Question about Pioneer PureVision PDP-V402 40 in. Plasma Television
Connected xbox 360 to pioneer pdp428xd with hdmi cable but no sound?
5 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: connecting my comcast hd cable to my pioneer elite hd 1130
you will need the other cables. Hd tv won't work with the old school hookups. rca jacks' can sort out those frequencies
Posted on Jan 28, 2009
  • 668 Answers
SOURCE: TV wont detect HDMI Devices except a pc.
Something is wrong whith the HDMI jack it's self, or the electronic switching is not sensing a signal is present. In either case the board that has the HDMI jack you are using needs to be replaced. Most all these boards are double printed, Multi-layered or both which prevents replacing the jack it's self. I do have a question though, do you only have on HDMI jack on the unit or do you have another one available.
Posted on Jun 18, 2009
SOURCE: No sound with HDMI cable and Xbox 360
FROM THE TOSHIBA MENU, (FIRST MAKE SURE YOU ARE SET TO
THE HDMI PORT THAT THE XBOX IS PLUGGED INTO) THEN SELECT
HDMI SETTINGS, UNPLUG HDMI CABLE FROM THE TOSHIBA TV (LCD
FLAT, MINE IS A 42") WAIT FOR THE SETTINGS TO HIGHLIGHT OR NOT
BE GRAYED OUT, THEN TURN OFF THE THREE SETTINGS, FOR COLOR
AND LIP-SYNC., SCROLL DOWN AND PRESS THE RESET BUTTON,
WAIT FOR MESSAGE TO APPEAR. TURN OFF THE TV AND PLUG IN THE XBOX.
TURN EVERY THING BACK ON. SEE IF IT WORKS.
NOT ALL CABLES ARE THE SAME AND NOT ALL TVS ARE THE SAME.
READ THE TV OWNERS MANUAL CAREFULLY, (RTFM), I FOUND A NOTE ABOUT
THESE SETTING ON THE SPECIFICATIONS PAGE.
Posted on Jul 13, 2009
BElectric
  • 1140 Answers
SOURCE: Hi, I have a 43"
Your question has reappeared in the unsolved problems list as you did not receive a reply to your most recent message within FixYa's specified time period. I am not able to see what answers have been posted by other experts, but I am able to see your own comments, so it's clear that you've reached a fairly advanced point with whoever was helping you.
If you can let me know who the last expert you were dealing with is, I should be able to route this problem back to them so you can resume communication.
However, it seems that you are on the verge of spending money on repairing this TV, but this may be a little hasty. If you have not already done so, you should reset the TV to factory default settings and "reboot" the firmware, then reinstall.
1. Switch the TV to STANDBY/OFF and disconnect all cables;
2. Switch the TV on again;
3. Press HOME MENU;
4. Select SETUP and press ENTER;
5. Select DTV SETUP and press ENTER;
6. Select INSTALLATION and press ENTER;
7. Enter your password or the default password - 1234 - if you have not set one;
8. Select RESTORE SYSTEM DEFAULTS and press ENTER;
9. Highlight OK and press ENTER to confirm the system reset
The system will be restored to the factory defaults and the INSTALLATION screen will appear.
10. Switch the TV off and disconnect from the power supply;
11. Re-attach all cables to the correct sockets;
12. Switch the TV on again and run through the INSTALLATION
13. Run through the external inputs and check the audio from Sky and X-Box.
If this doesn't work, then you definitely have a fault with the HDMI audio input circuits, but more often than not, loss of audio is due to a firmware crash and can be resolved by resetting the TV.
In addition before spending any money, consider alternative connections. SCART will not support an HD signal, however COMPONENT and S-VIDEO connections will. You will need to check your other devices to determine whether they have the correct outputs and whether you have sufficient inputs on the TV.
Component sockets will be labelled Pr/Cr Pb/Cb and Y and will also require a separate 2 plug AV cable for audio or a digital optical cable. S-VIDEO also requires a separate 2 plug AV cable for audio or a digital optical cable. However, this model only has a S-VIDEO socket under the flap on the front, so you probably don't want to use that permanently.
You stated you had no audio from the INPUT 2 sockets, but these are the COMPONENT IN sockets and therefore require a separate audio cable. You didn't make it clear whether you had connected one of these.
Please try the above if you have not done so already and then let me know if you need further assistance. If you would like to continue your discussion with whoever was assisting you before, you will need to let me know the expert's name for this as I am unable to see who it was helping you.
Hope this helps.
Regards,
BElectric
Posted on Feb 16, 2011
How do I get sound from my Xbox to my monitor via a hdmi lead - DVD lead
As far as I know, the DVI cable can't send sound, so if you could use a only-HDMI cable or SCART cable, that should give you both picture and sound.
Nov 11, 2012 | Microsoft Xbox 360 Console
Xbox 360 working thru HDMI working fine. Now no sound & weird pic
it is prolly an internal problem. have to tried connecting the componet cables?
Mar 03, 2010 | Microsoft Xbox 360 Console
No Xbox image via HDMI
the only thing i can think of is that you havent flicked the switch on the hdmi cables wher the plug into the xbox from tv to hdmi, if you have the go ahead and get it replaced
Jan 04, 2010 | Microsoft Xbox 360 Elite Console - Black
I am using my xbox 360 via HDMI, and I have a 5.1 surround sound system hooked up via RCA output from the tv. If I switch it onto the coax input it works, but when I switch to HDMI it doesnt. Is there a...
no, there's no firmware upgrade that you can do on the tv. the reason for that is because you are sending digital sound to the tv with hdmi from xbox 360,and when you have rca cables connecting your tv and surround sound, the rca cables provide stereo sound. what you need to do if you want to use hdmi is connect optical cable from tv orxbox 360/ or tv to your surround sound to get digital sound, and it will sound better digital sound.
Apr 17, 2009 | Samsung SlimFit TX-S3082WH 30" TV
Cannont connect Ear Force X3 with my HDMI set up .
Is the problem that you're using a single HDMI cable to connect your Xbox to your TV? If so, this Turtle Beach article should help... ________________________________________
HDMI and Connecting Ear Force Xbox Headphones
The current Microsoft Xbox 360 series of gaming consoles allow the use of HDMI cables for simpler hookup to home theater systems and Hi-Definition televisions (HDTV).
The Xbox 360 Elite (the black one) comes with two additional cables, an HDMI cable and a separate AUDIO cable that provides a pair of RCA jacks (red and white) and an optical digital audio output (S/PDIF Out). With this cable package, you can easily connect any of our X-series headsets and an HDMI-connected television at the same time.
This Xbox 360 HDMI Cable package is available as an extra-cost option from Microsoft: http://www.xbox.com/en-US/hardware/x/xbox360hdmiavcable/
Here's a more in-depth explanation of the Xbox 360 HDMI Cable and how it works: http://support.microsoft.com/kb/937899?sd=xbox
[NOTE 1:] The standard Xbox models do not come equipped with this cable set. The HD cable they have obscures the HDMI connector, so that the two sockets cannot be used at the same time. If you only have this stock HD connector (component video, composite video, stereo analog audio and optical digital audio connectors), then you will not be able to use the HDMI connector at the same time.
In order to use both sockets at the same time (HDMI and A/V) you'll need to purchase the Xbox 360 HDMI Cable package described above.
[NOTE 2:] The current Xbox 360 Elite Holiday Edition (Fall 2009) does not come with the HDMI Cable set.
___________________________________________________________________
Some companies make aftermarket HDMI cables for use with the Xbox 360, but these may not provide the dual RCA jacks that carry the 2- channel analog audio necessary for hookup of the anlog-only Ear Force X-series headsets. If this is what you have, you may need to find another way to connect your Ear Force X-series headset.
The TOSLINK digitally-connected X-series headsets can be always be connected using optical digital "Toslink" connections (and that's the best way to use them!).
The oldest white-and-gray Xbox 360 models DO NOT have an HDMI port. With this particular (obsolete) model, you cannot use HDMI connections, but you can use any of our X-series headsets.
Current Xbox 360 models all have separate HDMI and A/V ports ("sockets") on their back panels.
Here are some suggestions for alternative connection schemes:
XBOX 360 AUDIO PLAYS THROUGH TELEVISION SET:
For X4 and X41: Your best bet would be to connect the Xbox optical digital audio out to the X4 transmitter's optical digital input. Then connect the X4 optical digital output to the optical digital audio input on your HDTV or home theater amplifier.
[NOTE:] Some HDTV systems have an optical digital audio output that will not transmit Dolby Digital/DTS encoded digital audio, only stereo PCM audio will be passed. In this case, you must connect as above.
For X2, X3 and X31: You can use the Headphones jack or the Audio Out jacks on your TV to connect to the Audio In jack on the Transmitter.
For X1 and X11: You can use the Headphones jack or the Audio Out jacks on your TV (if available) to connect to the headset's analog Audio Input.
NOTE: Please make sure your TV has Audio Out jacks. Some TV's only have Audio In jacks.
Audio In jacks only accept incoming audio signal; they do not send audio signal out. If no audio signal is being sent to the headset, no sound will play from the headset.
You may need to purchase a suitable adapter cable in order to connect the TV audio output(s) to the Ear Force X-series headset's transmitter or Audio Input plug.
- Connect the HDMI cable so that the Xbox 360 plays its audio through the TV.
- For X1, adjust the Dashboard > Settings > System > Voice in the Xbox 360 so that the talkback and game sounds are played together (Play Through Speakers). - For X3, X31, X4 and X41, you should set this to Play Through Headset.
XBOX 360 AUDIO PLAYS THROUGH HOME THEATER RECEIVER (except X4 and X41): This is exactly the same as the above, except that you will use the receiver's Headphones output jack to connect to the Audio In on the Ear Force Xbox-compatible headset's Transmitter (X2, X3, X31) or the green Audio Input plug (X1).
- You may need to obtain a shielded audio cable with 1/4" stereo phone plug to 1/8" stereo mini-phone plug ends. The 1/4" phone plug goes to the receiver's Headphones jack, while the 1/8" mini-phone plug goes to the Audio In on the Ear Force Transmit- ter (X2, X3, X31) or Audio Input plug (X1).
- Adjust the Dashboard > Personal Settings in the Xbox 360 so that the talkback and game sounds are played together (Play Through Both). For X3 and X31, you may also set this to Play Through Headset.
Mar 13, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
No sound from my xbox 360
You cant have HDMI and the xomponent cables pluged in at the same time.
to get audio to your monitor you will need an xbox 360 audio adapter. You can find that here. http://www.xbox.com/en-us/hardware/x/xbox360hdmiavcable/default.htm
That comes with the HDMI and audio adapter.
You can probabaly find it seperate somewhere else.
I hope this helps.
Dec 29, 2008 | Microsoft Xbox 360 Console
Component to HDMI
why dont u connect the xbox directly to the tv via HDMI cable? the output will be fantastic.The component cables just cannot give a better resolution than HDMI.
As for connections,i am not in favour of component and HDMI together.
May 18, 2008 | Pioneer VSX-92TXH Receiver
Xbox 360 sound problem
HDMI carrys no sound you still need to have the audio cables from the component plugged into the tv. If this doesnt do the trick you should call MS or check your TV's settings maybe there is a special function when using that resolution. Hope this helps.
Jan 02, 2008 | Microsoft Xbox 360 Console
Pioneer PureVision PDP-V402 40 in. Plasma Television Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
