a tube that runs toward the base. At the bottom of the tube you can remove a cover where you can check for a clog. Thats basically on the right side of the machine. From the rear side, very low and toward the middle right is a tab that you can push in and remove the tube that goes up into the flexible hose. Thats another good place for a clog to hide.
Jun 10, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hoover u5720-900 quits running and restarts again after some time
There is one more filter under where the collection tank & Hepa filter sits -- there is one screw that holds the cover down - remove that filter and clean it that will help. I also find I need to vacuum the hepa filter as well- it is too expensive to replace all the time. The Hepa filter can be placed inside a plastic bag and shaken really good to get the dust off of it
Jul 27, 2007 | Hoover U5720-900 WindTunnel Upright Vacuum
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
352 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
