Question about Toshiba Satellite L45-S7423 Notebook
Purchase new battery from attbat, there faq say to upgrade your bios so battery can be recognize, don't no how
  • 124 Answers
You MUST be very CAREFUL upgrading BIOS! Do NOT recommend you take this action if you've never done it before! Laptop may become unusable and you may NOT be able to retrieve your personal information (files, pictures, etc).
Have reviewed the fixes of the BIOS of your laptop and it DOES NOT mention anything about battery.
A skilled technician can help.
Have included the web site for you to read.
www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1845345&rpn=PSL48U&modelFilter=L45-S7423&selCategory=2756709&selFamily=1073768663
Posted on Apr 02, 2011
How Can I Upgrade BIOS On An HP Compaq Presario 2175US?
Open the website chose your model and then download updated Bios software and drivers then burn a CD and follow the process of updating.
Good Luck
Aug 13, 2012 | HP Compaq Presario 2175US Notebook
I have purchase a memory upgrade KByte and not sure how to install. I went to www.kbytememory.com and found nothing to help me.
This looks very much like my old M90... you pop out the battery, locate and unscrew the memory door, and then snap in the new memory. Then restart the laptop... if it beeps at your (this is called a beep code) then the BIOS doesn't recognize one or both of the sticks. Assuming all goes well it should prompt you and say something to the effect of 'amount of system memory has changed, press F1 to continue or F2 for bios'... go into BIOS and confirm its reading the new memory amount (2GB will say 2064). This model apparently only accepts 2 x 1GB sticks so hopefully you didn't order 2GB sticks... unless there's a BIOS update you can install the mobo won't recognize memory sticks greater than 1GB. Good luck.
These links will be very helpful... please rate me if this helps you:
http://www.ifixit.com/Guide/Installing-Dell-Inspiron-E1705-RAM/3987/1
This is the parent page for the E1705:
http://www.ifixit.com/Device/Dell_Inspiron_E1705
Jan 15, 2012 | Dell Inspiron E1705, Intel Core 2 Duo...
Hello I am looking for XP drivers for a "fujitsu lifebook E series 6555" laptop. I would also like to update the BIOS. Fujitsu's website doesn't even list my model...? Any help is...
hi
i have two links for you .. read and review carefully. you will get the drivers you need
http://support.fujitsupc.com/CS/Portal/supportsearch.do
FAQ, http://support.fujitsupc.com/CS/Portal/supportsearch.do?srch=FAQ
How do I upgrade the Bios for E5140, E5320, E5520, E6150, E6520, E6530 and E6550 LifeBooks?
NOTE: This BIOS upgrade is for E5140, E5320, E5520, E6150, E6520, E6530 and E6550 LifeBooks. The upgrade fixes an issue with the Full Dock II/LAN Dock II/Port Replicator II.
Instructions on Upgrading the BIOS.
Step 1: Create a bootable BIOS upgrade disk
This step can be performed on any system (desktop/notebook computer) running a Microsoft Operating system.
  1. Place the BIOS upgrade disk in the floppy drive of your pc/notebook.
  2. Copy the system files onto the BIOS upgrade disk to make it bootable.
  3. For example:
    MS DOS prompt: type 'sys A:'
    MS Windows:
  4. Double click "My computer" on the desktop.
  5. Right click the floppy drive icon.
  6. Select "Format?"
  7. Select the "copy system files only" option
Step 2: Upgrading the BIOS
  1. Attach a floppy disk drive to the LifeBook to be upgraded.
  2. Place the BIOS upgrade disk (created in Step 1) in the floppy drive of that LifeBook.
  3. Reboot the system. Boot from the floppy.
  4. At the command prompt, type:
    phlash /mode=3 filename.rom (put a space after "phlash" and after "3". Filename is the name of the BIOS.)
  5. Allow the system to reboot.
Step 3: Change BIOS settings (For users upgrading from Windows 9x to Windows 2000).
To allow Windows 2000 to better manage your system, change the following settings in your BIOS:
a) Boot the notebook and press F2 to enter BIOS setup.
b) Set Power Management to Disabled
b) Set Plug and Play OS to NO
Consult your user's guide on how to change BIOS settings.
Jan 09, 2011 | Computers & Internet
I have just purchased a new sony battery. my model no. is sony vaio VGN CR510E/L. The laptop doesnt recognize the new battery BPS9 and it says update the bios. i just downloaded the sofware bps9.exe but...
If the battery is not a Sony battery but an equivalent, the Sony may not recognize it as there is not the specified "bit" of information built in to it. It maybe just totally flat in which case it will take a number of hours on charge to get it recognized.
The BIOS upgrade must be done with a good battery fitted and the AC Adapter working otherwise if the power fails whilst loading, you cannot recover the BIOS again.
Dec 16, 2010 | Sony VAIO VGN-CR220E/P Notebook
Upgrading ram on laptop, new ram not recognized.
remove the bios battery for a few seconds...and place it back on ...this will make it see the new ram memory modules...if you are sure they are compatible ..they will work .....in fact ..the ddr1 333 512 M is more that compatible with your system and it will work after you remove the battery ...\ my recommendation is to reinstall a clean operation system after you boot up ...and format the C partition too...this have to be done after memory changes to get the max out of them ..
Nov 13, 2009 | Dell Inspiron 1100 Notebook
Can the cpu be upgraded to BX80526C1000256! If yes what modifications need to be made? Motherboard is EliteGroup P6STP-FL
Hello!
If you want upgrade you CPU, you must first know, specification of motherboard.
If the motherboard can´t see a new CPU, more exactly bios, you can try only one upgrade bios.
I give you a link for a manual and upgrade bios.
When you upgrade bios, try new CPU, if bios again don´t see a CPU, you can´t do anything about that.
Nov 03, 2009 | EliteGroup P6STP-FL Motherboard
My Bios password has got reset
Hi Psyadav,
Try this link http://www.tech-faq.com/reset-bios-password.shtml , there are information on how to reset, with different way, a bios password.
Let me know if this article helps you.
Oct 31, 2008 | Acer Aspire 5520-5908 Notebook
Bios password for acer travelmate 2410
i have had just the same problem, i took my laptop apart removed the cmos battery its just to the side of the trackpack on top of the motherboard, but this did not work, HERE is the solution with out stripping the all the laptop make sure the battery is out and no power to the laptop all you need to do is take the plastic part with the power button on off and underneath you will see a small switch called SW1 move the number one switch to on then power up the laptop press F2 and there you go your in the bios, save all settings turn off put the switch back to where it was put you plastic facia back on replace the battery power up now press F2 and do what you want all is good
Sep 12, 2008 | Acer TravelMate 2300 Notebook
PNY GeForce 8800 GT
change the settings in the bios then restart. make sure that the card is seated right.
Jun 09, 2008 | PNY Verto GeForce 6800GT, (256 MB) PCI...
Open Questions:
Toshiba Satellite L45-S7423 Notebook Logo
150 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
