Question about Hoover Vacuums
My hoover S3765 cannister vac has a problem with the vacuum beater brush. It spins on hard surface floors but when it's on carpet it stops. If I lift up the vacuum head while I vacuum the brush spins. I checked the belt and it's in good shape. What could the problem be?
SOURCE: Powerhead woes
I've had my Hoover S3755 for about 2 years and loved it, at least until the last couple of months when the "belt slipping off" problem started. I changed the belt and the vacuum would work for a little while then the belt would come off again. I put on a new belt again and within minutes the belt had slipped off. I took it to my local vacuum repair about 4:00 in the afternoon. By 4:45 I got a call from the repairman that he'd fixed my vacuum! What did he do? He put a different belt on it. He put a Rainbow belt on my Hoover that's thicker and doesn't have as much "give" as the Hoover belt. It's also a little bit wider than the Hoover belt. Now when the brush slows or stops at a carpet edge the belt doesn't slide off.
Posted on Jan 31, 2009
renevacdoc
  • 84 Answers
SOURCE: Need Hoover cannister vacuum floor brush & filter bags
yes attachment are available just bring your wand into your local vacuum store to insure the proper fit
Posted on Nov 04, 2009
Vacuum Guru
  • 78 Answers
SOURCE: The brush turns when the vacuum is lifted up, when
Over time your belt stretches between 10% & 25% and once it stretches like this it will only run ok when there is no resistance. As soon as you put the belt under load (ie carpet) there is not enough tension to keep the brush turning. What you need to do is fit a new belt and all will be good again.
If you need parts I would recommend nelson vacuums or vacuumspot if you are in Australia.
If this has been a helpful answer for you please take a moment to give me a comment or a testimonial.
Happy Vacuuming :)
Posted on Dec 09, 2010
Andriod Man
  • 271 Answers
SOURCE: The carpet brush won't revolve
this is the part for the belt, 38528036. you can get it at sears website or service center. also make sure you clean the caps on the side of the brush. take them out and remove hair and dirt. put a little or mineral oil and install them back.
good luck to you.
Posted on Feb 08, 2011
  • 240 Answers
SOURCE: Hoover WindTunnel S3765. The
The belt is stretched and needs replacement.(Belt # 38528036) . The brush is not turning against resistance.
Posted on Feb 23, 2011
I have a brand new hoover canister s3755 and the beater brush will not turn on the carpet it spins fine as soon as you lift it slightly off of the floor, I can't imagine it is the belt as the mac
It's commonly the belt when they're new. More explained here:
http://www.vacuummedic.com/blog/2012/10/09/my-brand-new-vacuum-doesnt-work/
Call Hoover and complain, they'll likely send you a new one. The service centers will not be able to give you a belt under warranty as it is a "wear" part.
Feb 21, 2013 | Vacuums
Sebo k3 won't vac on carpet...only hard floor
Do you mean the beater bar stops turning and then it doesn't vacuum?
Or it shuts off when you jam it full of carpet? Read the below manual:
http://www.sebo.us/pdfs/website_owners_manualsPDFs/AIRBELT%20K%20Manual.pdf
Aug 27, 2012 | Sebo Air belt K3 Bagged Canister Vacuum
The carpet brush won't revolve on the Hoover S3765. After 5 months I replaced the belt and the salesman gave us model 38528-036. Is this correct? The rotating brushes are not hard to turn; it's just...
good luck to you.
Feb 08, 2011 | Hoover S3765-040 WindTunnel Bagless...
Bought a new sweeper and brush ( beater bar ) does not turn. The large belt is fine and turns. The small thin belt is also fine but does not turn the brush. It is either the wrong belt or is there...
Jim, To put tension on the brush, tilt machine forward when upright, move carpet selector knob to carpet. then turn vac on. Brush will only spin when vac is tilted back to operate. brush stops when upright and on to use hand tools so the er is no danger to carpet or persons with moving roller.
Sep 29, 2009 | Hoover U6630-900 WindTunnel Bagless...
Hoover makes terrible screaching sound when using upright.
It's most likely the bushings/bearings in the beater bar (roller). The beater bar cover is fairly easy to remove -- take it off and investigate. Could be that the roller only needs lubricating on the ends. Also, check the belt to see if it's intact or damaged.
Clean area thoroughly.
If this is not the problem, please, let me know.
Charlie
Aug 26, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hoover Tempo Widepath Blows Dirt Out Back on Hard Surfaces
lots of times switching to hard surface floors you need to slow down because the air flow that does the actual picking up of the dirt can't work as fast as the spinning brush so the brush is throwing the dirt out the back before the suction can pick it up. Try slowing down
Jun 11, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Hoover 5470-900 no longer contacts carpet with beater brush
your floor adjustment spring is broken there is a plastic slider and clip if it is broken the height adj will not work you should get a new vacuum because this repair can cost as much as a new vac.also this is a common problem with the hoover brand I would get a sebo or an oreck they have a great warrentty and you will more than likly never buy a other vac.
Jan 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Problems with the Hoover Steam vac Heated carpet cleaner
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter.
Nov 18, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
141 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
