Question about Memorex iListen Mi1006 (Silver) Remote Control for Apple iPod
It won't turn on.
My Memorex iListen worked perfectly fine before the power went out in my house for a couple of hours.  I tried turning it on when I got the power back and it simply won't turn on. I have tried resetting the power strip it was plugged into but nothing works.  What is strange though is the green light on the power adaptor works, it's just the main system that won't turn on. Please help! thanks.
  • 6 more comments
  • jcrum08 Aug 24, 2008
    We had the same problem. Our power went out during TS Fay here in Florida, and when it returned, the iListen would not turn on. It occasionally flashes on for a second when the power button is held down, but it will not power up. This is a bummer as we have not had this long.
    Our green light on the power adapter seems to flash rather than stay consistenly green. I don't know if that will be helpful.
    Thanks ahead of time for any help.
  • kt_aylor Aug 24, 2008
    The power goes off in my house often, I came home from vacation came and all of sudden my 2nd generation ipod wouldn't work but my boyfriends 20g older ipod would. Any help or an explanation why the older ipod works but not the nano?
  • craig195 Jan 06, 2009
    how do you reset the power strip?
  • debkroberts Jan 24, 2009
    same problem...thought my husband was crazy when he said maybe it doesn't work because the power went out several weeks ago.
  • gatornewsman Jan 29, 2009
    sounds like this is a common problem, as i am just online researching why this happened to ours! please let me know when someone comes up with a solution....thanks!
  • nbsp2000 Feb 24, 2009
    I have the same problem with my unit after the power went out the light on the power supply blinks while pluged to the unit but once unpluged it stays steady. I measured the voltage from the power supply and it was a steady 12.56 dcv, now my problem is how to get in the unit with out breaking it all apart I have grown atached to it I think inside the unit their is a fuse by the incomming power plug that can be changed out but if anyone has found out how to open it with harm please do tell.
  • Oakvillian Apr 04, 2009
    Yep, mine packed it in for apparently no reason about 6 months after purchase...it will intermittently light up when you press power, but nothing happens thereafter...
  • Anonymous May 25, 2009
    Same problem here.  My husband is doing the power button thing.  I will be totally amazed if it actually works.
  • 3 Answers
SOLUTION: After a year and half of keeping this broken dock around and researching online to no avail, I have finally "fixed" my Memorex iListen iPod dockIt won't turn on. - 2_bing.gif.
*Quick answer is that I used an old ac adaptor from a modem I no longer used but for more details, read below.
The first issue was figuring out what to search for. My iListen doesn't clearly note it's name on the unit. All I could find on it was "Memorex" so for the purpose of those Googling for a solution, I used generic search terms like "Memorex white ipod2_bing.gif dock" plus "won't power on," "fix," "repair," and "broken." I hope including those keywords in this solution's text helps people arrive at this page as a result.
To clarify the symptoms my unit presented: 1) The power supply's green light was lit but did appear to blink, or rather it was constantly lit but would fade slightly from bright to medium before repeating in approximately two second intervals. 2) The unit would not seem to turn on; however, pressing the power button with an ipod plugged in would result in the unit momentarily turning on. It varied in length but usually only "flashed" on.
Given these circumstances, my guess was that a "blown fuse" was the cause. Since I saw no way to open up the power block or the main dock unit (not quite sure what I was gonna do once in there except look for a fuse), I decided to rummage thru some old power adapters I had lying around in an old shoe box. I found one from an old modem that matched the symbols on the original "broken" adapter. (as i found later, the symbol represents a positive polarity, more info here:http://commons.wikimedia.org/wiki/File:AC_adaptor_polarity.png)
Once I plugged in the modem adaptor to the dock, it powered right up.
I know this was a long, LONG way around sharing a singular solution, but seeing how long it took to finally discover it (albeit an incredibly simple one), I wanted to make sure others found it and knew what circumstances specifically applied to my case.
Posted on Feb 09, 2010
Hi Everyone,
I had the same problem with mine. For no apparent reason 4 months after we purchased it, it would not turn on. I called memorex, and get this.....THEY HELPED ME!!
I cannot begin to tell you how blown away I am. I do have a possible solution, but I can not confirm it, and shortly you will understand.
I actually talked to someone. I still can't believe it. This is what he told me to do;
Push down and hold the power button for 2 minutes. Nothing will happen, and that is normal. While you are continuing to hold down the power button unplug the power cord from the wall. Keep holding the power button for 2 more minutes. Now, let go of the power button and wait 1 1/2 hours. Then plug it back in and see if it works. I still have an hour left, and that is why I do not know if it will work.
Now get this, he told me to call him back if it didn't help. Did you read that?? He said call me back and we will keep trying!! I still can't believe that I actually talked to someone, and he actually is HELPING me!!!
If this fix does not work for you call 877-363-6673 and see what the next step is.
I hope this works for all of us. Memorex has now been lifted to the highest makrs in my book. I have NEVER called another company and recieved help without a hassle or paying for the help.
Have a great day!!!!
Steve
Posted on May 19, 2009
I have a 2000 Volvo s80 t6 it was running perfectly fine 2 days ago yesterday I went to leave and the gear shifter would not shift out of park, a couple hours later in tried it again and it worked, it was...
sounds like the solenoid or the relay that locks the lever into park when the key is turned off may be playing up just to check try using the spare key see if you get the same problem hope this helps regards mick
Feb 28, 2015 | Volvo Cars & Trucks
I have a memorex. I am getting sound but no picture. When powered on, the memorex sign shows up but then no picture just sound. Also makes a slight screeching sound for approx 10 sec. when powered on.
I guess the blanket draped over the TV is intended to give it a "timeout". Anyway, you will likely conclude eventually that the internal power supply has failed.
Jan 02, 2014 | Memorex MLT1921 19 in. LCD TV
My memorex DVD player's drawer won't open. It is plugged in properly and it can turn on. The only problem is that is just won't open.
Unplug it for a week or so. then plug it back in and it will reset. It must take awhile to discharge the capacitors in the machine to reboot the thing if you get a voltage spike or anything. Ours did that too once when the electricity went out suddenly. Then it wouldn't turn on.
I took it over to my house and left it set for a week and tried it again and it worked fine. So I took it back to my mothers house and used it. It's still working three years later.
My expensive JVC did the same thing to me.
Jan 29, 2011 | Memorex MVD2040 DVD Player
My ilisten Mi1006 will not turn on, the transformer is fine and supplying voltage 20Volt DC and the transformer light is on . But the ilisten Mi1006 unit has no display and will not turn on. Tried the 2...
SOLUTION: After a year and half of keeping this broken dock around and researching online to no avail, I have finally "fixed" my Memorex iListen iPod dock.
The first issue was figuring out what to search for. My iListen doesn't clearly note it's name on the unit. All I could find on it was "Memorex" so for the purpose of those Googling for a solution, I used generic search terms like "Memorex white ipod dock" plus "won't power on," "fix," "repair," and "broken." I hope including those keywords in this solution's text helps people arrive at this page as a result.
Given these circumstances, my guess was that a "blown fuse" was the cause. Since I saw no way to open up the power block or the main dock unit (not quite sure what I was gonna do once in there except look for a fuse), I decided to rummage thru some old power adapters I had lying around in an old shoe box. I found one from an old modem that matched the symbols on the original "broken" adapter. (as i found later, the symbol represents a positive polarity, more info here: http://commons.wikimedia.org/wiki/File:AC_adaptor_polarity.png)
Jan 17, 2010 | Memorex iListen Mi1006 (Silver) Remote...
Exactly the same problem
didn't work for me either, but I used an old modem adaptor that fit and it powered right up. if you got any old electronics laying around, rummage thru them and hopefully you find one that works, otherwise you may be able to find a universal or old one online or at a local store for relatively cheap.
Aug 16, 2009 | Memorex iListen Mi1006 (Silver) Remote...
No external sound from Memorex iListen Mi1006 with iPod Touch
this is exactly the problem I am having but with a new ipod nano. Please post if you hear back. thanks!
Feb 08, 2009 | Memorex iListen Mi1006 (Silver) Remote...
Car won' start
Sounds like baD FUEL TO ME.
Jul 29, 2008 | 2002 Pontiac Grand Am
Memorex iListen Mi1006 (Silver) Remote Control for Apple iPod Logo
642 people viewed this question
Top Memorex Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
