Question about Kenmore Dishwashers
Items come out gritty - Kenmore Dishwashers
  • 4,323 Answers
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes.
Hope this helps...
Daniel
Posted on Apr 02, 2011
  • Kenmore Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
My maytag W10199645 is leaving gritty residue on my mugs & glasses. how can i troubleshoot this?
Try using a dishwasher cleaner. You can get it at any supermarket that sells dishwasher soap.
Nov 06, 2014 | Maytag Dishwashers
My dishes on the top rack are not coming out clean. We checked the spray things and they are not clogged. The top rack items are gritty and stale type water.
Make sure there is nothing obstructing the upper spray arm(dishes). Also, make sure the upper basket connects to the water inlet hole in the back of the tub, when it is pushed in all the way
Sep 21, 2010 | KitchenAid Dishwashers
We get a gritty / sandy residue. what can I do?
The cause may not be your dishwasher.
Especially hard water may leave the residue. If you don't have that problem when you hand-wash, then check your pipes. Homes more than 40 years old may have galvanized pipes that eventually rust on the inside. The grit could be grains of rust from the pipes. If you do have galvanized pipes (rather than copper) then you may need to replace them. You could put in a filter as a temporary work-around, but that will eventually clog with the gritty material.
Feb 16, 2010 | Bosch Dishwashers
How do I replace the frame for the door? Is it
Actually it is more realistic buying the door and glass complete. Price difference is not excessive. Removing plastic d/layer "glass" dissrupts the seal and small nitty gritty items break. Must be 100%good seal for microwave action.
Sep 24, 2009 | GE JVM1650 1000 Watts Microwave Oven
Residue on glassess etc
changes r that gritty residue is detergant .water should b around 160 to desolve the deter.
Jul 03, 2009 | GE Nautilus 24" Built-in Dishwasher
Clutch adjustment
Sounds like time for an oil change. Dirty, gritty oil is causing the clutch plates to grab. Change the oil filter along with the oil. Ride the bike fifty miles or so then change the oil again. No new filter this time. Doing this will flush out the dirty oil.
The bike is 10 years old. It is probably time, (or past time), to replace the clutch cable if yours is not hydraulic. Most cables never seem to get lubricated. The oil and the cable are low cost items and you can't go wrong in doing the service.
Please rate this solution. Thanks Stacy!
Apr 21, 2009 | 1999 Titan Gecko RM
A gritty feel is left on glasses and some dishes
Hard water! Try Cascade Rinse Aid.
Mar 25, 2009 | Dishwashers
Hotpoint Auqarius dishwasher. I have resentley moved house and reconnected the machine. it works through programme fine but is sometimes leaving dishes gritty and not quite clean. I have cleaned filters,...
It sounds like there could be a gritty deposit in the bottom of the system. At the start of the cycle the unit takes in a set amount of water and recycles it around to the drying phase.
Try and run the diswasher a few times with no items in it - this will may help to flush it out.
If the gritty deposit coloured white this could be that your new home has more limescale in its supply. Try getting dishwasher tablets with limescale protection to see if that helps.
Finally, please ensure the spray arms free to rotate on each cycle. Failure to do this leaves grit on certain items and not others.
Please dont forget to rate.
Jul 07, 2008 | Dishwashers
Not washing properly
This D/W should have been re- called ,toooo many flaws.Sorry!
Nov 22, 2007 | Indesit 24 in. D63 Free-standing...
Dishwashers Logo
125 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
