Question about Neff Microwave Ovens
New Ceramic Hob T44T9ono 4.4 KW Ceran . No user Instructions
2 Suggested Answers
dcramer531
  • 1654 Answers
SOURCE: I have a cata ceramic
When you turn on the hobs main power, press the the rear left hand element pad at the same time and the lock will come off.
press the centre minus button and the bottom right plus button at the same time it will work if not keep trying
You have to hold down the centre sensor button with the minus on and the sensor which turns on the bottom right ring immediatley after turning the hob on. It should unlock, then press the minus again
the hob switchs off
when you now switch on there will be no lock
Posted on Feb 04, 2011
Replacing the ceran glass maintop
Actually if you've removed the 2 or 3 screws at the front (underside) of the cooktop, you can lift up the front. Prop it up with a board, and then remove the 4 screws that hold the 2 brackets that hold the 4 elements to the cooktop. Now pull the cooktop forward a bit, and you should see a green ground wire attached to the back of the cooktop. If not, then don't worry about it! Just pull that cooktop up and off the range. You will need to transfer the 2 tabs in the back of the cooktop, and the silver steel bar located at the front of the top to the new cooktop. Then reverse the process to install the new cooktop and re-fasten the elements to it.
Apr 22, 2014 | Kenmore Microwave Ovens
Hi, We have MAYTAG schott ceran flexchoice glass cooking top. Even after cleaning it with a ceramic glass top cleaner,stains are remaining on it. Can u please suggest what is the best way to clean it .
Sudha3025 -
Sorry to hear you're having trouble getting your cooktop clean.
You mention you are using a glass-ceramic cleaner but I would also suggest scrapping the stains with a NEW metal razor scraper. A cooktop scraper is similar to one you would use to scrape paint off your windowpanes at home and you can typically find them at a hardware store. The razor won't damage the surface like other abrasive sponges might. For best results, hold the scraper at approximately a 30 degree angle to the cooktop and protect your hands by wearing an oven mitt.
Also try using a Wieman sponge in conjunction with the cleaner on those stubborn stains.
As always, try to clean up spills, especially sugary ones, immediately when they happen, or get them away from the hot burner area and clean after every use.
Hope this is helpful!
Apr 07, 2011 | Maytag Microwave Ovens
I HAVE A STOVES CERAMIC HOB 700CTH THAT IS SHOWING A FAULT 7A IS BEEPING AND FLASHING ON PLEASE CAN YOU HELP
The fault is on the PC board, capacitor C17. It can be replaced if you are handy with these things. Remove the hob and dismantle it to gain access to the PC board without turning it upside down. There are several screws which have to be removed, there are 13 spade connectors on the PC board, label these and remove them carefully. The capacitor has to be un-soldered and the new one fitted with the polarity the right way around. If this is not within your capabilities and you do not have the correct tools, have someone do it for you for a few dollars. A call-out for this fault could run into the $400 bracket and the part costs about $1.50.
Feb 08, 2011 | Microwave Ovens
I have a cata ceramic hob. the child lock has been engaged & is restricting operation of any of the 4 hob's
the hob switchs off
Feb 04, 2011 | Microwave Ovens
Can I gaet a new glass top for a Diplomat HJA 1613 ceramic hob?
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Jan 05, 2011 | Bosch Microwave Ovens
Replacement ceramic hob element C00228943 for Creda EDCW60 has 4 connections on thermostat in place of 2 on old unit. Do you have circuit diagram for this replacement element please?
Sounds like it is the wrong element. I wouldn't like to advise further without seing it. Contact your supplier and ask for an explanation.
Dec 24, 2010 | Panasonic NN-P794SF Microwave Oven
Good morning we are staying in a house of friends who are on holiday. I would like to clean the Bosch Ceran top but I am not sure which cleaning stuff I can use. Is the use of CIF creamer allowed with a...
Harry -
I would first see if your friend has a special ceramic cleaner in his or her cleaning supplies cupboard. If you can't find a ceramic cleaner, the best thing you can do is use hot water to clean the surface. All-purpose cleaners (like Cif) can damage the ceramic glass so it's best to avoid using them.
Also, look in your friend's cleaning supplies cupboard for a metal razor scraper. Use the razor scraper to scrape off any burnt-on food or spills. Do this by holding the scraper at approximately a 30 degrees angle to the cooktop while wearing an oven mitt to protect your hands. If no scraper is available, don't resort to a knife or abrasive sponge as these could damage the ceramic glass.
When the cooking surface is cool, apply a few dabs of the ceramic cleaner (if you found it) in each burner area and work the cleaning cream over the cooktop surface with a damp paper towel. Then wipe down with water and dry with a clean paper towel.
If no ceramic glass cleaner is available, it is sufficient to wipe down with hot water and a soft sponge. Never use abrasive sponges or scouring pads on ceramic glass cooktops. Also watch out for corrosive cleaners such as over sprays, cleaners containing chlorine or ammonia and stain removers - these will just further damage the surface.
For a list of approved CERAN cleaners see here: www.schott-ceran.com
Oct 28, 2010 | Microwave Ovens
Microwave Ovens Logo
55 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
