Question about Samsonite Tripod
SAMSONITE CARRY TO INSIDE THE PLANE,I DO NOT HAVE THE MODEL No. IS THE 21 INCHES SIZE, THE HANDLE CAN NOT PULL UP IS STOCK WHAT MAY I DO TO MAKE IT WORK, I JUST BOUGHT IT. THANK YOU FOR THE ASSISTANCE YOU CAN PROVIDE ME, O LET ME KNOW WHERE SIMSONITE REPAIR DEALER I CAN TAKE IT.
If you just bought it, you should have a guarantee. look on the site of Samsonite to find a repair company in your area.
Posted on Apr 06, 2011
Y does my 2003 mercury outboard 200 efi take so long to get by 21 foot pro craft out on a plane it is really slow
Check the size and pitch of the prop. By reducing the pitch you will get better hole shot out of the water ,but my be lose a little top end speed. This will be stamped or cast into the prop eg: 15x21 which stands for 15 inch diameter by 21 inches pitch.
Jan 26, 2015 | Boating
What are the wheel and tire sizes front and rear for my 99 1200 sportster?
Fitment for 1999 XL Tubeless Cast Wheels:
Wheel Position and size = 19 inch Front; Rim Size and Contour = T19x 2.15 MT; Rim Valve Hole Diameter = 0.45 inch; Tire Size = Dunlop D401 ELITE S/T 100/90-19
Wheel Position and size = 16 inch Rear; Rim Size and Contour = T16 x 3.00 D; Rim Valve Hole Diameter = 0.35 inch Tire Size = Dunlop D401 ELITE S/T 130/90-16
Wheel Position and size = 19 Inch Front; Rim Size and Contour = T19x2.50 TLA; Rim Valve Hole Diameter = 0.45 inch Tire Size = Dunlop K591 S&FR Elite SP 100/90-V19
Wheel Position and size = 16 Inch Rear; Rim Size and Contour = T16x3.00 D; Rim Valve Hole Diameter = 0.45 inch Tire Size = Dunlop K591 S&FR Elite SP 130/90-V16
Tire Fitment for 1999 XL Tube Laced Wheels:
Wheel Position and size = 19 Inch Front; Rim Size and Contour = T19x2.50 TLA; Tube Size = MJ90-19 Tire Size = Dunlop D401 ELITE S/T 100/90-19
Wheel Position and size = 16 Inch Rear; Rim Size and Contour = T16 x 3.00 D ; Tube Size = MT90-16; Tire Size = Dunlop D401 ELITE S/T 130/90-16
Wheel Position and size = 21 Inch Front; Rim Size and Contour = T21x215 TLA; Tube Size = 3.00 x 21; Tire Size = Dunlop Touring ELITE II MH90 - 21 56H
Wheel Position and size = 16 inch Rear; Rim Size and Contour = T16x 3.00 D; Tube Size = MT90-16; Tire Size = Dunlop Touring ELITE II MT90 - B16
Tire Pressure - All Models:
Cold up to 300 Lb. Load (includes rider, passenger and cargo)
Front = 30 psi (2.1 bar)
Rear = 36 psi (2.5 bar)
Up to GVWR maximum load
Rear = 40 psi (2.8 bar)
Jul 07, 2014 | 1993 Harley Davidson XLH Sportster 883
Samsonite luggage
That keyhole is so that TSA can open that lock and take it off. They only time they would do that is if your are flying on a plane and the bag is in checked luggage and it needs to be searched.
May 01, 2014 | Samsonite Large Dial Travel Sentry Combo...
I have bought a spinner 75/28 and can not change the lock ?
I'm not sure of this model, but on codelocks there is normally a small hendel on the inside. Put this in a locked position and you may set the code as you wish and then release the hendel to "lock" the code.
Jul 14, 2012 | Samsonite Silhouette 11 Hardside Spinner
Replace starter handle for troy bilt tuff cut 210
most homedepot and lowers stores stock them or order threw sears parts online
Apr 23, 2012 | Garden
Does a 21 inch wheel fit my 2005 Ultra Classic stock front fender ?
Hi Michael, no way on the 21" wheel.
Front MT90B16 72H
Have nice day.
Mar 14, 2012 | 2005 Harley Davidson FLHTCUI Electra Glide...
Would 205 75R14 fit my standard 4 door 2004 chevy cavalier or would they rub
Your original size is 195 70R/14. The sport model has 205 55R/16. You are going 10mm wider or 5mm deeper to the inside, but the profile is higher by 5%. I would say they should fit fine.
BUT. I am not an expert in tires. You need to check this out with a Chevy dealer or reputable tire shop.
Using tires that are not the recommended size and/or rating can adversely affect vehicle handling, performance and safety.
J
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is really appreciated for the FREE answering of your question.
Feb 11, 2011 | 2004 Chevrolet Cavalier
Two people can not shower at the same time because of the water temprature fluxuation. How can I remedy this problem
Hello.. The problem you are having is common. there are only two causes. One is that the water pipes in the house are old and partially filled with scale and such. The other, and more common problem is that the house is plumbed entirely with one size of pipe, usually 1/2 inch pipe. Houses that do not have this problem use a larger size pipe to carry the water around the house, say 3/4 inch and then only go down to 1/2 inch when they are about to feed a faucet or a toilet. There is no inexpensive fix to this problem. The only fix is to replumb the main lines in the house with a larger size pipe and then go down to the 1/2 inch size when you are near the faucet or toilet.
Dec 02, 2009 | Delta Faucet Delta 470-BL-DST Signature...
Mounting info for Meade telescope 70 AZ ADR model 04054
Here is the mnanual for the telescope-- screw sizes may be listed inside-
However just carry it up to your local ACE hardware store and the friendly folks there will help you find the proper screw size-- (or any well stocked hardware store).
Good luck
Mar 16, 2009 | Meade Optics
Photography Logo
330 people viewed this question
Top Samsonite Photography Experts
ittco
Level 1 Expert
Are you a Samsonite Photography Expert? Answer questions, earn points and help others
