Question about Craftsman 25cc Gas Line Trimmer
I have a sovreign 25cc trimmer and was wondering where the idle screw is on it any ideas
    Genius:
  • 1,267 Answers
Go to the Sears URL page listed and click on the sears number you find on your string trimmer and see the exploded parts of that model.
http://www.searspartsdirect.com/partsdirect/brands-products/Craftsman-Parts/Grass-trimmer-weed-wacker-Parts
Posted on Apr 02, 2011
Poulan p2500 carb adjustment
Carb not set correctly. Screw down idle an fast run screws an then reset. Sometimes fuel gets clogged an needs adjusting
Jul 04, 2014 | Poulan 25cc 2-Cycle Gas Powered String...
Craftsman trimmer 25cc
Diaphrams can be tricky sometimes...seating can be irritating. If carb disassembled and cleaned out...might have to check adjustments. Make sure screw didn't get loose. I had one do that before when governor broke.
Apr 21, 2014 | Craftsman Convertible 25cc. Gas Line...
Setting the rpm
To identify the idle screw adjustment push in and and out with the gas throttle handle and look at the carburetor for a little finger that moves in unison with your movements. That finger comes to rest against a tapered screw - the latter is the idle adjustment. Clockwise increases the speed and vice versa. Adjust so unit runs smoothly at low speed - too slow and it will stall. Experiment.
Nov 22, 2013 | Craftsman 25cc Gas Line Trimmer
GHT 225 Trimmer Replaced primer bulb, Starts OK but, will not keep running.
Try adjusting the low side screw on the carb. Back it out about 1/8 of a turn at a time until engine continues to idle. If this this doesn,t solve your problem then you will have to disassemble the carb and replace the diaphragms and fuel filter screen.
Nov 26, 2010 | Poulan Ght225 25cc Gas Hedge Trimmer
How do i set idle for 25cc gas trimmer?
look on the carb for two screw's sticking out they should have plastic guards on them just take them off and adjust the set screw's until its right it should smoke very little when right and not run very fast!!!
Aug 18, 2010 | Craftsman 25cc Gas Line Trimmer
Sluggish gas trimmer
Make sure you have a good gas to oil mixture, My 25cc 1999, is 50:1, Be sure you're not sucking air from faulty fuel lines or fuel line connections. Make sure the air filter is clean, and oiled if it requires oil. Turn your idle screw in till it stops, then start at 1 1/4 turns out, and then an 1/8 of a turn at a time if all else has been checked and is well... You will adjust the idle screw till you can Idle without giving it gas, (after the engine is warm)... If you have a high air/fuel mixture screw, screw it in until it stops.(Do not over tighten). Screw out 1 1/4 turns... Adjust these two screws 1/8 of a turn at a time until there is power all the way through the RPM range. Oh... And check your plug... if it is wet or black and sooty , then clean or replace it, it should be a golden brown with no soot.
Jun 17, 2010 | Homelite Mighty Lite Lawn Trimmer
Poulan Pro PPB250E trimmer won't idle
clean and repair carb, make sure the mounting gasket is ok. and does not have a vacuum leak.
May 28, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Engine quits when throttle is opened
Most weed eaters are two stroke. You have a high and low idle screws on the carburetor. Assuming you have the right fuel mixture. Turn both screws in lightly until seated. Turn two turns out. You should see an h for high and l for low. Stat with low screw first turn in or out until running smooth. Then do the same with high idle screw holding full throttle. Once running smooth in high . Go back check low idle. Should run fine after this. Also check plug see if carbon fouled.
May 21, 2010 | Craftsman 25cc Gas Line Trimmer
358-791010 2 cycle starts bur engine runs so fast...Is there an adjustment? Also, I have no owners manual, that would be very benificial.
There is an idle adjustment screw that adjusts the idle speed of the weed whacker on the carburetor.
Look for the throttle cable, and there should be a screw adjustment in the area where the throttle cable hooks to the carburetor. It will normally adjust with a screwdriver, turn the screw one way and see if it speeds up, if so then adjust the screw the other way to slow the idle speed down.
I hope this helps,
Please Rate Me
May 02, 2010 | Craftsman 25cc Gas Line Trimmer
Poulan trimmer wont idle
Sounds like the carb needs adjusted. Unfortunately, it takes a special tool now to fit the adjustment screw(s). A shop should be able to do that for you.
Jun 12, 2009 | Poulan Garden
Craftsman 25cc Gas Line Trimmer Logo
132 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
