Question about Car Audio & Video
Battery went dead in my bmw its ok now, radio not workin need code for 1998 R reg bmw E42 318i. can u help
  • 4,836 Answers
These older BMW radios require further special advice in order to see if a code is available.
Try asking here and mention this forum CLICK HERE
Posted on Apr 02, 2011
I had someone change the radio in my 1998 camry and it did work. My battery went dead, dead and once I replaced battery the radio now doesn't work. Why>
Car radios have security codes to prevent them from being stolen. If they lose power, such as when replacing the battery, they lock out. This makes them worthless to anyone trying to steal them. You need to have the unlock code to reactivate the radio. It is provided with the vehicle at purchase, or by the retailer when selling replacements
Mar 28, 2015 | 1998 Toyota Camry
The original radio and wipers of 1998 BMW 3181just went off.
Check your fuses. If moisture or a power surge happen recently it's pretty common. NOTE have your radio code handy, you'll need that to get radio up and running.
Mar 08, 2011 | 1998 BMW 7 Series
Car battery went dead and need to find out how to enter code for 1989 BMW car stereo
go to your dealership and give them the make, model, and year of your car. next give the the serial number of the radio( should be in the glove box on a label. explain to the the problem, and they should be able to look up the 5 digit code for you(most dealerships do this for free). when you go to enter the code, the radio must be powered up for one hour before entering the code(in case of theft). I hope this helps you
Jan 15, 2011 | 1989 BMW 5 Series
Batteryis dead
Need more info - How old is battery? can you jump start? etc. If you can jump start it, take it to a local parts store like Autozone, Advance, etc and have them test your charging system and battery. Note if battery went dead, you're going to need your code to re-activate your factory radio.
Jan 05, 2011 | 2001 BMW 5 Series
I have a 2001 daewoo lanos and the battery went dead and now the radio is saying it needs a code to work. do you know that code or how to find it?
This code should be in the glovebox on a small card the size of a credit card. if the code is not found you will need to remove the radio and get the serial # off the radio then go to dealer with the reg and id to prve ownership and they will give it to you, hope this helps.
Nov 08, 2010 | 2001 Daewoo Lanos
Vauxhall astra s reg
One of two things has happened
Because your battery went flat and you then created a short circuit the radio may be locked out and need a start code which should be in your manual
Worse case is that by applying a reverse polarity to the radio you have blown the protection diodes up inside it, if so it is a back to the maker job
Aug 19, 2009 | 1996 BMW 318
BMW 318 would not start this morning Error code 2BOA?
I think you need a new battery.
Replace it and the radio will probably reset ok when you input the code..
Jul 09, 2009 | 1996 BMW 318
I have a 2001 BMW Z3. The battery went dead last
most new BMW's the fuse block is located behind the glove box. There should be a pair of twist plastic fastners at the back of the glove box, twist and remove the plate and you should find the fuse box and fuse locater list.
May 12, 2009 | 2001 BMW Z3
Bmw r 1100rt 1998
Check the battery with a voltmeter. If it drops below 11v while the key is on or you are trying to start it the battery is faulty. You can also try connecting jumper cables (I would do so without the donor vehicle running), if the instruments & lights work while cables are connected your battery is the problem.
Mar 01, 2009 | 1998 BMW R 1100 RT (ABS)
Car Audio & Video Logo
160 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
