Question about Yamaha PSR-S700 ARRANGER WORKSTATION Keyboards/Midi
I have a Yamaha PSR-S700. Recently, the touch sensitivity in one of the keys stopped working. Very little pressure applied would cause the note to sound as if the touch sensitivity was off completely. Now the key has stopped working completely and the action feels different to the other keys. The keyboard has never taken any knocks or been damaged in any other way. The key in question is an 'A' key which is commonly used, but no more so than many other keys. Just wondering if anything can be done about this problem. Thanks in advance for your help.
  • Yamaha Master
  • 5,603 Answers
You MAY be confusing touch sensitivity with VELOCITY sensing. Touch sensitivity is PRESSURE put on AFTER the note sounds that causes modulation. VELOCITY is what is used for example to control the loudness of pianoo notes depending how fast they are struck. VELOCITY sensing is done by using TWO contacts at every key... one closes first. IF one of these gets dirty, FULL velocity will be sensed and it will be LOUD. The contacts can be cleaned using ONLY 99% isoprophyl alcohol and Qtips after MUCH disassembly of the keyboard. The contacts are conductive rubber pills in silicone rubber domes. Clean boththe contacts and the circuit traces they pres down onto.
Posted on Apr 02, 2011
My yamaha psr s 700 changes sound sometimes hand with all d bottons Woking if I start d keyboard all botton will not come up util 20mins after switched off plz I really a solution cus im so tired
lots of issues there
will need taking apart to find the faults and repair
some possibles
power source input low
internal circuity faults
switches
dry solder
diode faults
internal dust build up
One of Yamaha's new arranger keyboards, the PSR-S700 is the more entry-level model, but still comes with a range of impressive features:
  • 61 touch responsive keys
  • 96 notes of polyphony
  • 5.7-inch QVGA LCD capable of lyrics and score display
  • AWM (Advanced Wave Memory) sample sounds
  • 813 preset voices made up from 317 voices, 16 drum kits, 480 XG voices
  • 10 MegaVoices
  • 11 Sweet! Voices
  • 18 Cool! Voices
  • 14 Live! Voices
  • 9 Organ Flutes
  • 2 layer voices
  • Large number of preset and user-definable effects including reverb, chorus, 4 x DSP (Digital Signal Processing)
  • 205 preset 8-part auto-accompaniment + user category with mixer controls
  • 16 track recording
  • 30,000 note capacity
  • Performance assistance technology
Sep 15, 2016 | Yamaha Music
Yamaha PSR-S700 reset
Press the last note (right side) while powering your s700 ,this will reset your settings.
Jul 04, 2014 | Yamaha PSR-S700 ARRANGER WORKSTATION...
I would like to know which transformer I can use with the Yamaha PSR 260? How many AMP's? Volts I know are 10-12.
You should be using the Yamaha PA-3B adapter. The unit draws 9 watts... so at 10 volts a 1 amp adapter would be great. Make sure the polarity is correct.
Sep 07, 2011 | Yamaha PSR-295MS Portable 61-Key...
I'VE A YAMAHA PSR S700. The problem is with it's screen. Whenever i start playing, the screen fades and then it comes and it goes and vice versa. This occurs almost two - three days a week. There...
Likely a connection to the backlight is being broken. Tap on the unoit and see if it pops back on. Illuminate screen with a flashlight and see if the characters can be seen when screen is faded. If they can, then the backlight is the problem... IF NOT then the display may be bad... This has been a problem and if you are under warranty, excersise it immediately... else replacement of the display is relatively expensive.
May 28, 2011 | Yamaha PSR-S700 ARRANGER WORKSTATION...
The keys are broken and some at no sound can I order the notes and sound kit. Yamaha PSR-295 . Regards Elias
Hi, i think you can. You can go to any of the Yamaha companies around you area and explain to them the problem of the keyboard. They will give you good and quality replacement part for your Keyboard.
Make sure you go to only Yamaha company to avoid getting a wrong part for your Keyboard.Avoid road siderepairsforissue like this,it's more complicated to handle
I guess that will do.
Thanks for using fixya...
Jan 12, 2011 | Yamaha PSR-295MS Portable 61-Key...
I have yamaha PSR-i425 keyboard.can i conect it with my pc to play midi files stored in computer memory?
Yes. You will need to have a MIDI interface on your OC and also select in the sounds control panel of windows that you are using the external synth. The MIDI will expect the PSR to respond to the "general MIDI" assignments.
Sep 08, 2010 | Yamaha YPT400 61 Key Portable Keyboard...
Yamaha psr 400 give an Er 1 message when switched on and gives no sound when played. The demo works however
Wild guess of possibilities.
1. Internal backup battery exhausted.
2. Button OR key is stuck down, either mechanically or electrically.
Jan 06, 2010 | Yamaha Portable Keyboard with 61...
Yamaha PSR-79 keyboard fried fuse
i have the same problem please someone help us.
Sep 10, 2009 | Yamaha Portable Keyboard with 61...
Yamaha PSR-S700 ARRANGER WORKSTATION Keyboards/Midi Logo
530 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
