Question about U.S. Robotics MAXg USR5461 (738168036790) Wireless Router
The wireless light is on, the internet as well but my laptop and Iphone is not finding the wireless feed from the router.
Assign a fix IP address to your iPHONE (out of range of DHCP) and reboot your URS5461.
Posted on Sep 20, 2011
My laptop and my iphone indicate that my wireless-g broadband router is putting out a wireless signal; but neither accessory works on the network, even though the bars are entirely full on the devices.
The bars on your laptop or iPhone means that you are connected to the router! Not necessarily to internet. Your internet depends on ISP Internet service provider and modem which connected to your router. To check if you have active internet connection connect your laptop directly to modem provided by your ISP with ethernet cable and try to open a internet browser IE or Safari or Chrome or Firefox and open a webpage! If you are able to connect internet by this mean you have internet connection active. Now disconnect your lap top from modem and connect modem to your Linksys router using WAN port of LINKSYS! Its good to power off and power on (power cycle) once on modem and router to make it work!
good luck!
Sep 14, 2011 | Linksys Wireless-G Broadband Router
Wirelss router won't allow other devices to connect to it - eg kindle, iphone, but internet works fine on computer (which it's plugged into)...
Before you start :
The Following Steps Should be done on the computer that is connected to the router (Plugged with a cable)
Step 1 : Make sure you have internet access
Step 2 : Open Router Setup by typing http://192.168.2.1 in the address bar of Internet Explorer
Step 3 : Once you are at the router setup .. on the left side underneath Wireless you can find Wi-Fi Protected Setup
Click it
Step 4 : If it is asking for a password .. leave the password field blank and click submit
Step 5 : Disable Wi Fi Protected Setup and click apply changes
Step 6 : Now on the left under wireless click Security
Step 7 : If it is asking for a password .. leave the password field blank and click submit
Step 8 : Change the Security mode to WPA-PSK (you can also choose WPA-2 but sometimes it doesnt work )
Step 9 : Type a password (8 Characters , It is Case Sensitive)
Step 10: Click apply Changes
Step 11: On the left , Under Wireless Click Channel and SSiD
Step 12: Change the SSiD to a Different name , Change the Wireless Channel to 11
Step 13:Click Apply Changes
Turn On the Wireless Switch on the Computer (If you are using a Laptop to Connect between router)
Now try to Connect to this new network on both your wireless Computers and Ipad
Let Me Know if it Works
Aug 24, 2011 | Belkin (F5D5231-4) Router
Today I rearranged my router and unplugged it. Now upon plugging my router back in my wireless devices cannot find the internet. This includes my iPhone, iPods, laptops and a desktop computer. The internet...
It happened because the router automatically resets to it's default settings. Maybe you accidentally touch the reset button or the device was shaken to restore its default settings. Go ahead and check the router configuration. Or maybe the wireless switch of your router was turned off. Better check that as well.
Jun 20, 2011 | D-Link DIR-615 Wireless Router
I have just installed netgear wireless ADSL2 modem router. The wireless works fine on one laptop and iphone but even though my other laptop says it is connected and the signal strength is excellent, I...
is your laptop getting a DHCP address? is it getting the correct DNS? Do this by going to control panel. Network Connections. Right click on the wireless connection. choose properties. double click oo TCP/IP. set to DHCP
Also check your Internet Explorer settings to see if it is using a proxy server under internet options. connection settings. If it is on or set to a proxy server. turn it off.
Mar 06, 2011 | NetGear DG834G 54 Mbps 802.11g Wireless...
Trying to connect iphone to wrt160n router but cant
Dear friend fist turn on your iPhone wifi and when your router is find in your iPhone select the router name and enter your password same password use when you conncet Internet with your laptop ....,ok
Mar 01, 2011 | Linksys WRT160N Wireless Router
I have a DI 624 router which is being used by laptops in our house but when i try to find the wireless network on my iphone, ipad and other computers I can't see the network, can you please help? thanks
Did you set the router to _NOT_ "broadcast" the SSID?
On the iPad/iPhone, under Settings, did you "enable" the WiFi?
Does the iPhone detect wireless networks at an Internet Cafe' or a Starbucks or a Public Library?
Did you configure the router to allow only specific MAC-addresses?
Can you view the "log-file" on the router, to see what computers tried to connect?
Dec 20, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
Laptop does not detect wireless from Zyxel 660 router
Dear! You will have to enable wireless conection to access the router and internet. Check your adapter settings and enable wireless conection. Your problem will be solved.
Thanks
Jul 28, 2009 | Zyxel Prestige 660HW Wireless Router...
Forgot my password
please follow the following steps:
1) Click Start > run > cmd > ipconfig (enter) and note down the Deafult gateway should be some numbers like 192.168.1.1 etc 2) Open internet explorer and type those numbers in the address bar and press enter 3) now you will get the router page, login with following details username: admin password: admin or password 4) and in wireless settings you can find the password (WEP) to connect the IPhone
Jan 27, 2009 | Linksys Wireless-G Broadband Router
Please help...internet won't connect
You may be running into a problem of your ISP only allowing one computer on the internet. while the internet is on can you access the internet from the desktop comcast originally setup?  If so that is more then likely your problem.
I have comcast myself and they told me they do not allow home networks. I fixed that problem by using the mac address cloning feature in my router.
The setup cd is also junk, all you should really need to do is:
1. unplug modem, router, and turn off computers
2. Plug modem into router
3. Plug computers into router (don't worry about wireless right now)
4. Turn on modem, wait 20 seconds or so for lights to set,
5. Turn on router. again wait for lights to set
6. Turn on ONE computer that is hard wired into the router
7 Try to surf the net.
8. If successfull try to connect wireless computers (Without using cd) and see if they surf.
If not call comcast and see if your computers are trying to obtain real-world ip's instead of LAN ip's like they should.
If so, you'll need to enable DHCP on the router.
Jul 18, 2008 | Belkin (F5D7230-4) Router (587009)
Open Questions:
U.S. Robotics MAXg USR5461 (738168036790) Wireless Router Logo
37 people viewed this question
Top U.S. Robotics Computers & Internet Experts
Prashant M
Prashant M
Aris C.
Aris C.
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
