Question about Creative Labs Inspire T5400 Computer Speakers
I have a T5400 that has been working fine until I moved the computer reconnected it and now when I do a test on Super Woofer the sound come out of the centre speaker very muffled have checked all connections Have you any ideas.
  • Creative Labs Master
  • 27,725 Answers
Open up your computer the speakers plug/outlet is usually at the back of the computer
to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
be sure to wear an anti static earth strap before touching anything inside your computer
hope this helps
Posted on Apr 02, 2011
No sound from woofer behringer truth monitor b2031
first check woofer (end wire problem )
remove woofer from circuit
test with 1.5v battery cell touch parallel woofer lead neck
if disturbance sound come from woofer
woofer is ok
Apr 29, 2014 | Behringer Truth B2031 Other Dj Equipment
No sound out of my Altec Lansing ADA 745. Computer Sound card is fine.
If other speakers are working, then 745 is defective or the volume switch is set to mute. Please check that, repair it if required.
Aug 27, 2012 | Altec Lansing Technologies Audio Players &...
Short in subwoofer wire - Altec Lansing computer speakers & sub
yes, you can splice the cables and put on a new connector, goto radio shack with the old connector and im sure they will have one you can splice right onto it. ive done this many times with varios equipment "headphones speakers etc" it may take a couple of tries to get the wiring right but if its just one speaker there will most likely be just 2 wires, if you wire it up and it doesnt quite sound right, wire it the other way. speakers will work wired backwards but wont sound quit right so if it doesnt, rewire it and it should. good luck and i hope this helps!
Jan 15, 2010 | Altec Lansing ADA 885 Computer Speakers
Dell MMS-5650 5.1 speakers not working
sounds like they are picking up interference. make sure they are grounded well.
Aug 19, 2009 | Dell 5650 Computer Speakers
What's the best sound card?
Sound Blaster is certainly a good name when it comes to sound cards, they've been around forever. If you're looking for quality audio and full use of your 5.1 speakers, SB live 5.1 will do the trick.
May 09, 2009 | Creative Labs Inspire T5400 Computer...
Sound problem with Creature II Woofer.
just increase subwoofer level located at the front. If it doesn't work then replace your woofer if it is in warranty period because it migth be due to internal electronic components failure.
Jun 17, 2008 | JBL CREATURE II Computer Speakers
Subwoofer
often your sub need to be change because of its malefunction.
Mar 09, 2008 | JVC TH-M303 System
Logitech Z-2300 computer speakers
Please recheck the connection of subwoffer once again..
thankyou...
Jan 02, 2008 | Logitech Z-2300 Computer Speakers
Creative Labs Inspire T5400 Computer Speakers Logo
126 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
