Washing maching will not fill with water - Washing Machines
  • Washing Mach... Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Apr 02, 2011
Machine whirlpool not filling whith water
This is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call to confirm that it is not something else- like the control board not feeding the correct voltage to the valve ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
May 15, 2011 | Whirlpool Washing Machines
Maching not taking in water
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 26, 2011 | Siemens WXL132GB Front Load Washer
My Frigidaire Galaxy Washing maching will not allow water into the tub.
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Sep 07, 2010 | Washing Machines
THE WASHING MACHING FILLS WITH WATER, GOES THROUGH
Most Likely it's the timer. try to move it by hand to the net cycle. If that doesn't work it's the contacts on the inside fouling up.
Sep 06, 2009 | Whirlpool Washing Machines
Agitator problem
POST MODEL NUMBER PLEASE
Apr 27, 2009 | Washing Machines
My maytag top loading washing maching only fills up with water
take the two screws out of back controll panel than jam somthing to hold the door closed switch forward mine did same many times and it is always that switch moved back a little to far you can check by holding open door and push in switch with a pen or somthing
Apr 01, 2009 | Washing Machines
Whirlpool washer continuouse water water runninng into tub
try turning the mach off while it is spinning and filling.if it continues to fill or drip heavy,the mixing valve is not closing completely and needs to be replaced.if the water stops when the mach is turned off,there is a problem with the pressure switch.
Sep 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Simpson esprit washing machine
put a new pressure switch in it
Mar 25, 2008 | Washing Machines
Washing Machines Logo
125 people viewed this question
Top Washing Machines Experts
