Question about Amana 24 in. ADB1200AW Built-In Dishwasher
I have an ADB 1200 (or possibly an ADB 2200) according to the installation instructions. I lost the manual. Anyway, the door was becoming more difficult to open. Now it won't open at all no matter how hard I press on the latch. Any suggestions before I try to pry it open and probably break something? Bill
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Amana ADB 1200AWW
Try first unlocking the door latch with a small screwdriver, unplug power cord before working on the door lock.
If this does not work buy a replacement door lock, or get it replaced.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
Posted on Nov 29, 2008
I can not reset my tablet to factory reset no matter how many times it will not work
Hello, today I will show you how to fix stuck on android or remove password, for model SC-91JB - SC-74JB
First, connect your tablet to PC.
you need drivers to be able to reset;
download the adb drivers from website;
www.adbdriver.com/downloads/
or click on link below for direct download.
ADB Driver Installer (9.22 MB)
next, install the ADB driver then you will see a USB root on notification area on your PC.
not-reset-tablet-factory-reset-no-matter-ov0hda1oylwbkzivvosqeagh-5-0.jpg next, download the fastboot click on link below;
https://www.dropbox.com/s/adu0ysny2191kgd/Fastboot.zip?dl=0
install fastboot and you will open a dialog box.
Follow the steps on image below; step one, two and three...
not-reset-tablet-factory-reset-no-matter-ov0hda1oylwbkzivvosqeagh-5-2.jpg next, command prompt will open and you need to type these commands;
not-reset-tablet-factory-reset-no-matter-ov0hda1oylwbkzivvosqeagh-5-5.jpg This will reboot and erase password.
If stuck on Android; type commands below (it's the same way like on top image just shorter commands).
> adb devices
> adb shell
> wipe data
> adb reboot
> exit
that is all; your tablet will be completely restored...
thanks and good luck.
Jan 26, 2016 | Supersonic SC-91JB 9-inch Android 4.1...
My alcatel is asking for an adb sideload. How do I do this?
Probably every Android power-user at least once in his life used ADB - Android Debug Bridge. It is a versatile command line tool that lets you communicate with an emulator instance or connected Android-powered device. Using ADB shell commands gives you additional control over your device and sometimes it can save your device from being bricked (example: How to: copy ROM zip file to the freshly wiped device). You can find some more basic information about ADB here.
How to: copy ROM zip file to the freshly wiped device. The main difference is that ADB sideload works only with recoveries based on Jelly Bean source or newer. I believe that ADB sideload was created to simplify the process of flashing/restoring Android update.zip packages.
Keep in mind that while using ADB sideload, the regular ADB shell won't work. To be able to use SIDELOAD mode make sure you're running latest ADB drivers from the Android SDK (Platform-tools). Here are the simple steps you need to follow to flash update.zip package using adb sideload mode (based on stock Android recovery):
  1. Place the ZIP package you want to install in the same location where you keep ADB drivers - adb.exe, AdbWinApi.dll and AdbWinUsbApi.dll (usually it's SDK\platform-tools)
  2. Make sure you have USB debugging enabled in Settings > Development on your device
  3. Make sure your phone drivers are installed on the PC you're going to use
  4. Boot your device in recovery mode (Android logo with a exclamation mark) and connect your device to PC
  5. Hold down "power" button first, followed quickly by "volume up" button. You should now see the recovery menu
  6. Use the volume up/down keys to select "apply update from ADB," then press power to select it
  7. Open a command prompt on the PC (cmd.exe), type and confirm with ENTER:
  8. cd /d <adb.exe location> (for example: cd /d c:\SDK\platform-tools) or you can open your SDK/platform-tools folder, then press SHIFT button and the right-click mouse button and choose "Open command prompt here"
  9. adb sideload <filename>.zip (for example: adb sideload update.zip)
  10. The zip package will begin installing. When it's done, select "reboot system now."
How is that different from the alternative method? You don't have to manually create the proper folders structure, push the file and later install if from inside the recovery menu. The result is basically the same, because ADB sideload is also transferring the zip file into the device internal memory and later it automatically begins the installation procedure. However, it works only with recoveries based on Android Jelly Bean source.
May 16, 2015 | Alcatel Cell Phones
How do I unlock my ALCATEL T'POP 4010X PHONE?
If, and only if, you've backed up your profile and contacts to a Google account, you can do the following. If no you should take it to a service provider who can use a computer to back up that information to an SD card without actually unlocking your phone's password.
Reset the phone to factory settings to unlock the password. If you're more computer savvy you can try this:
What You Need:
=>A computer running a Linux distro or Windows+Cygwin
=>USB cable to connect your phone to the PC
=>Adb installed
How to install adb:
1. Open Terminal
2. Type:
Code:
sudo apt-get install android-tools-adb Hit [Enter]
3. Follow the instructions until everything is installed.
INSTRUCTIONS:
1. Connect you (turned on) Phone to the Computer via USB.
2. Open a terminal window.
3. Type:
adb devices adb shell cd data/system su rm *.key
4. Done...Now You Just Have To Reboot.
*If you see a pattern or gesture unlock just use any random pattern to unlock it should work.
You may also try:
Solution For Everyone Via Adb - SQL Command :
INSTRUCTIONS:
=>Type This Commands Separated In Your Terminal (CMD Prompt) :
Code:
adb shell cd /data/data/com.android.providers.settings/databases sqlite3 settings.db update system set value=0 where name='lock_pattern_autolock'; update system set value=0 where name='lockscreen.lockedoutpermanently'; .quit =>Now You Just Have To Reboot.
Or this:
INSTRUCTIONS:
=>Type This Command In Your Terminal (CMD Prompt) :
Code:
adb shell rm /data/system/gesture.key You can find more options here at XDA android developer's forum.
Android Guide Hacking And Bypassing Android Password Pattern Face PI
Jan 19, 2015 | Alcatel Cell Phones
How to use the keyboard to control the volume on my dell inspiron2200
In the Tray Notification Area click on the Sound Icon adjust volume. You can find a user manual here: http://www.dell.com/support/Manuals/us/en/19/product/inspiron-1200
Mar 18, 2013 | Dell Inspiron 2200 Notebook
How to hook up my logitech z-2200 woofer I lost my manual
Usually the speakers connect to the back of the woofer. The subwoofer then has the Auxillary cord that plugs into your computer. This is how the majority of all conventional speakers work.
If you want to check the manual, follow this link. It's tough to view but might be helpful.
Best of luck!
http://safemanuals.com/user-guide-instructions-owner-manual/LOGITECH/Z-2200-_M
Mar 19, 2011 | Logitech Z-2200 Computer Speakers
1998 honda accord driver side door won't open inside or outside but it can lock and unlock.
The lock / unlock operations are performed either electrically or manually directly on the solenoid installed on each door, and has nothing to do with the opening mechanism. In all probability, the metal rod that goes up from the door latching mechanism to the outside and inside handle, has become unattached / dislodged from the unit. This requires taking down the inside of the door panel, in order to reach the latch, and its operating rods. Look elsewhere on Fixya, for instructions on how to dismount the door panel. I think i provided instructions for this in the past.
Sep 03, 2010 | 1998 Honda Accord
1988 5 speed Honda Accord
Ensure your spark plugs,wires (ignition coil and spark) and your filters (air and fuel) are within 2 years of installation It's erratic at 800 rpm as the engine is cold and they like the 2200 range for 3 minutes before they kick down on their own. Press the pedal twice before inserting your key. The owners manual states depending on the outside temperature, the engine will require more priming. Update if possible.
Oct 25, 2009 | 1988 Honda Accord 4 Door
Magimix Ice cream maker - Le Glacier - lost instruction book
Magimix 2200 Gelato Chef 1.03 Quart Ice Cream Maker Support Magimix 2200 Gelato Chef 1.03 Quart Ice Cream Maker Support. Manual for ice cream maker ... Need Instructions/User Manual. Magic chef ice maker model MCIM30TW ... fixya.com/support/p519941-magimix_2200_gelato_chef_1_03_quart_ice/rss
best regards mike
Aug 17, 2009 | Magimix 2200 Gelato Chef 1.03 Quart Ice...
Need instruction manual for cuisinart dcc-2200 coffeemaker
they have your user manual free , all you have to do is save this pdf file to your computer
http://www.cuisinart.com/share/man/528_man.pdf
Feb 04, 2009 | Cuisinart DCC-1200 Coffee Maker
Cuisinart Coffee Maker DCC 2200
The user manual is a free pdf download from the cuisinart web site.
Dec 26, 2007 | Cuisinart DCC-1200 Coffee Maker
Amana 24 in. ADB1200AW Built-In Dishwasher Logo
43 people viewed this question
Top Amana Dishwashers Experts
Cleverer2
Mike
Kolbrun...
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
