Question about Garden
I have a 5020dm Ardisam Earthquake Tiller. The tines (and wheels) turn when trying to start the machine. I just put a new belt on, could the new belt be to tight? Or am I looking at another serious problem.
  • 8 Answers
SOURCE: Stateman Tiller tine not engaging
Sounds like the worm gears are worn to the point they will not engage.
Posted on Feb 21, 2009
SOURCE: Ariens rear tine tiller. What direction are the
The tines should turn counter clockwise or from the ground up toward the tiller not toward you .Owners manuals can be obtained from a local dealer on most often on line..
Posted on Apr 09, 2009
Typus
  • 69 Answers
SOURCE: Roper tiller 26 inch front tine Pulley/belt diagram
I am not sure either, but I think that it would be alot cheeper to buy a new tiller, than to use your strenght fixing a old tiller that you didn't bother to keep the instructions for (no, I am not trying to be harsh. I am trying to be nice. and I am not sure about it coming with instructions, they usually do.)
29259605.jpgSorry, that is the closest picture that I can get.
Here is a link that may help. (IDK, because it is blocked where I am at.) http://www.google.com/aclk?sa=l&ai=CqcKEPGEMSvvXJJyotgeEiOyLB_jqoUWYtdrOBMib0rsYEAMoB1DU-N7X_P____8BYMmOo4qkpMQRoAGUt9H9A8gBAaoEIU_Q6ppHU85NtRLlGbCSz8M4YQ7k6yZkGAMPo_XJ9i4rSQ&num=3&sig=AGiWqtyvlB5FasgaU109ezFuPnc-65WzHg&q=http://www.fixya.com/support/roper%3Fcmpid%3DG3372595023
Posted on May 14, 2009
wadembly
  • 513 Answers
SOURCE: tines go around but wheels are locked in position and won't move
the gears in the transmission are possibly worn out if i can further help e-mail wade at wadembly@aol.com
Posted on Jun 28, 2009
  • 138 Answers
SOURCE: Craftsman tiller engine dies when I try to engage tines
tilt the back of the tiller up and check for a rock or stick wedged in between the tines and the shield
Posted on Aug 21, 2009
I need a parts manual for a earthquake model 5020 rear tine rototiller
contact the manufacturer on the net and look for a pdf version if available.
Jun 17, 2015 | Ardisam 5.5 Hp Rear Tine Rototiller
Why is the belt wearing out so quick, i have used my brand new earthquake rear tine tiller less than ten hours and have gone thru three belts.
-The pulley, idler are not line up and may be too sharp edges. or may be some other part is touching the belt when is running.
Good luck
mai
Jun 08, 2014 | Ardisam Inc Earthquake Mini Cultivator
Garden master tiller 5020d
Get behind the tiller as if you are ready to use it. Look down towards the tines. There's a protective cover. Remove it and you will see the belt running vertically between the motor and the tines.
May 08, 2013 | Ardisam 5.5 Hp Rear Tine Rototiller
How easy is it to replace clutch cable on earthquake mc 43 tiller
Remove the 4 to 6 screws holding the engine to bottom gear box and lift eng off. clutch is right there. It could be the teeth on the lower branze gear are stripped. lay machine on its side and with tines off remove gear box cover.
Apr 08, 2013 | Ardisam Inc Earthquake Mini Cultivator
Pull cord stuck
remove starter assembly and check the spring and pulley.
Oct 23, 2012 | Ardisam Earthquake - 7055C - Gear-Dive...
Have been on the computer all morning many diff sites getting a nervous breakdown want tine geat & shaft part for earthquake mini tiller all sites are impossible to use help help help
Select the model on this website and then the part. The link below is for MC43E Mini Cultivator http://www.getearthquake.com/foundations/store/partsblowup.asp?product=MC43E
Jul 19, 2010 | Ardisam Inc Earthquake Mini Cultivator
Need a user manual for Earthquake 3365PS tiller
I need a service manual for the earthquake 9800 auger with the 3.8 hp tecumseh.
May 12, 2010 | Ardisam 5.5 Hp Rear Tine Rototiller
I need a forwward cable for an earthquake reartine rototiller #5020dm how to order. thanks
I googled Earthquake 5020DM tiller and show a site that has a technical manual. It has the diagrams and parts numbers. It looks like the forward and reverse cable are the same. You may have to call ARDISAM direct to get the cable.
Oct 02, 2009 | Ardisam 5.5 Hp Rear Tine Rototiller
Older model earthquake rear tine tiller won't start
try replacing the spark plug and spraying a shot of starting fluid into the cylinder via the spark plug hole
Sep 30, 2008 | Ardisam Garden
Garden Logo
66 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
