Question about Samsung Microwave Ovens
When I push on start..........the microwave freeze ....and become in the mode where I just plug it in. Some time after several push it cook normally. But most of the time it freeze
  • Samsung Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 .//../
Posted on Apr 02, 2011
How do I change temp and time while food is cooking?
all is explained in the user manual
if you have just put food in the even and pressed the start several times to get a number of minutes to cook but want to increase that time just press start again the number of times that you want the cook time to increase
for example :-
you put a frozen pie in the oven and your start operates in 30 second increments and you have pushed it 3 times and it starts cooking-BUT - you read the cooking instructions and it says cook for 4 minutes, just press the start another 3 times while it is cooking
the new cook time will show on the display
Dec 30, 2016 | Microwave Ovens
How do I get out of demo mode/
  • Push the "Clock" key underneath the "Warm" key on the control panel three times.
  • Check that the display shows the time, then program the microwave to cook food as desired.
  • Read more : http://www.ehow.com/how_7262577_cancel-mode-panasonic-microwave-c994s.html
    Apr 17, 2015 | Panasonic Genius Prestige Over-the-Range...
    My microwave GE model # JVM1440WH04 spacemaker has no heat coming out of it. My husband heated microwave lasagna in it last, everything works except for the heat, any solutions?
    Push the microwave door tightly closed. The computer will not start cooking until the door is closed for safety reasons. Some models of microwave will give a warning on the screen if the door is open.
    Ensure you have programmed a heat setting, entered a cooking time and pressed the "Start" button on the microwave's keypad. Check that the microwave is not set to "Defrost" mode.
    Unplug the microwave and wait for one minute. This measure will reset the microwave's internal computer if it has frozen or scrambled. Plug the microwave back in and try again.
    Ensure the keypad lock mode is inactive. Most microwave ovens have a lockout feature that prevents children from starting the microwave while unsupervised. Lockout mode is usually deactivated by holding down the button that bears a padlock symbol
    Oct 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
    My microwwave is not heating,
    Hello
    Ensure the keypad lock mode is inactive. Most microwave ovens have a lockout feature that prevents children from starting the microwave while unsupervised. Lockout mode is usually deactivated by holding down the button that bears a padlock symbol (like the "Start" button in the photograph).
    Oct 05, 2011 | Sanyo Microwave Microwave Oven
    My microwave/convection oven will not heat up, but the lights and clock work
    Hello
    Look to see if the microwave power cord is securely plugged into a live power outlet. The power cord cannot be loose for proper function. Move other appliances to a separate outlet if possible.
    Replace or reset the circuit breaker or fuse if blown or tripped.
    Unplug the microwave and wait several seconds before plugging it back in to reset.
    Make sure there are no current functions in use. Press "Clear/Off" to cancel any other settings or programs already in progress.
    Select a new cooking program and then select "Cook Time." Make a time selection and press the "Start/Pause" pad to begin cooking.
    Oct 04, 2011 | Microwave Ovens
    My oven is not heating anything although everything else seems to be working fine. Your site said i may need a multi tester, what is this and where might i find one cheap.
    Microwave actual serial # FMC B11 5GM. We had this microwave set on push a one and cooks for one min. push a two and so on.. in a rental house with people who aren't electronic savy. I pushed a...
    The owner's manual will help you, I'm sure.
    If for some reason you don't still have yours, you can download Frigidaire owner's manuals and installation instructions here.
    Sep 26, 2011 | Frigidaire FMCB115GC Microwave Oven
    Microwave doesn't work
    Sounds like you have a faulty control panel. I would use a meter and test the power from the control board to the magnetron and circuit board. Chances are the control panel is faulty
    Jul 25, 2010 | GE Microwave Ovens
    The timer counts down but the microwave doesnt turn on.
    I have a FNCB115GC Microwave problem. The microwave has a icon on the left hand side of the panel that looks like a opened book on a stand with lines on top. This is best that I can descibe it. The microwave turntable does not move or the microwave does to come on but the light comes on and the timer will count down. I have cleared the microwave and unplugged it with no results. Please help. Thanks in advance.
    Jun 03, 2010 | Frigidaire FMCB115GC Microwave Oven
    My mother just bought an Emerson MW8119 Microwave and can't figure out how to only set say 15 seconds cook time. Is it possible?
    Hi! I just purchased the same microwave, and came online to find the solution. I was then able to find the correct answer to this problem. On this model, Emerson does not put a "time cook" button for odd cook times such as 15 seconds. Instead, they have you push the "Power Button" prior to setting the cook time.
    If you want to cook on full power, press the power button once, and then enter your cooking time and press start. If you want to cook on 50% power or 30% power or something like that, push the "Power Button" several times until the appropriate power level is displayed, then enter the cook time and press start.
    The reason that it starts up right away when *********** pushes the 1 button is because Emerson has the quick cooking feature for 1 minute through 6 minutes. You only have to push the number once to get the 1 minute cook time or anywhere through 6 minutes respectively.
    Hope this helps!
    Jun 22, 2009 | Emerson Microwave Ovens
    Microwave Ovens Logo
    29 people viewed this question
    Top Samsung Microwave Ovens Experts
    William Miller
    William Miller
    Oscar Netto
    Oscar Netto
    Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
