Question about Garmin StreetPilot c550 GPS Receiver
I replaced the battery, and the 1/2 inch cable that connects from back to front came looses, how can I reattach this cable, is some kind of special glue used for this?
  • Garmin Master
  • 6,993 Answers
Yes, you can use super glue to reattach the cable. Get a super glue and that should do the attachment. When you apply the super glue, put a little sand and this will make it form like a rock. This will put the cable back together.
I hope you understand the above.....
Good luck.
Posted on Apr 02, 2011
How do replace alternator 06 f 250 6.0 l
I tried to find a tutorial video that could better show the process but I couldn't locate one in my database. Hopefully, my written instructions will suffice.
  1. Disconnect the negative battery cable.
  2. Rotate the drive belt tensioner away from the drive belt and remove the drive belt from the alternator pulley.
  3. Detach the electrical harness connectors at the alternator assembly.
  4. Disconnect the positive battery cable and remove the nut and washer.
  5. Remove 2 front alternator bolts.
  6. Remove the rear alternator support bracket retaining bolts and the support bracket.
  7. Remove the alternator from the vehicle.
To install:
  1. Place the alternator in position and loosely install 2 front alternator retaining bolts.
  2. Install the alternator bracket and 3 alternator bracket bolts. Tighten to 84 inch lbs. (10 Nm).
  3. Tighten 2 front alternator retaining bolts to 19 ft. lbs. (26 Nm).
  4. Connect 2 electrical harness connectors to the alternator assembly.
  5. Connect the positive battery cable and install the nut and washer. Tighten the nut to 72 inch lbs. (8 Nm).
  6. Rotate the drive belt tensioner away from the drive belt and install the drive belt on the alternator pulley.
  7. Connect the negative battery cable.
  8. Start the engine and check for proper charging system operation.
Jun 17, 2012 | 2008 Ford F 250 Super Duty 4WD
When changing the oil pan on a 2006 town & country do you have tighten the bolts in a sequence?
Removal & Installation
2.4L Engine
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Drain the engine oil.
  3. Remove or disconnect the following:
    Negative battery cable Structural collar A/C compressor bracket to oil pan bolt Oil pan
  4. Clean the oil pan and all gasket mating surfaces.
To install:
  1. Install or connect the following:
    Oil pan gasket to the block after applying engine RTV at the oil pump parting line Oil pan. Torque the bolts to 105 inch lbs. (12 Nm). Structural collar Negative battery cable
  2. Fill the crankcase to the correct level.
  3. Start the engine, check for leaks and repair if necessary.
To install:
3.0L Engine
    Negative battery cable Starter motor Front motor mount bracket Bending braces Torque converter dust shield Oil pan
    Fig. Oil pan mounting bolt tightening sequence-3.0L engine
To install:
  1. Clean the oil pan all mating surfaces.
  2. Apply RTV gasket material to the oil pan.
  3. Install or connect the following:
    Oil pan. Tighten the bolts in sequence to 50 inch lbs. (6 Nm). Torque converter dust shield Bending braces Front motor mount bracket Starter motor Negative battery cable
  4. Fill the crankcase to the correct level.
  5. Start the engine, check for leaks and repair if necessary.
3.3L & 3.8L Engines
    Negative battery cable Engine oil dipstick Drive belt splash shield Strut to transaxle attaching bolt and loosen the strut to engine attaching bolts Transaxle case cover Oil pan fasteners Oil pan and gasket
To install:
  1. Clean the oil pan and all mating surfaces.
  2. Apply a 1 / 8 inch bead of gasket material at the parting line of the chain case cover and the real seal retainer.
    New gasket on the oil pan Oil pan. Torque the bolts to 105 inch lbs. (12 Nm). Transaxle case cover All bending brace bolts Drive belt splash shield Engine oil dipstick Negative battery cable
To install:
May 05, 2012 | 2006 Chrysler Town & Country
1979 Yamaha 650 Special no spark
Hi, Fbigtank81 and the usual suspects are:
1. Fouled spark plugs.
2. Discharged battery, needs to be 12.5 volts or more and be able to pass a proper "LOAD" test, your battery may show 12.5 volts or more but has little or zero amps causing the battery to be faulty and must be replaced, AGM batteries fail in this category more so than lead acid batteries.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting/leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
79 xs650 Special No Spark But 12v help
How to diagnose no spark situation on motorcycle
Yamaha XS650SE Shop Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xs-owners-manuals
Jun 30, 2011 | Yamaha XS 650 C Motorcycles
Where is the voltage regulator located?
The voltage regulator is built into the Alternator.
May 13, 2011 | 2003 Ford Expedition
2000 f250 supercab. Engine light comes on. When you connect to a computer checks ok.
Hi, if your car engine light comes on and after connecting it to the computer it looks o.k, then you should try reseting the engine light by remove the positive battery cable from the battery post and leave it off for about five minutes. Then, reattach the battery cable to the battery. You can do this with a basic 1/2-inch or 9/16-inch wrench. Removing the battery cable will reset the "Check engine" light as long as there is nothing serious wrong with the engine.
Jan 28, 2011 | 2000 Ford F250 Super Duty Crew Cabs
Torque sequence for 1996 chevrolet van intake manifold with a 4.3 litre moter
Ha, you tried to fool me with the bit about a 3.5 L motor--I could find that one...here is the complete procedure from AutoZone.com:
Installation To install:
  1. Clean the gasket mounting surfaces. Be sure to inspect the manifold for warpage and/or cracks. If necessary, replace it.
  2. Position the gaskets on the cylinder head with the port blocking plates to the rear and the This Side Up stamps facing upward. Then apply a 3 / 16 in. (5mm) bead of RTV sealant on the front and rear of the engine block at the block-to-manifold mating surface. Extend the bead 1 / 2 in. (13mm) up each cylinder head to seal and retain the gaskets.
    0996b43f80208c7b.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Lower intake manifold tightening sequence-4.3L engines
  3. Install the lower intake manifold. Tighten the bolts in sequence and in 3 steps, as follows:
    1. Step 1: 26 inch lbs. (3 Nm).
    2. Step 2: 106 inch lbs. (12 Nm).
    3. Step 3: 133 inch. lbs. (15 Nm).
  4. Install or connect the following:
    Power steering pump Alternator bracket bolt near the thermostat housing Wiring harness to the lower manifold components, including the injector, EGR valve and ECT sensor Air conditioning compressor bracket-to-the lower intake manifold pencil braces
  5. Install transmission oil dipstick tube, if necessary.
    Fuel supply and return lines to the rear of the lower intake
  6. Temporarily reattach the negative battery cable, then pressurize the fuel system (by cycling the ignition without starting the engine) and check for leaks.
  7. Disconnect the negative battery cable.
  8. Install or connect the following:
    Heater hose to the lower intake Upper radiator hose to the thermostat housing Distributor assembly and engage the wiring Ignition coil Connect vacuum hoses to the upper and lower intake manifold. New upper intake manifold gasket, making sure the green sealing lines are facing upward Upper intake manifold Manifold retainers. Tighten them to 88 inch lbs. (10 Nm) using two passes. Purge solenoid and bracket Brake booster vacuum hose at the upper intake manifold PCV hose to the rear of the upper intake manifold Vacuum hoses to both the front and rear of the manifold assembly Throttle body Throttle linkage to the upper intake Wiring to the upper intake components including the TP sensor, IAC motor, MAP sensor and the fuel meter Engine cover Air intake assembly
  9. Connect negative battery cable.
  10. Refill the engine cooling system.
  11. Start the engine and check for leaks.
Aug 26, 2010 | 1996 Chevrolet Astro
Can't get the back plate of a Timex Indiglo WR30M watch back on
It is either a screw on case back or a "snap-on. I suspect that it is the latter since you don't mention that you used a tool to unscrew the case back. So getting the back on sometimes is very difficult. I have a special tool for that to apply even pressue and the necessary force and does not put pressure on the crystal. You have to be careful to not damage the crystal. If you don't get it done, then suggest you take it to a shop that has the right tool. If you have very strong thumbs you might get it done.
Dec 05, 2009 | Watches
Remove and replace alternator
2000 Ford Truck Expedition 4WD 4.6L EFI 8cyl
Alternator - REMOVAL & INSTALLATION
4.2L Engine
  2. Disconnect 2 alternator and voltage regulator electrical harness connectors at the alternator. To disconnect push-on type terminals, depress the lock tab and pull straight off.
  3. Remove the positive battery cable nut and remove the positive battery cable at the alternator.
  4. Rotate the drive belt tensioner away from the drive belt and remove the drive belt from the alternator pulley.
  5. Remove 3 alternator retaining bolts and remove the alternator.
To install:
  1. Place the alternator on the engine and install 3 alternator retaining bolts. Tighten the bolts to 18-22 ft. lbs. (20-30 Nm).
  2. Rotate the drive belt tensioner away from the drive belt and install the drive belt on the alternator pulley.
  3. Connect 2 alternator and voltage regulator electrical harness connectors.
  4. Connect the positive battery cable to the alternator and install the nut and washer. Tighten the nut to 84 inch lbs. (10 Nm).
  5. Connect the negative battery cable.
  6. Start the engine and check for proper charging system operation.
4.6L, 5.4L and 6.8L Engines
Fig. 1 Detach the connectors from the alternator
Fig. 2 Remove the nut and the battery cable from the post on the rear of the alternator
Fig. 3 Remove the 2 front alternator mounting bolts and ...
Fig. 4 Remove the alternator from the engine by carefully lifting it up and...
Fig. 5 ... out of the engine compartment
To install:
5.8L and 7.5L Gasoline Engines and 7.3L Diesel Engine
  1. Disconnect the battery ground cable.
  2. Label and detach the connectors from the alternator.
  3. Release the tensioner and remove the drive belt from the alternator pulley.
  4. Remove the alternator retaining bolts.
  5. Remove the alternator from the vehicle.
To install:
  1. Position the alternator and install the retaining bolts. Tighten the retaining bolts to 15-21 ft. lbs. (21-29 Nm).
  2. Install the drive belt.
  3. Attach the alternator connectors.
  4. Connect the battery ground cable.
I really hope help you with this (remember rated this help) Good luck.
Oct 13, 2009 | 2000 Ford Expedition
Cannot get into tomtom one v3
After the screws are out, just put something (I used a fingernail, but you might want to use something like a butterknife or a thin bladed screwdriver) between the silver front casing and the black back casing at the top front corner. Then gently pry until it separates. Do the same thing for the other top corner and the case should just pull loose. Be careful not to stress the cables connecting the speaker and the battery by pulling the back casing more than a few inches from the front casing (the battery and the speaker are attached to the back casing). The battery is held in place with sticky tape. Just disconnect the cable and gently pry it free from the sticky tape.
Mar 19, 2009 | Tomtom ONE 3rd Edition GPS
Changing the starter on my 99 tahoe
Starter Escalade, Suburban, Tahoe, Yukon, Denali, Denali XL, Yukon XL, 1999 – 2005 REMOVAL&INSTALLATION
4.8L, 5.3L And 6.0L Engines
CAUTION Before servicing any electrical component, the ignition key must be in the OFF or LOCK position and all electrical loads must be OFF, unless instructed otherwise in these procedures.
  2. Raise and support the vehicle.
    • Protective shields, as necessary
    • Starter solenoid shield
    • Starter-to-transmission close out cover bolt
    • Engine oil level sensor connection
    • On 4WD, front axle mounting bracket through bolt nut
  4. Reposition the front axle mounting bracket through bolt until the bolt tip is flush with the support bushing. Do not remove the bolt.
    • Mounting bolts from the engine block. Slide the starter forward until the starter clears the transmission.
    • Starter transmission close out cover
    • Positive battery cable and wiring harness from the starter
    • Starter from the vehicle 0900c152800a6916.jpgStarter removal—4.8L, 5.3L and 6.0L engines
To install:
    • Starter
    • Positive battery cable to the starter. Tighten the nut to 12 ft. lbs. (16 Nm).
    • Mounting bolts to the engine block and tighten to 37 ft. lbs. (50 Nm)
  2. Reposition the front axle mounting bracket through bolt until the bolt is fully seated.
    • Front axle mounting bracket through bolt nut and tighten to 70 ft. lbs. (95 Nm)
    • Protective shields as necessary
  3. Remove the safety stands.
  4. Lower the vehicle.
5.7L And 7.4L Engines
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Mounting bolts and shims
    • Wires
    • Heat shield
    • Starter
To install:
    • Starter
    • Wires. Torque battery wire nut to 89 inch lbs. (10 Nm), and ignition nut to 18 inch lbs. (2 Nm).
    • Heat shield. Torque the bolts to 53 inch lbs. (6 Nm) and the nuts to 35 inch lbs. (3 Nm).
    • Mounting bolts and shim. Torque the bolts to 33 ft lbs. (45 Nm).
6.5L Engine
    • Negative battery cables
    • Mounting bolts/nuts and shim, if used
    • Starter
    • Wires
    • Heat shield and bracket 0900c152800a6917.jpgExploded view of the starter motor—6.5L engine
To install:
    • Heat shield and bracket. Torque the bolts to 13 ft lbs. (17 Nm).
    • Starter
    • Mounting bolts/nuts and shim, if used. Torque the bolts to 33 ft lbs. (45 Nm) and the nut to 75 inch lbs. (8.5 Nm).
8.1L Engine
  1. Remove or disconnect the following:
  2. Reposition the front axle mounting bracket through bolt until the bolt tip is flush with the support bushing. Do not remove the bolt.
    • Positive battery cable nut
    • Positive cable from the solenoid
    • Engine harness ground nut and ground from the solenoid
    • Mounting bolts and starter
    • Heat shield bolts, nut and shield, if necessary
To install:
    • Heat shield, bolts and nut if removed. Tighten the bolts to 35 inch lbs. (3 Nm) and the nut to 44 inch lbs. (5 Nm).
    • Starter and bolts. Tighten to 37 ft. lbs. (50 Nm).
    • Ground wire and nut. Tighten to 30 inch lbs. (3.4 Nm).
    • Positive cable and nut. Tighten to 80 inch lbs. (9 Nm).
Sep 28, 2008 | 1999 Chevrolet Tahoe
Garmin StreetPilot c550 GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
