Three red lights flashing
Well mainly it is down to overheating, and as you play your games the
motherboard flexes ever so slightly and the soldering snaps off and
that is when you are left with the red lights of doom.
Step 1: Turn on the console, and check the light on your power supply
The power supply light is located on the black box that is in the middle of your power cord.
Step 2: If power supply light is green, try this solution
Step 3: If the power supply light is red, is orange when the console is powered on, or is not lit, try these solutions:
Solution A: Unplug your console, plug it into a different outlet in a different room, and then turn it on
This will help determine whether the problem is with your power supply, your power outlet, or your console.
Solution B: Request a replacement power supply
If the power supply light is still red, orange, or not lit, the problem is with your power supply. Contact Xbox Support to obtain a replacement power supply.
